Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-10-2014, 09:45 AM   #586
Xpress's Avatar
Anybody have info RX3 17.5? Better than the TX for TC?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-10-2014, 10:09 AM   #587
Better than most of the current TX motors, maybe not as good as the first TXs. I find it likes a lot of timing (just short of the plus mark) and I'm gearing around 3.8 on a relatively small track (80ft straight).
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 11-10-2014, 10:50 AM   #588
Xpress's Avatar
I read the bottom bearing is larger, but not sure if that is ID or just the OD? I saw it comes with a 12.4 rotor, but if the ID of the bottom bearing is larger none of the HT rotors will fit?
-Espo
Old 11-10-2014, 11:59 AM   #589
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
No the motor is made at a different factory and none of the TX parts or rotors will fit it.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-10-2014, 12:52 PM   #590
metalnut's Avatar
Trader Rating: 36 (100%+)
How is that a lot of timing if the TX motors liked to be 1.5 to 2mm past the last + mark?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 11-10-2014, 12:54 PM   #591
Odin544's Avatar
Trader Rating: 93 (100%+)
The + mark on the can means nothing really. You can't compare the timing marks from one motor to another.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-10-2014, 02:03 PM   #592
Team EAM
I would not advise going much past the + sign on the RX motor. It has a lot more timing built into it than the TX did.
EA
Contact Us
Old 11-10-2014, 02:22 PM   #593
Since I got my motolyser I've learned the markings on the motors don't mean anything at all except the relative settings on that particular motor. Even on motors of the same brand the timing can vary a lot even with the same settings on the end bell.
WF D06 USVTA
Old 11-10-2014, 06:05 PM   #594
stikman's Avatar
Originally Posted by Josh-n-ya View Post
Ok so I have been running my Orca's VXX now in blinky now for awhile and they are great. I put together a mod car and have tried to set up esc for that. I was given a setup sheet and programmed esc but the issue is it is not ramping or boosting up. I thought it was a sensor wire thing so that has been changed several times to no luck. Then I swapped out the motor and same issue. For mod you only mess with settings in modify mode? Or do you adjust anything in stock mode as well? Both program box and esc are 4.1ver. Below is my setup.
Basic:
Running mode=Forward/brake
Battery=Lipo
Cutoff Voltage=Middle
Overheat=Off
Neutral range=6%
Modify mode:
Timing start=40%
Timing=0%
Timing Interval=+3
Turbo Delay=0.06
Turbo Timing=14%
Turbo Interval=+3
Drag Brake=10
Initial Brake=3%
Brake Freq=2k
Punch=3
PWN=32%
This is Hagbergs setup I was given by EA. So I don't know if I setup anything in Stock mode or if there is something else Im supposed to do. Any thoughts?
This setup is basically a blinky mode with 14deg of turbo at the end of a long straight.
if you want some boost on the infield, you need to add value to the timing.
and add that value to the turbo equally.
ie: change timing to 10 and turbo timing to 24
stikman is offline   Reply With Quote
Old 11-10-2014, 07:17 PM   #595
Ran both motors on the Motolyser tonight:
Gen1 TX 2mm past last mark on scale = 53deg
RX3 1mm short of plus symbol = 60deg
WF D06 USVTA
Old 11-11-2014, 02:20 PM   #596
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Exactly its like blinky mode. I changed what you suggested and it still made no difference. I was hopeful for a minute. I might try and set everything to default again and start over. With a 4.5 I should have been spinning the rubber off the tires on a bench test but its about the same speed as my 17.5 blinky.
Josh-n-ya is offline   Reply With Quote
Old 11-11-2014, 02:28 PM   #597
Odin544's Avatar
I would load the default program from the program card then adjust from there. I was told that's like reloading the firmware?
TriCitiesRC.com
Old 11-11-2014, 02:58 PM   #598
bkspeedo's Avatar
What size track are you running Mod on? If your motor sounds like a 17.5 free wheeling somethings a miss, especially with a 4.5.
Set the timing on the motor to 0 or +5, 1 tick above zero. Gear around 8.2-8.4 FDR. Use timing if there's some long shoots on the infield, if not don't.
Like I mentioned in my post a few days ago. Turbo Timing only functions when your throttle is recognized to be at 98%+, if not you'll never see it. Make sure the ESC is seeing 100% throttle.
Using just turbo timing is good for tighter infields and you just want some extra speed on the straight.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-11-2014, 08:56 PM   #599
Josh-n-ya's Avatar
Might just do it tomorrow. thx
Im geared at 8.4 right now. Just bench test so far and know something isn't quite right. Headed to the track Saturday. Big track 100+ straight. Motor is at 0*
Old 11-12-2014, 05:27 PM   #600
stikman's Avatar
did you rebind the ESC to the radio? sound like you do not get a full throttle
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
