Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-01-2014, 09:40 PM   #571
Trader Rating: 113 (100%+)
Does anyone have any info on the vx3? I really would like to know the specs maybe see the manual.
Breeze is offline   Reply With Quote
Old 11-05-2014, 08:02 PM   #572
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I have just bought a new VXX ESC it has a 4.1 software in it. I went to use my programing box to adjust it to the ESC programing to match the settings to my liking, just like my ESC with the 3.3 software I have in my older VXX. When I try to use the stock blinky mode or any other mode the program box says sending and won't complete's programing.
I have programmed many vx and VXX with my box but they all have 3.3 software. This ESC won't program. Can you guy's help me? Thank you guy's ahead of time.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 11-05-2014, 08:31 PM   #573
nolo148's Avatar
I believe you have update your programming box to the newer version for it to program the 4.1 software.
Owen Ren
ll ORCA ll Pro-Spec ll
Overgeared Racing BOD (Facebook - Overgeared Racing)
nolo148 is offline   Reply With Quote
Old 11-05-2014, 08:45 PM   #574
bkspeedo's Avatar
nolo148 is correct you need to install the latest programming box FW as well.
2014/10/07 ORCA PROGRAM CARD Ver 4.2 140823A ( Support Ver 4.1 VX,VXX,VX1,VX3 ) New!!
http://www.orcarc.com/en/download.asp
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-06-2014, 05:42 PM   #575
fullout's Avatar
Send a message via MSN to fullout
How do i physically attach my program card to my usb link for updating?
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 11-06-2014, 06:42 PM   #576
Hi Daniel,
There is an attachment that has a sensor wire type connection on one end and a three pin connection on the other end that allows the update of the Program Card.
If you are at St. Catharine's on Sunday, we can update it for you. Otherwise, we could meet during the week if you are in the West End.
Regards,
Ian
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 11-06-2014, 08:42 PM   #577
What do I need to add 4.1 firmware to my programing box?
Old 11-06-2014, 11:17 PM   #578
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Yes!
Josh-n-ya is offline   Reply With Quote
Old 11-07-2014, 03:22 AM   #579
R Dodge's Avatar
Originally Posted by Josh-n-ya View Post
Yes!
Hey guys,
You'll need the USB Link (Part no. OUL3680E) and you can download firmware version 4.0 140319A to your program box, that should support 4.1 according to the Orca site. I've had my program box since ver 3.0 and I've downloaded all versions to it and never had any issues tuning any Orca speed control regardless of what firmware they have. Brent posted the link to the downloads page a few posts back.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 11-07-2014, 05:47 AM   #580
fullout's Avatar
Originally Posted by ADHSponser View Post
Hi Daniel,
Regards,
Ian
Hi Ian,
Can i purchase this connector locally? I can't make St. Catherines this weekend. And thanks for the response Ian.
Daniel Weinstein
rcamerica.com
orcarc.com
Old 11-08-2014, 08:05 PM   #581
Josh-n-ya's Avatar
Ok so I have been running my Orca's VXX now in blinky now for awhile and they are great. I put together a mod car and have tried to set up esc for that. I was given a setup sheet and programmed esc but the issue is it is not ramping or boosting up. I thought it was a sensor wire thing so that has been changed several times to no luck. Then I swapped out the motor and same issue. For mod you only mess with settings in modify mode? Or do you adjust anything in stock mode as well? Both program box and esc are 4.1ver. Below is my setup.
Basic:
Running mode=Forward/brake
Battery=Lipo
Cutoff Voltage=Middle
Overheat=Off
Neutral range=6%
Modify mode:
Timing start=40%
Timing=0%
Timing Interval=+3
Turbo Delay=0.06
Turbo Timing=14%
Turbo Interval=+3
Drag Brake=10
Initial Brake=3%
Brake Freq=2k
Punch=3
PWN=32%
This is Hagbergs setup I was given by EA. So I don't know if I setup anything in Stock mode or if there is something else Im supposed to do. Any thoughts?
Old 11-08-2014, 08:21 PM   #582
Did orca give up on the vx8?
Old 11-09-2014, 01:43 AM   #583
R Dodge's Avatar
Basic:
Battery=Lipo
Overheat=Off
Neutral range=6%
Modify mode:
Timing start=40%
Timing=0%
Timing Interval=+3
Turbo Delay=0.06
Turbo Timing=14%
Turbo Interval=+3
Drag Brake=10
Initial Brake=3%
Brake Freq=2k
Punch=3
PWN=32%
Everything looks good there, tho I prefer to run my voltage cutoff at like .02 or whatever the lowest value is. I don't think that's your problem here tho. I'm running a very similar setup and it's really good. Seems like you've tried everything I would've tried, except maybe reloading the firmware on the speedo and starting over completely.
Old 11-09-2014, 07:02 AM   #584
Josh-n-ya's Avatar
Actually I tried two speedo's with the new software installed. I was wondering if there is anything else I have to do? I recalibrated radio too.
Old 11-09-2014, 09:29 AM   #585
bkspeedo's Avatar
Turbo only works when the throttle is at 98%+. Make sure the ESC is recognizing full throttle. Try playing with throttle end points or sub-trim.
Brent Klingforth
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
