Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-03-2014, 09:27 PM   #511
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I ran the new software with a VXX today in modified TC with a 5.5 and it was smooth and ran flawless. Seemed better than the previous couple versions but hard to tell because we were outdoors for the first time this year.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-04-2014, 10:17 PM   #512
EDWARD2003's Avatar
Thank you Team ORCA for powering my 1/12 for the TQ and win of the first stage of the All Japan Nationals. The motor had mad rip all throughout the day and posted the fastest lap which was 0.200 faster than the next guy.
EDWARD2003 is offline   Reply With Quote
Old 05-10-2014, 01:05 PM   #513
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I see that Alex Hagberg is using a different speed control from the ETS chassis focus, when will that be available.
Racing4Evo is offline   Reply With Quote
Old 05-10-2014, 01:14 PM   #514
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Only thing I see is the VXX There. I dont see anything else other than he has a futaba receiver in his car now too. Havent heard he switched from KO.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 05-10-2014, 02:41 PM   #515
Racing4Evo's Avatar
There is different wiring from older Orca speed controls where the "A" and "C" wire are reversed. Now it lines up with other manufactures' wiring pattern.
See below...
Old 05-10-2014, 04:11 PM   #516
Team EAM
See below...
Thats a new adjustment in the software being tested I am told. I have not put 4.1 on any of my speedo's to see if it is in there or its something newer. He is always testing new stuff for ORCA.
EA
Contact Us
Old 05-10-2014, 05:32 PM   #517
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
EA
The new v4 software allows you to set which way you wish to have the ABC wires. You set it via the program box. Very nice feature.
It is available now on the ORCA site.
HTH
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 05-10-2014, 05:48 PM   #518
Team EAM
HTH
Thanks for the confirmation! I know that version 4.1 is the official ROAR version. They are just waiting on ROAR to give the final word before they put it up on the site for download.
EA
Contact Us
Old 05-10-2014, 06:46 PM   #519
Odin544's Avatar
Trader Rating: 93 (100%+)
is it normal to run timing on the negative side?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 05-14-2014, 07:03 PM   #520
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
whats the bottom end like on these motors say vs a SMC or orion motor?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 05-14-2014, 10:51 PM   #521
Jerz616's Avatar
Trader Rating: 49 (100%+)
i don't know much about those, but my 17.5 has nice low end. It comes with a 12.5 rotor that is stronger then the trinity 12.5HT. It is as fast as the D3.5 on the low end, but the speed of the D3.5 is much better.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 05-14-2014, 10:54 PM   #522
I assume the mod motors are the same?
yokomo yz-2
Old 05-15-2014, 10:44 AM   #523
emacrimes's Avatar
What would be a good setup for VXX-Trinity D3.5 15.t?
Something fast but no too much on the limit.
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 05-24-2014, 07:55 PM   #524
CSeils's Avatar
Trader Rating: 48 (100%+)
What is a good starting point for timing on a 21.5 ORCA?
Running USGT class on carpet with the FDR at 3.75. First practice run i was tempting up at 175
Timing on motor was above the 10 mark.
Should I gear down or time down?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 05-24-2014, 08:28 PM   #525
Jerz616's Avatar
What's your track like. I used to run mine with the timing 1.5-2mm past the lady mark with about a 3.72 fdr. That's on a 96X48 carpet track. Temps were anywhere from 140-160. Track had a few tight corners but pretty fast. I'd start at 3.88 with the timing at the last mark. Temp from there and adjust gear or timing. These motors can take some heat do don't be afraid to bump the timing past the last notch.
Ryan Gracey
XRAY XB8'14
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
