Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 12-19-2013, 05:44 AM   #406
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by rc car guy View Post
well trying to use the stock 12.5 rotor in the motor is very tough i cant below a 3.9 fdr on the track i run or else it gets above 160 (hasnt been there yet but it was close) im only at 1mm past the timing mark do you think i should reduce the timing?
What size is the track and do you run a fan? I'm geared at 3.72 with 2mm past last mark and I don't go above 140*. Our track is 96x40ish with some pretty tight spots. This is in my 17.5 sedan.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-19-2013, 07:15 AM   #407
rc car guy's Avatar
36X60 I think some would classify our grip as medium amount the picture is when the layout first was put down also my car is FREE I made sure of that I did mess with the rotor shimming seem to give me a bit more power without increasing the heat, although i did hear running drag brake will increase the motor temp i run about 50% drag brake with the tekin, i was going to take it out and change my driving style to just use the brake... not an ideal choice but it should go around the corner faster haha
rc car guy is offline   Reply With Quote
Old 12-19-2013, 08:04 PM   #408
rc car guy's Avatar
i cut the timing down to 0 or centered the factory setting and added 2 teeth it really helped i think i am going to go down a tooth and up on the timing to find a happy medium however stilling running about 155 after 6.5 minutes i figure 30 sec of practice laps and the 6 min race
Old 12-19-2013, 08:24 PM   #409
Jerz616's Avatar
That much drag break will heat a motor up. The factory setting on them is at the 10* mark. I would put it to that and run about a 3.88 FDR on that track. Cut the drag break in half and you will prob drop temps to about 145*ish. That's still pretty cold. They can take some heat. I think a few guys at IIC got them close to 200* and they were fine. Obviously not recommended to get them that high but you won't be worried about smoking a motor.
Ryan Gracey
XRAY XB8'14
Old 12-19-2013, 08:37 PM   #410
rc car guy's Avatar
ya if i drop a tooth thatll be close to where im at and about 1 tooth is 20 deg give or take the dealer from the track who blew up his orca by running that hot advised me not to run it that hot im not running against a bear its a club race if it comes down to the other guy out motoring me then so be it however we were at the same speed he might have gained a foot on me on the straight and i know the cars faster now that ive done the change but i appreciate the input i really do
Old 12-22-2013, 06:31 PM   #411
B00t13g's Avatar
What is everyone running for settings in 2wd mod buggy?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is online now   Reply With Quote
Old 12-24-2013, 05:03 PM   #412
monkeyracing's Avatar
Has anyone tried using the Orca USB link with a 64 bit (Win 8.1) machine? I can't get the device to fire up, even after installing the latest UART drivers from Silabs. My other USB devices work perfectly.
It works fine on 32 bit Windows and even gets recognized by my Linux box.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-28-2013, 10:28 AM   #413
terryh's Avatar
Trying to find out if the 80c rating on the ORCA INFINITE LiPo 7000mAh 7.4V 80C RACE PACK is the 'continuous' rating, or the 'burst' rating? Cant find this info anywhere....
terryh is offline   Reply With Quote
Old 12-28-2013, 02:22 PM   #414
Trader Rating: 27 (100%+)
'C' ratings means pretty much nothing at all since there's no standard of measure. Don't even worry about it.
Orca has fantastic batteries, so go ahead and get one and feel assured that you have one of the best.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-29-2013, 04:01 PM   #415
Odin544's Avatar
Trader Rating: 93 (100%+)
Is there a torque rotor option for the orca TX 17.5 motor? I see they have the OTR15MSH for mod motors. Anyone tried this in a 17.5?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-29-2013, 05:46 PM   #416
rc car guy's Avatar
this "stock" rotor is stonger than my ht rotor, it is all you will need, maybe too much i run the motor fairly good motor not the fastest still trying to get my car there though but its a good motor
Old 12-29-2013, 08:05 PM   #417
I recently picked up a Orca 13.5 motor. Is there a good way of getting the bearing out if the sensor board? I would like to clean the heavy grease out of it.
letrbuk is offline   Reply With Quote
Old 12-30-2013, 07:18 AM   #418
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Its continuous rating. The ORCA 2S packs are very good!
The stock rotor that comes with it is a 12.5 Medium strength rotor (but its stronger than other companies "12.5 HT" rotor. They do make one that is stronger but its so strong that it doesnt run very well in anything but possibly a SCT. Its about 100-150 points higher than the stock one.
You can look on the shaft of the rotor and its engraving gives its strength. 125S means 12.5 Spec. The MH is medium hard. The SH is super hard. They also have 123S which are 12.3 spec rotors. I have a few of them here that havent been put up on the site yet.
It usually just pushes out with light pressure. If you dont have a bearing remover you can just use a socket wrench that fits along the outside race and push it out. Same for going back in.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 12-30-2013, 07:56 AM   #419
I'll have to try again. I'm just worried about breaking the sensor board as I have not been able to find anyone who carries spares. The way it's designed even if I had a bearing puller I would be pushing on circuit board material to get it out.
Old 12-30-2013, 12:55 PM   #420
Team EAM
you did take the board off of the endbell correct? The bearing comes out the endbell side of the sensor board.
EA
Contact Us
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 10:04 PM
SEO by vBSEO 3.5.0
