Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-10-2013, 01:10 AM   #346
Trader Rating: 23 (100%+)
I am looking for a usb link if anyone has one for sale.
bmcallister is offline   Reply With Quote
Old 10-11-2013, 05:58 PM   #347
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Eric does the orca spark just install into the car or does it need to be programmed somehow . seems like the throttle acceleration is slow ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-11-2013, 07:16 PM   #348
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
FYI The motor has offically been approved.
http://roarracing.org/4rmb/showthrea...=2001#post2001
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-11-2013, 08:41 PM   #349
mbykerman's Avatar
Trader Rating: 45 (100%+)
Hey Justin, the spark has to be adjusted to add punch and other things. I got one from Eric and I love the hell out of it. Big difference between the spark and the rs.
mbykerman is offline   Reply With Quote
Old 10-12-2013, 06:26 AM   #350
Am I able to do this with the buttons or does it need to be hooked up to something?
Justin & Matt Lyons
a800s sanwa m12s
Old 10-12-2013, 11:25 AM   #351
ngo8's Avatar
Send a message via ICQ to ngo8
looking for a mod 5.5 starting setup for touring car carpet track size 80x60 any suggestion will be great thanks.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 10-12-2013, 11:52 AM   #352
You could find PY setups at quantumracing-rc.blogspot.com.
I run Offroad either 13.5 stock or mod and I always start with his as a base.
Various setups from him or Hagberg, every time I got a setup before the firmware update is out.
I consider he (can) use every bit of power the esc/motor/lipo can handle so I try a little lower to start with then work my way up on timing and turbo to fit the track.
Then Drive freq and punch then brakes.
Telemetry is nice to check max temp and rev after a run.
He use a fan on speedo and motor (Orca launch a fan mount and large fan for motor for that matter), it helps.
Also ceramics motor bearing if needed.
mojo tom is offline   Reply With Quote
Old 10-12-2013, 04:26 PM   #353
mbykerman's Avatar
Justin you have to get the program box to adjust settings on the spark.
Old 10-12-2013, 08:52 PM   #354
monkeyracing's Avatar
You can adjust the Spark with the program button. I've got the USB link and the program box as well. Most of the time it's faster to use the button on the ESC. The only function of the USB link is updating the firmware, which was last revised in 2011.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-13-2013, 03:35 PM   #355
Any word yet on what the base timing on the ORCA TX 17.5 motor is? Mine was running pretty well at IIC with 15deg of timing and FDR of 3.6 so that tells me the motor probably has more than 30deg built in. Wondering how high people have pushed the FDR and timing and when the efficiency curve starts getting steep for the timing.
I only run in blinky classes.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 10-13-2013, 05:16 PM   #356
thanks to orca for the great support at the iic!!! the speedo and motor performed flawlessly!!!
John Birmele
JohnBirmele.com
John birmele is offline   Reply With Quote
Old 10-15-2013, 05:53 AM   #357
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
25 degrees of base timing. You can go up to 3mm past the last notch of timing which puts you at about 60 degrees. After that it starts to stutter and overlap.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 10-20-2013, 09:00 AM   #358
J.Filipow's Avatar
Trader Rating: 14 (100%+)
Looking for some setup/gearing help for my ORCA Vritra ESC, for a Reedy 13.5 boosted application. Outdoor asphalt track (Tamiya America), medium grip and bumpy surface with a 100' straight away. Can anyone provide a starting point for a FDR and boost/timing/turbo?
Thanks.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
Reedy / RC America/XRayUSA / Hudy / Avid / JConcepts / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 10-20-2013, 03:52 PM   #359
B00t13g's Avatar
Looking for a setup for the vxx with an orca 5.0. Also interested in gearing for an indoor carpet track. Size of vegas. t4 14
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 10-20-2013, 07:03 PM   #360
For those that want to use the ORCA TX motors for ROAR events.
Only the endbell with "R" is ROAR legal.
Only the endbell is different as the original endbell is slightly too big.
About RC Racing LTD. North America importer:
ORCA RC Product
About RC racing is offline   Reply With Quote
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
