Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree8Likes
Old 01-30-2013, 07:31 PM   #226
Originally Posted by 2Quick View Post
Can someone help with a setup for VX speedo V3 in 17.5 boosted on an asphalt low grip track with 70Meter straight.
You can try this setup!
Timing start: 5%
Timing:36
Timing inter.:Nor.
Turbo timing:56
Turbo inter.:Nor.
Turbo delay:0.1s
PWM:8K
FDR 6.0
Orca RX2 17.5 motor: motor timing 3 lines.
Max. Motor Temp. after 6mins 160f*
Keith Yu
Team ORCA/About RC Racing/Team Pro-Spec/CTRL Systems/
APS Racing/RCMISSION/Teamorca.shop/
[email protected]
Keith Yu is offline   Reply With Quote
Old 01-30-2013, 07:37 PM   #227
Originally Posted by canon View Post
has anyone tried the orca spark for 13.5 boosted class? im planning on getting one but i want to know if it will be competetive enough
For club level should be good enough but the VX can allow you to use higher timing and turbo setting!
Keith Yu
[email protected]
Old 01-30-2013, 10:38 PM   #228
monkeyracing's Avatar
Hey Keith! How you doing?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-31-2013, 12:52 AM   #229
Nico''s Avatar
Hi,
does someone use Orca RX2 10,5 motor in blinky stock please?
Ho is it compared to other motors please?
thanks,
Nico'
Nico' is offline   Reply With Quote
Old 02-02-2013, 10:56 AM   #230
Qualifying is complete at the Snowbirds - and ORCA has TQ for two of the touring car classes. In the 13.5 Super Stock class, Andrew Hardman TQ'd and in the Mod class, Alex TQ'd and Andrew was .29 behind.
1) Alexander Hagberg (ORCA) 29 5:05.686 10.366
2) Andrew Hardman (ORCA) 29 5:05.981 0.295 10.346
Thanks to Keith Yu and the rest of the ORCA team for the great support.
Regards,
Ian (Andrew's Dad)
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 02-05-2013, 12:19 PM   #231
ngo8's Avatar
Send a message via ICQ to ngo8
Run my orca vx this past weekend in my touring car with lrp 5.0 turn motor ...ran really good all day long and in the main after about 4 minutes it suddenlly stopped would not work at all i thought it thermalled at first so i left it till i got home but still it was dead then i did full throttle and nothing till i spun the spur gear and then it worked and only worked while it was rolling and full stop it will not work so i changed the motor and still does the same thing so i figure something went wrong the speed control any ideas what it would be ?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 02-07-2013, 02:00 AM   #232
I've got a problem updating ESCs I need help with. I've been updating the software for our club racers on the Q Spark combos for a while now and probably have 30+ under my belt. Last weekend, I updated a few, 2 of which have become bricks. No lights or response of any kind when powered up.
I'm updating from Ver2.0 to Ver2.1 firmware. I cannot go back as the USB Link hardware and software do not store original versions of firmware. The Ver2.1 firmware cannot be reloaded, as the software won't allowed currently installed firmware to be overwritten by the same.
Any thoughts? Is the an archive of Ver2.0 firmware available someplace? Maybe I could find some X4 or X6 stuff, just as temporary filler?
Stab it and steer.
Old 02-07-2013, 03:57 PM   #233
Ladder Killer's Avatar
So is there a real big difference in the ORCA VX compared to the TEKIN RS PRO
( I know where you stood last weekend) http://www.MobileRCRacing.com
DiscountRCRacing - http://myworld.ebay.com/discountrcracing
Team Magic Parts, Kits and More www.machinaria.com
RC Apparel - http://www.bluegrooveapparel.com Globalhobby.com - XtM Racing Teamxtm.com
Ladder Killer is offline   Reply With Quote
Old 02-07-2013, 04:23 PM   #234
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Using the blinky mode there is not a difference in top speed. There is however a difference in feel, smoothness and especially mid range. The Orca is super easy to drive with which, for me, yields better lap times. The throttle is much smoother than a tekin and offers more of a mid range with rip. Its super easy to adjust without using a computer or flashing lights through the use of a program box or card.
Hope this helps.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-07-2013, 04:28 PM   #235
Bigz84's Avatar
Trader Rating: 17 (100%+)
Hope this helps.
EA
EA,
what settings did you have on your Orca w/ your 17.5 Touring?
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 02-08-2013, 03:03 AM   #236
anyone help with performance on the following set up, just after a bit more performance.
orca vx with team dynamite platinum motor 13.5 boosted
Motor timing at 25 degrees
timing start - 10%
timing - 33
Turbo delay 0.02
Turbo timing - 58
all intervals at normal
Nathan Wilson is offline   Reply With Quote
Old 02-08-2013, 07:04 AM   #237
Team EAM
Originally Posted by Bigz84 View Post
EA,
Punch 10
PWM 4K
BPWM 1K
Initial brake 5
Drag brake 3
Neutral width 5%
EA
Contact Us
Old 02-08-2013, 08:43 AM   #238
timing start - 10%
timing - 33
Turbo delay 0.02
Turbo timing - 58
What version of the software are you using? What FDR have you been using with this setup?
When you say you are after a bit more performance - are you looking for top end, bottom end?
Regards,
Ian
Old 02-08-2013, 10:13 AM   #239
Regards,
Ian
using the latest software v3 i think? currently running 8 FDR, small indoor track.
looking for a bit of both, i know this isn't logical but surely each motor has its sweet spot/power band
Old 02-08-2013, 11:35 AM   #240
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
sounds like the sensor port voltage as dropped
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
