Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree11Likes
Old 02-21-2012, 09:24 PM   #151
monkeyracing's Avatar
Hi, I'm trying to find out the bearing size in the Orca Q Spark combos with the Hobbywing style ribbed motor. (380 motor in a 540 sized can)
I think they're either 1/8"x3/8"x5/32" or 3x10x4mm.
Anyone know this one?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-22-2012, 04:25 AM   #152
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by jake95 View Post
Will give it a try thanks what fdr you run
timing: 9
Turbo: 30
Turbo Delay: off
Turbo Interval: 3
PWM: 32k
BF: 1k
Drag Brake: 4
Initial Brake 4
fdr 9 9.5
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-22-2012, 09:45 AM   #153
Ariel Reds's Avatar
hello there
can anyone suggest me ESC orca MKII 2.1 settings? im looking for smoothness, not punchy. combo with orca RX2 10.5t motor.
i'm play at pretty big track, highspeed with tactical flow and my currebt FDR is 5.9 but still punchy. Im looking for great top end but at the same time not lose the power at tactical, can someone suggest the esc setup?
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-22-2012, 11:10 AM   #154
macdude's Avatar
Originally Posted by Ariel Reds View Post
hello there
Based on your gearing I would start with
1.Timing 0
2.Turbo Delay .1
3.Turbo Timing 32 .
4.Turbo Interval 4
5.Punch 2
6.PWM 64
7.Drag Brake 0 This really depends on how you like to drive
8.Initial Brake 4
9.Brake Frequency 1.1
Obviously you will need to drive the car to see if you are happy with its performance. But this should give you a really smooth car, with tons of top speed. If it is still not fast enough just raise the turbo timing, if you are still accelerating before you reach the end of the straight you can lower the turbo interval to make the timing come on harder.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 02-22-2012, 12:30 PM   #155
Ariel Reds's Avatar
1.Timing 0
2.Turbo Delay .1
3.Turbo Timing 32 .
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
okay thanks, i will try out this setup!
Old 02-23-2012, 07:42 AM   #156
Ariel Reds's Avatar
1.Timing 0
2.Turbo Delay .1
3.Turbo Timing 32 .
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
after few packs of battery, i admit that this setup really smooth, but i didnt get the top power, it seems the power didnt come in, what should i increase or decrease?
and 1 more, what happen if i increase the timing?
regards,
Aril
Old 02-23-2012, 10:58 AM   #157
macdude's Avatar
regards,
Aril
Timing is like adding endbell timing. It is applied to the motor throughout the RPM band. I don't like using it except for stock motors. If you add timing the motor temps will increase, you might get some more top speed but it always makes the motor feel softer in the bottom. If you think you need a little more then start at the first setting and watch your motor temps.
If you want more top speed. I would increase your turbo, up one adjustment at a time until you are reaching a good top speed. You can also make the turbo come on harder if you lower the timing interval. Or if you want it to start a little sooner you can lower the turbo delay to .05. or to Off. I only use the Off setting on small tracks. Try this and see if it is better.
1.Timing 0
2.Turbo Delay .1 If you want more push sooner decrease this to .05
3.Turbo Timing 40 .Change this first, check temps. This will give you more top speed. If everything else feels alright but you are still not fast enough just keep increasing this until you get to the speed you need.
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
If you are still not fast enough try these settings Adding a little timing may help push the 10.5 harder. I would definitely keep an eye on temps though.
1.Timing 12
2.Turbo Delay .1
3.Turbo Timing 40 .
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
Old 02-23-2012, 11:06 AM   #158
Ariel Reds's Avatar
1.Timing 0
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
1.Timing 12
2.Turbo Delay .1
3.Turbo Timing 40 .
4.Turbo Interval 4
5.Punch 2
6.PWM 64
8.Initial Brake 4
wow! great tips and briefing there! thanks dude! i will try out this setup, fyi, last setup that you suggested to me, really smooth, run about 8 min and the temp keep below the 50C or less
will give some feedback
Old 02-29-2012, 06:12 AM   #159
liteweight's Avatar
Anyone have picture of Orca esc on Xray T3 2012? Cant figure it out for position
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 03-02-2012, 09:11 AM   #160
Craig W's Avatar
http://alexanderhagberg.com/R1GP/slides/107_0525.html
not best picture in the world
Old 03-02-2012, 09:12 AM   #161
Craig W's Avatar
hi guys
i was wondering if orca back on the raor list as our race season starts in april
Old 03-02-2012, 09:46 AM   #162
hello there
I have tried the following setting on software version VTC 111118.
Timing: 15-21deg
Turbo delay: 0
Turbo Timing: 52-56deg
Turbo Interval: 4-6
Punch: 8
PWM: 32K
Drag Brake: Personal Preference
Initial Brake: Personal Preference
FDR: 6.5-7.0
Motor Endbell Timing: +1-2 notches (Counter clockwise)
I believe this should work well on a big track. As for punchy feeling. I would try to have a different ratio. But running a higher ratio(Lower number) would require you to decrease the Timing and Turbo Timing. Increasing the Turbo Interval would also smooth out the throttle feel.
Hope the above helps.
newb1 is offline   Reply With Quote
Old 03-02-2012, 10:24 AM   #163
locked's Avatar
Yep. I changed a couple of things, slightly, since I took this picture.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-02-2012, 12:15 PM   #164
Hey guys, does anyone happen to know what sort of things get changed during a firmware update on an ESC? Just updated my Spark ESC, but Orca's a touch short on documentation. Thanks.
Stab it and steer.
Old 03-02-2012, 01:05 PM   #165
Ariel Reds's Avatar
Timing: 15-21deg
Turbo delay: 0
Turbo Interval: 4-6
Punch: 8
PWM: 32K
FDR: 6.5-7.0
Thanks for the setup! This is my settings that i found so smooth and nice
Timing: 3-6 deg
Turbo delay: 0.05
Turbo Timing: 48-56deg (depends on your style)
Turbo Interval: 7-8
Punch: 1-3 (i found out that it makes the tyre less spin, thus make the car easy to drive)
PWM: 64K
FDR: 5.8-6.0
Can someone test it and give your feedback? thanks
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 10:04 PM
