Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-24-2012, 03:50 PM   #136
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by JonboyGB View Post
Hi all, does anyone have a really good setup for the ORCA VRITRA VTC PRO MK1 esc, GM2012 13.5 motor on a high grip carpet track - 30m x 16m. Usually quite twisty with one straight running the full length.
An idea on FDR would also be cool
you could give setting in post 125 a try frd 6.66 to 7,4
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-25-2012, 04:43 AM   #137
JonboyGB's Avatar
Thanks Craig I'll give that a go.
This is what I'm currently using, but I must admit, I'm not clear on what does what, as this was a friends setup. How would the setup on note 125 perform differently to this setup?...
Timing: 39
Turbo delay: 0.05
Turbo timing: 58
Turbo interval: 1
Punch:10
PWM: 4k
Drag brake: off
Initial brake: off
Brake freq: 1.4 kHz
Thanks.
JonboyGB is offline   Reply With Quote
Old 01-25-2012, 05:41 AM   #138
Craig W's Avatar
Timing: 39
Turbo delay: 0.05
Turbo timing: 58
Turbo interval: 1
Punch:10
PWM: 4k
Drag brake: off
Initial brake: off
Brake freq: 1.4 kHz
Thanks.
Timing: 30
Turbo delay: off
Turbo timing: 44
Turbo interval: 2
Punch:10
PWM: 32k
Drag brake: off
Initial brake: off
Brake freq: 1.4 kHz
try this as im still learning the esc
Old 01-25-2012, 07:32 AM   #139
macdude's Avatar
Originally Posted by Craig W View Post
Timing: 30
Turbo delay: off
Turbo timing: 44
Turbo interval: 2
Punch:10
PWM: 32k
Drag brake: off
Initial brake: off
Brake freq: 1.4 kHz
On a tight infield track I would not set the turbo delay to off. This will add turbo timing as soon as the esc sees full throttle. In most instances this will cause a corner overshoot as the power comes on hard. I would all a .1 or .2 second delay as turbo is really only for longer straights. I agree with the drive frequency as for the timing interval I would adjust it so that you are maxing out (top speed) by the end of the straight. If you are not getting to top speed by the end of the straight then decrease timing interval or back off the turbo timing if you are not then increase turbo. The other settings seem fine to me. Personally I like a lot of drag brake so this is just a personal thing.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 01-25-2012, 08:13 AM   #140
JonboyGB's Avatar
Hi, what do you mean by 'drive frequency'? Is this the PWM thing?
Old 01-25-2012, 11:13 AM   #141
macdude's Avatar
Yes. PWM is drive frequency. It is listed in KHz.
Here is link to the manual that explains all the functions of the ESC
This should help you figure out what each setting does.
Old 02-08-2012, 10:38 PM   #142
Default Orca Q Spark
I just bought 2 Orca Q Spark 17.5t Combo Sets. One of the sets has lag in throttle operations when it's turned on. Also, the green blinking light blinks slower than the other one when in profile 1.
Can anyone advise. Thanks.
caiping is offline   Reply With Quote
Old 02-09-2012, 04:57 AM   #143
Trader Rating: 19 (100%+)
Alexander Hagberg joins ORCA
Great addition for ORCA!
http://www.redrc.net/2012/02/alexand...ntent=FaceBook
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 02-16-2012, 02:05 AM   #144
jake95's Avatar
Trader Rating: 27 (100%+)
hi guys i was wondering if you guys had any good setups for mod with the vritra mk2 using a speed passion v3 4.5t.I run mostly on medium size tracks.
thanks,
jake
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 02-16-2012, 05:30 AM   #145
thanks,
jake
Ping ADHSponser for the mod setups.
TEAMORCA.SHOP
Old 02-16-2012, 06:34 AM   #146
Any news on the upcoming 1S speedo?
JamesL_71 is offline   Reply With Quote
Old 02-16-2012, 08:26 AM   #147
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
While I am not associated with ORCA, Alexander Hagberg spent a week with me at my track testing before the birds and running the ORCA prototypes. His car was fast and the throttle was very smooth and linear. He said that he had heard they hoped to have them out sometime in the next 2 months but hasnt heard anything official yet. His were still prototype units.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 02-16-2012, 12:19 PM   #148
jake95's Avatar
Thanks mark
XRAY✯NOSRAM✯SANWA
Old 02-16-2012, 02:14 PM   #149
Craig W's Avatar
thanks,
jake
iming: 22
Turbo: 44
Turbo Delay: off
Turbo Interval: 2
PWM: 32k
BF: 1k
Drag Brake: 6
Initial Brake: 4
some thing like that i tink
Old 02-16-2012, 08:48 PM   #150
jake95's Avatar
Will give it a try thanks what fdr you run
XRAY✯NOSRAM✯SANWA
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 09:04 PM
