Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree57Likes
Old 05-15-2014, 04:32 AM   #106
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey Guys,
With all the motors that have gone out, I just wanted to give some info about the numbers and settings.
On the header card you'll see a list of numbers:
21.8/.9r 12.50mm 1400/1408g
stator resistance, rotor diameter, rotor strength (N&S)
Numbers will vary from machine to machine.
Timing wise (starting points):
SC = 15*
Buggy = 25*
TC = 30*
1/12 = 20/25*
Rotors :
SC = 12.50mm 1550+
Buggy = 12.30 or 12.50mm 1350-1450g range
TC = 12.50mm 1400-1600g
1/12 = 12.30 or 12.50mm 1350-1450
These rotors and timing settings are baseline starting points.
I'm sure there are some instances where you may need a bit stronger rotor or a change in timing, but these setting should get you close
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 05-15-2014, 05:27 AM   #107
Trader Rating: 74 (99%+)
Originally Posted by sg1 View Post
Hey Guys,
SC = 15*
Buggy = 25*
TC = 30*
1/12 = 20/25*
Rotors :
SC = 12.50mm 1550+
hm dont know another company that posts their motors numbers, rotor numbers, and starting points for their motors. Definitely the best customer service I've ever seen!!!! Also a fantastic product. Hauls my touring car around the track faster than the rest haha!
thecaptain is offline   Reply With Quote
Old 05-15-2014, 08:52 AM   #108
That's some great info and definitely great customer service.
Bobbyb84 is offline   Reply With Quote
Old 05-16-2014, 06:08 PM   #109
I'm trying to discharge my TeamScream AAA batteries using a Compettion Electronics Turbo35 charger and was wondering what the cut off voltage should be set to. I tried 3.6v (.90v per cell) but it's not working. What should I be setting the charger to?
outlandr91 is offline   Reply With Quote
Old 05-19-2014, 04:40 AM   #110
sg1
sg1's Avatar
The GFX will not go down low enough to discharge.
You need to be at a 3A discharge rate.
At 10A (min. GFX) I don't think you'll see anything, the discharge would be done so quickly.
Old 05-20-2014, 03:14 PM   #111
Bummer, I was hoping to use the charger to discharge the batts but it looks like I'll have rig up something else.
Thanks for replying.
Old 05-27-2014, 05:33 AM   #112
sg1
sg1's Avatar
Next shipment of motors are due tomorrow!!
Also some 21.5's for testing
If you ordered stuff over the weekend it will be a few days before I can get through everything and have stuff sent out
Old 05-27-2014, 03:38 PM   #113
I have had this 17.5 motor for my RC10T4.2 for about a month and keep pushing it limits and finally have great results at our indoor clay track (ocrc). Final gearing is 78 spur/32 pinion, 30 timing. The timing evolved just as I read before, I had it at 42 and backed off to 30 and wow that was a bullseye. The truck performs better than most in the stock class and comes off the track at about 120 temp. I think there is still more room for a larger pinion. Great motor, form what I've seen here locally I have a winner except for my driving. Thanks Team Scream.
bladeys is offline   Reply With Quote
Old 05-27-2014, 03:58 PM   #114
sg1
sg1's Avatar
Glad you found a sweet spot you like!
Feedback we've received is even less timing.
Applying 8.4v input to that motor on the dyno with the rotor you are using and at 30* of endbell timing is over 2,000 more RPM then a D3.5 with 28* endbell timing with a stock 12.3 rotor.
Just for giggles try just a little less timing (4-6*) and leave the gearing. If it feels a bit slower on the top end drop the spur gear
Old 05-29-2014, 12:58 PM   #115
sg1
sg1's Avatar
All orders went out today!
Motors are back in stock... come get some!
21.5's are being tested this weekend
Old 05-29-2014, 02:08 PM   #116
gazza's Avatar
How should I gear the 17.5 for TC compared to an Orca or D3.5?
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC˛ Racing, Hobbywing North America
gazza is offline   Reply With Quote
Old 05-29-2014, 02:27 PM   #117
sg1
sg1's Avatar
With 30* endbell timing on a 90 x 40 track thats high bite and a few spots where you use push breaks we were at 48-96 with a 1.9 internal.
If you're on approx. that size but flowing, go 50-96.
Old 05-29-2014, 03:49 PM   #118
gazza's Avatar
How about on a 140x50 flowing asphalt layout?
Old 05-29-2014, 04:10 PM   #119
sg1
sg1's Avatar
Start with 50-96 @ 30*
You may end up a tooth or 2 lower at 35-38* timing.
More timing will generate alot more heat, but will pull hard down the longer straight and flowing infield.
Keep an eye on temps
Old 05-29-2014, 04:19 PM   #120
gazza's Avatar
Cool deal. Will post results after trying those recommendations
