Two2cool Products 2009-2009
Two2cool Just released a New Front end design for 1/10 and 1/12th scale pan cars. It bolts up to conventional USA Standard chassis mounting but uses the Newer style geometry.
you can checkit out at www.T2CRC.com Black Mamba Front suspension
Any Question please send ask here.
Conversion Kits Include
(2) Machined 6061-T6 Bulkheads with conventional standard chassis mount spacing and 8-32 screws
(2) Machined 6061-T6 Caster Blocks
(2) Machined Delrin Upper Suspension Arms
(2) Upper Hinge Pins ASTM Steel
(4) Machined 6061-T6 T Nuts with 4-40 UNC Standard Threads
(2) AE R5 Lower Arms #4620
Parts needed from you old style front end
(2) Upper Pivot Eyelets
(4) Pivot Balls
(2) Upper Turn buckles
(2) Inline Spindle Blocks
(2) 1.4 -1.5 King Pins
(2) Front springs
Misc spring cups and e clips
If you plan of adjusting the Track Width you will be required to purchase a .700 upper turn buckle and and Longer 4-40 screws to space either the caster block or lower arms out from the Bulkeads.
Adjustable Advantages:
Track Width
Wheel Base or lead or trail of front wheels up to .200
(4) Pivot Balls
(2) Front springs
Track Width
looking for drivers to work with us and devlop new products. please send us an email at
[email protected]
[email protected]
Interesting looking front suspension...e-mail sent
you should have it! thanks for the order, I responded to all PM's this is really a great front end. we have really done well with this design.
here is some useful info for those that are using this front suspension. it will help you tune better, please keep in mind that the travel is .200 the average car travel about half that amount.
http://www.youtube.com/watch?v=ylJUcJE562E
We are releasing a 1/12th scale version of the Black Mamba Front suspension this month!
