BMI Racing Discussions
#1292
protc3 1 quest for ya YGPM
#1295
Hi everyone:
Jay:
Can't wait to see it......... it's gotta be trick. so you can get a good laugh. I was shoveling that white stuff when a county plow came by.......... one 6' snow man.......... and tonight when I got out (YES another 8 hr night) all the lights were shining up like pillars everywhere... -3 was the temp in my truck. it looked kinda cool..... I'll call today. more Q's for ya.
Wannabe:
Hi,
I am in need of a radio box for my new KO radio. (Helios EX10) with the steering wheel drop down.it JUSt barely fits in a T3 box with the bottom foam from the stock box. if you have any ideas please let me know. Mini wants this one kept safe.... really safe along with the backup thats coming soon.
pm me or e mail me.
BTW:........................I HATE SNOW
Jay:
Wannabe:
Hi,
pm me or e mail me.
#1296
Hello,
I was wondering if there was any word on the BMI Chassis coming with the anodized aluminum parts? How much longer?
Joe
Joe
#1299
Hi,
I thought I'd post our setup for carpet.
Front
Springs: white
Oil: 60wt assoc
Pistons #2's
Caster blocks: 4* assoc/losi steeing knuckles
front block: F-0
shock mounting: lower outer hole on arm, middle hole on a rear shock tower mounted up front. (I cut off the outer most hole).
camber link: lower inner on shock tower.
Sway bar: either a .078 or a .062 up front (depending on bite).
Tires: Jaco double Pink/Orange or Purple/Orange.
Rear:
Springs: Purple or copper (depending on bite)
Oil: 50wt Assoc
Pistons: #2's
Rear toe in: either the "R" block with the R+2+0 or the "F" block with the R+3+0 block. (I shim up the "F" block with 2 motor washers per side).
Rear Hubs: Losi 0* hubs.
Camber link: upper inner hole on hte shock tower and the inner hole on the hub carrier.
Sway Bar: none
Tires: Jaco double pinks or purples.
Camber: 1.5* all around. (less up front if the tires are coning)
Batteries: forward.
Motor: either a Monster stock or a MVP
Tire size: 2.360 (new Jaco rims) 2.3 (old rims)
Elecronics: GT7 speedo, (#4setting) XXTra Rx, JR 8714 servo, and a personal transponder mounted on the servo.
Body: Losi Alfa. slammed or a Startus (old one).
hope this helps.
the only change we made was to go to 70wt Assoc up front for Cleveland and we ran a 2.0 Stratus.
we went back to the Alfa this weekend
and Jaco dpuble pinks and double pink/orange for tires.
hope this helps
Front
Springs: white
Oil: 60wt assoc
Pistons #2's
front block: F-0
Rear:
Oil: 50wt Assoc
Pistons: #2's
Sway Bar: none
Batteries: forward.
hope this helps.
hope this helps
#1300
Originally posted by TimXLB
Hi everyone:
Jay:
Wannabe:
Hi,
pm me or e mail me.
Hi everyone:
Jay:
Wannabe:
Hi,
pm me or e mail me.
#1301
TC3 BMI test
hi there
Just wanted to let you know we now have a BMI TC3 chassis test online at www.overrc.com thanks to them!!!
It s in french but nothing a little babelfish can t fix...
It says basically that it s a fantastically well finished chassis...very accessible..and of top quality.. i should know..i wrote the review
#1302
#1303
it's possable just does not last that long thanks to the snow machines
#1304
Originally posted by jcrouse
Amen brotha. No actually I like the snow, just not the cold. Is it possible for it to snow when it's like 45 or 50 degrees. That would be ok.
