BMI Racing Discussions
#9841
Originally Posted by Killa G
Sweet Thanks!
Tim
#9847
Originally Posted by Tim Stamper
This is what 2 of the BMI T2's were running. It's almost a carbon copy of Baker's mod setup.
Tim
Tim
#9848
Originally Posted by protc3
for mod i run
Front:
1.5 degrees of camber
.020 front springs with 5000 wt diff oil on the king pins
10 degree castor blocks 1 shim front and rear of arm
4mm ride height front
0mm front uptravel
TRC double pink wraps cut to 1.750
flanged bearing on inside of wheel and non flanged outside(for track width)
Rear:
.063 Tplate
5000 wt. oil in washers
25 wt. losi shock oil w/ olive spring
1mm of uptravel for pod droop
TRC double pink wraps cut to 1.85
track width 168mm
4.5mm ride height
batteries full back position
parma speed 8 body
i sauce the full rear tire and inside 1/2 of front with paragon ground effects.i soak it in for 15 minutes,then i put tire tweak on top until the race.wipe it off real good and you should be set.
Front:
0mm front uptravel
Rear:
.063 Tplate
track width 168mm
4.5mm ride height
parma speed 8 body
how do you measure your uptravel on 1/12 fr and rear?
#9849
i check it with a ride height guage in the rear.in the front i just make sure there is no sag in the front by the steering knuckles.i shim them with about .010 of preload on the springs.for the rear droop,i set my car at ride height and lift the rear by the ball stud on the upper pod plate until the shock stops it from lifting.i measure this by using the ride height guage and checking the lift over ride height.
#9850
I was wondering if I could get a price for a set of new mi2 shock towers. I would prefer a front tower that is sloted. Thanks.
#9851
#9853
Tech Legend
Trader Rating: 51 (100%+)
Hey Tim hows everything going? Still doing the go cart stuff?
#9854
Wyd;
Hi,
We had to quit Karting do to my health problems. it was hard to give it up but we had to. now we just race R/C cars
and Mini is into imports right now. he has a sleeper sitting in our little garage that he's working on.
how've you been??? still racing???
Hi,
#9855
Tech Legend
Hiy Tim,
Sorry to hear about the carts but good thing you still can race R/C's together and work on the import some.
I just started to race some touring again. IT has been alot more fun this time around as I'm not doing the buy a new car every other week thing. Next new car will be when Schumacher has their new car done in a couple months. Started racing at are local indoor asphalt track. It was greeat to get back to racing and hanging with my friends again. ALso nice to get back on Tech a little more than I was for last couple of months to. Missed reading the posts that this site offers.
