BMI Racing Discussions
#602
Hey John C you missed the nerve so chill out I am just messing around. I suck at driving too and there is a miss print In the 1/12 A mains I was 6th and Dave was 7th so relax iam just funenn with you.
#603
#604
Team EAM
Originally posted by Fakk2
Eric A:
Hi,
here's our base setup for carpet
I thought I'd post our setup for carpet.
Front
Springs: white
Oil: 60wt assoc
Pistons #2's
Caster blocks: 4* assoc/losi steeing knuckles
front block: F-0
shock mounting: lower outer hole on arm, middle hole on a rear shock tower mounted up front. (I cut off the outer most hole).
camber link: lower inner on shock tower.
Sway bar: either a .078 or a .062 up front (depending on bite).
Tires: Jaco double Pink/Orange or Purple/Orange.
Rear:
Springs: Purple or copper (depending on bite)
Oil: 50wt Assoc
Pistons: #2's
Rear toe in: either the "R" block with the R+2+0 or the "F" block with the R+3+0 block. (I shim up the "F" block with 2 motor washers per side).
Rear Hubs: Losi 0* hubs.
Camber link: upper inner hole on hte shock tower and the inner hole on the hub carrier.
Sway Bar: none
Tires: Jaco double pinks or purples.
Camber: 1.5* all around. (less up front if the tires are coning)
Batteries: forward.
Motor: either a Monster stock or a MVP
Tire size: 2.360 (new Jaco rims) 2.3 (old rims)
Elecronics: GT7 speedo, (#4setting) XXTra Rx, JR 8714 servo, and a personal transponder mounted on the servo.
Body: Losi Alfa. slammed or a Startus (old one).
hope this helps.
the only change we made was to go to 70wt Assoc up front for Cleveland and we ran a 2.0 Stratus.
we went back to the Alfa this weekend
and Jaco dpuble pinks and double pink/orange for tires.
Eric A:
Hi,
Front
Springs: white
Oil: 60wt assoc
Pistons #2's
front block: F-0
Rear:
Oil: 50wt Assoc
Pistons: #2's
Sway Bar: none
Batteries: forward.
hope this helps.
For you guys running carpet a bunch is there anything else you could think I might need to add to a Factory team kit? I havent run a tc3 since they came out. Just wanna build it right the first time!!
ea
#605
Who makes the K- Factory steering unit and where can I get one?
#606
http://www.sslorder.com/speedtechrc/1.html
#607
Thanks Fasttrak
#608
hey guys,i want to make an announcement.BMI Racing chassis kit is now going to have perfect ackerman with the nitro steering rack.thanks to tim and BMW who have been working hand and hand with me on this accomplishment.the way that the rack is mounted on all of the aftermarket chassis has no ackerman which scrubs speed through the corners.now with the new placement,you have perfect ackerman with the losi hubs or associated hubs.thanks to everyone involved in this.i am proud of all of you guys.
#609
Sweet! YGM
#612
mark.
#613
Thanks!
#615
hey boomer.how have you been?your nitro chassis still working for ya?
you are exactly right about the ackerman.the nitro steering rack was designed to fit the nitro car.for perfect ackerman on the nitro car you need to use the front position on the steering hub for the ball end and tie rod.the electric car does not offer that position.in order to achieve the right ackerman on the electric car you have to mount the rack in the right place.we found it.
