BMI Racing Discussions
#317
after alot of working with the 2 types of carbon fiber(colored and standard black)i found the black to be ever so slightly more stiff than the colored.it is extremely hard to tell the difference.if you get fine weave colored carbon fiber(not coarse weave)and have the carbon running in the right direction,it is extremely stiff.if you cut it against the grain(0 deg. layers)it flexes like mad.if you are not careful,you can make a messy ball of flex out of this thing.dont worry,i pay close attention to these details.hope that helps
#318
Hey Jason,once again on sunday the BMI car ran as close to perfect as I could ask for.......this week their was alot of top end competition in pro-stock due to everyone preparing for the regionals comming up in mid december.....After some bad luck breaking a steering knuckle in one of the tripple A mains (giving me about 15 deg of tow out) I still managed to take an overall fourth place......I was turning alot of low 16 sec lap times and even managed a few 16.0's which is a tie for the single fastest lap ever to be run in the class..........so the car is pretty dialed in after only a few sundays of racing.......as you asked earlier ,I'll post some of my setups for asfault with rubber tires.............Joe B
#319
Joe B
You have a PM....
#320
Do we have a roster yet of the BMI representatives for the Cleveland race? Let those who will attend raise their hand.
#321
i will not be attending the Cleveland race...the soonest race i will be attending will be Novak race in Milwaukee since Christmas is right around the corner...i have to get the g/f some good partying gifts ...maybe aTC3...she'd love that ...i might be attending the Snowbirds as well in a few months if all goes well
#322
Hi,
We will be at Cleveland. running stock sedan.
#323
I will not be in Cleveland First year being married, the wife won't let me slide this time. I will post the setup that I have been running on my milled out tub that I plan to run on my BMI. I'll get it up first thing in the am. Great for high bite fresh Ozite tracks. Should be good on the new chassis. Good luck to all. Especially all running BMI
#324
Here is the setup I currently run and will try on the BMI
Front
70wt
#2 pistons
yellow springs
rear tower on the front on the inside hole
inner hole on the arm
losi 4 degree hubs
losi knuckles
f+0 block
-2 camber
zero tow in
camber link long and high
droop... I dunno. I just adjusted for 3mm of down travel
5mm of ride height
rear
60wt
#2 pistons
out on the tower and arm
copper springs
camber on the tower high and inside
losi 1/2 degree hubs with camber on the inside hole
hubs spaced in the middle
front block in the rear
R 2+0 block
same thing as above on droop
-2 camber
5mm of ride height
Plaid front, purple rear (2.28 preffered size)
Protoform alfa with wing mounted forward
100 tooth spur
Batteries forward
1/2 ounce weight added to the motor side of the car
Front
70wt
#2 pistons
yellow springs
losi 4 degree hubs
losi knuckles
f+0 block
-2 camber
zero tow in
5mm of ride height
rear
60wt
#2 pistons
copper springs
R 2+0 block
-2 camber
5mm of ride height
100 tooth spur
Batteries forward
#326
LOL.. Sucka.. You better be buying a servo from me.
#327
And yes I'm sure you will whoop my a$$. Maybe I'll get lucky
#328
Originally posted by pimpedaccord
can I whoop your a$$ with your own setup this weekend?? I'll buy you a smokey dog.
You need to make sure your little side kick don't stay out drinking all night and ruin the chance to come down! LOL
See ya Sunday...
