BMI Racing Discussions
#2780
is there any way for carbon fiber to get charged with electrcity or something? Because my bmi car glitches like crazy all of the sudden. It started a few weeks ago just alittle. Then it messed me up in the A-Main at a state champs race. Now i put electronics in it and it goes nuts worse then ever. I tried different electronics, dif batterys, dif motors, dif servos. everything, nothing is touching 3 layers of servo tape. Everything, i put all this stuff in my b4, nothing, i put it in my xxx4, nothing. its just my bmi, my bmi is cursed and it sucks. any ideas?
#2782
jason,
Are you cutting xray shock towers yet. I was wondering about the factory team one for the rear and the lower carpet towers. Also I was wondering if you would make a change on the xray lower chassis so that the droop screws for the short arms will have a little more or the chassis to rest on. Also if youare going to route out the chassis near the bulkhead for the hindge pin retainers for the short arms. There are on the outside of the bulkhead and if you are using the lower hinge pin mounts, there is a problem with clearance.
thanks
thanks
#2784
red chassis
Jason,
hey I got my red chassis today and I gotta say the quality is simply amazing!!!
I"m a little bummed I won"t be racing it at the reedy,but I will be running it at La Mirada this sunday,I"ll let you know how well it performs.
thanks again,
Scott
thanks again,
Scott
#2787
glitching problems
make sure that the outsides of the shrink wrap on your batteries is not shaved away and touching the c/f.another thing you can check is that 1:you have caps on the motor and that if if you do they are not touching the chassis.if you still cant find it i would remove the electronics and just lay them on the chassis loose and move them around slowly and see if you can duplicate the problem.2:do you run your battery wires over or under the upper brace?if you run them under it,try running them over the upper brace.let me know if this helps buddy.
zip over here is 34604 buddy.
#2788
Xray Chassis
i am aware of the problem with the short arms on the kit.i will be releasing a new version that will accomodate all the changes that the xray has gone through including the new shock towers.i will keep you posted.
hey scott,im glad that you like your chassis kit buddy,post some pics when its ready.
