Fukuyama Batteries
#2401
Originally posted by wyd
Maj.Teeth I run more chargers and irons off my Honda 1000 gen so you should be ok. The compressor will use the most power, especially when you first turn it on. Might want to check all you chargers once you turn on the compressor as it might make them false peak.
Dan
#2402
Yo Maj, have you any 1.17s 6 cell at all?
thanks
Tarnjit
thanks
Tarnjit
#2403
thanks
Tarnjit
thanks
Tarnjit
We'll also be processing our cells on the newly revised CET2 system to allow some further enhancement on the cells we have now so there should be some as high as mid 1.17s. Still nothing in the high 1.179 range since we didn't want to push the cells and stress them.
Dan
#2404
1.17s and above
Guys, just for your information.
Please check back with me after Christmas for higher numbers as we've found a way to boost these new shorter can cells to increase slightly more on the voltage side and still average 400+ runtime. We're working overtime and have found a new method which these newer stubborn cells will take to increase its voltage.
Our CET2 system now is upgraded with a higher capacitance zap at a slightly higher voltage allowing it to enhance the core a little better. These cells after running this method will remain on par with the 2nd Generation GP that we all seemed to like voltage and IR wise. So, Please stay tuned!
Dan
Dan
#2405
Welcoming Team Driver!
Just wanted to officially welcome our 1st Off-Road Team Driver. Curtis May aka Curtdawg here in this forum. Expect to see him perform in the upcoming 2004 off-road races and bring home some trophies!
Welcome aboard Curt!
Dan
Dan
#2406
well i definetly want some cells for january , is their any realistic chance ill have some 1.17+ by then if i ordered sometime soon friend?
thanks alot
Tarnjit
thanks alot
Tarnjit
#2407
Dan, like you said, the cells perform great on the track so I have no need to send them back to you. I don't have an octane 2, but I do have a real time 2. I'll try cycling a pack twice with a 6 minute rest, I think the T35 uses a 30 second rest if you use the cycle feature.
Josh
Josh
#2408
ur numbers on my new cells
i know u got good batterys i got the the high 1.16 but i noticed each cell has diffent sec, such cell i got 2 cells at407 sec 2 at 408 1 cell at407 and 1 at 410, 2 pack at3 cell at 405 1 at 407 1 at405 1 at 408 sec i just want to know why there all diffrent like somes cell hve like 1.17 across all six cell i hope u understand thxs reggie
#2409
I don't think I've ever seen a six cell pack from ANY matcher with the EXACT same numbers for voltage, IR, AND run time. To do that I would think would be just about impossible. Each cell is going to have a little bit different profile than the next. I've seen some very close but not exact.
#2410
Fukuyama Racing
Thanks Dan
I'm looking forward to running for Fukuyama Racing.
Its gonna be a great adventure....
Curtis May
Curtis May
#2411
I just ordered my first pack of batteries, can't wait to get em.
#2412
Super Moderator
I can vouch for what Dan said about storing them, McLaren, I've had to let my 4 cel packs of GP3300's sit for as long as 4 or 5 months(when I just couldn't get my 1/12 scale to work on our local track), & I did what he said. And when I got a chance to run them again(on a carpet track a couple of hours drive away), they woke up just fine. And btw, my 4 cell packs are the oldest ones, first-generation cells(the ones that had that ugly lime-green shrink wrap, before they added all the multi-colored ones).....
#2413
Dan YGPM !
#2414
thanks alot
Tarnjit
thanks alot
Tarnjit
Dan
#2415
Dan
