Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-09-2008, 02:20 PM   #61
Regarding the Vortex 2008 Race BL Motors
Is it possible to get the kv rating for each of these motors? & some additional information about them, what size bearings, rotor size, etc...
Drift Demon is offline   Reply With Quote
Old 08-10-2008, 02:27 AM   #62
Born2Run's Avatar
I ran a new Orion 3800mAh 30C untill the cutoff point of 6.2v with a mamba max 7700 for 5.5min and on the second charge it tooks only 3250mAh.Whats going on?Are you sure these packs are 3800mAh rated at 30C? I don't think so.And the punch wasn't something special.Two things may be happening.Or your new 3800mAh 30C packs are misrated or i have a defective pack.Its very clear.
Whatever
Born2Run is offline   Reply With Quote
Old 08-10-2008, 09:29 AM   #63
RC MARKET's Avatar
I'm used 4 or 4.5T feel volt drop ,
after next day charge had 37xx mAh
& don't 6.2V cut off !
choice 6.3-6.4 V cutoff bester !
if per cell had try under 3V , you battery will lose some punch !
& I'm use 4 T in small track had 11mins
4T in big track had 6 mins , car speed faster than GP car !
RC MARKET is offline   Reply With Quote
Old 08-10-2008, 09:55 AM   #64
FOXY923's Avatar
I'm not really sure you can say it's not a 3800 pack. The voltage cutoff of 3v/cell doesn't take the pack right down to 0mAh. So when you charge it it won't take a full 3800mAh cause there is still some in the pack. Am I wrong? Lipos are different then NiMh, we have to remember this. We charge Lipo with the CC/CV. Once the 8.4v is reached the charger will maintain that until finished. Where as the NiMh would keep going, thus putting in more that the rated mAh.
Please correct me if I'm wrong.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 08-10-2008, 10:15 AM   #65
SWTour's Avatar
I don't remember where, but I read somewhere that most lipo batteries shouldn't be discharged past about 80% of the mAh rating. 3250 on a 3800 would be about 85%.
If you ran a true 5.5 minutes (330 seconds) that would mean you were averaging approx a 35.4 amp load for those 5.5 minutes (If my calculations are right) which would mean a pull of probably 65-70 (or more) amps from a STOP.
The LIPO Cutoff will kick in because of the AMP load pulling the LOADED Voltage down, moreso than the actual voltage of the pack.
( if the car shuts down w/ the LIPO CUTOFF...wait until it resets...then roll slowly in the throttle w/o creating the HIGH load off the line) Or if you want MORE RUN - set the throttle settings to NOT allow the HARD AMPLOAD starts.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 08-10-2008, 11:40 AM   #66
Born2Run's Avatar
Guys it's not the lipo cutoff.The car slow down after 5 mins run and so i have to stop on 5.5mins because is useless to continue.I know the voltage cutoff of 3v/cell doesn't take the pack right down to 0mAh and that always some current remains on the battery.But here we're talking for 550mAh.As i said punch wasn't something special for a 30C pack.From the other side i have some 4 months old Yeah Racing 3200 20C packs,very punchy and am getting 5.5-6 mins runtime with the same cutoff point and when i recharge them they're getting 3300mAh without being overgharged.They are only 3200mAh 20C and i paid for them 34.00$ not 90.00$ as i paid for the Orion.Hard to say but im completly disappointed from Orion.
Whatever
Old 08-12-2008, 11:54 PM   #67
Born2Run's Avatar
No reply on this post?
Whatever
Old 08-13-2008, 09:08 AM   #68
POUNDITRACING's Avatar
I have no idea on the Kv rating but I will measure tonight.
Can you make a list of the things you want me to measure?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 08-17-2008, 08:19 PM   #69
Trader Rating: 17 (100%+)
I'm looking for batteries for my Losi Type R but I can't find and size/dimensions on the Teamorion website. I would like to know the 3600 & 3800.
Thanks.
seabass2500 is offline   Reply With Quote
Old 08-17-2008, 08:43 PM   #70
Yeti35's Avatar
Thanks.
I don't work for Orion but I can tell you neither of those packs will fit in the Type R. I was going to borrow some packs for my cars for IIC and tried to put one in. The pack rubs both pulleys on the lay shaft and will not go all the way in. Some went to the extreme of grinding the pulleys to make it fit but I am not willing to go that route since there are other options out there that are a direct fit. I don't feel modifying the car is a viable option to use a battery pack.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 08-18-2008, 12:07 PM   #71
Tubaboy's Avatar
One of my Orion 3200's fails when I attempt to charge it on a balancer. Anybody know how I can fix this issue? It's only been raced a handful of times, and this past weekend went on the charger and didn't peak for 2+ hours, and when I put it on the track, it hit the 6V cutoff after 2.5 minutes of racing.
Thanks,
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 08-20-2008, 12:55 AM   #72
Born2Run's Avatar
So far no answers to this post.Very professional from Orion's part
Whatever
Old 08-20-2008, 04:57 AM   #73
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
ORI28109 - Vortex BL 10.5>>>>>is this 10.5 b/less motor capable enough to run with the SP 10.5 / Novak 10.5 assuming gear ratios are kept in check? what needs to be done if its to keep up with the SP/Novak 10.5s? thanks.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 08-20-2008, 07:26 AM   #74
nc-hopsing's Avatar
Joe has been very busy with races this past couple of weeks. He does race too and also has to take care of the team orders as well. Sorry we couldnt get you the info needed right away. As soon as its available, we'll get it up on here.
Steve Butts
KYOSHO AMERICA.com -Peakmotors.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net
nc-hopsing is offline   Reply With Quote
Old 08-20-2008, 08:19 AM   #75
Joe Pillars's Avatar
Sorry for the delayed response. We were at the ROAR Off-Road Nats all last week.
The rotor size that comes in the motors right now is 12.2mm We will be offering other rotor sizes very soon.
The bearing size is: OD-12.7mm ID-4.7mm Width-5mm
Hope this helps!
Kyosho America, Team Orion, Peak Racing, AKA, KO Propo, DiBrino Designs, JTP, RCE, Rockstar Energy Drink, www.thebigrc.com, Portland R/C Raceway (www.prcr1.blogspot.com)
Joe Pillars is offline   Reply With Quote
Team Orion Lipo/Nimh Charger and Team Orion SBS Lipo Balancer birdy233 R/C Items: For Sale/Trade 11 07-09-2008 06:44 PM
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
Kyosho 1/8 Suzuki Motorcycle With Team Orion Coreless Motor And Team Orion Flash Esc hpidriver R/C Items: For Sale/Trade 3 07-04-2003 06:56 PM
