Just placed an order for an IP 3800 lipo and 17.5 duo. Running Novak now... just throw it in and go or should I gear a little differently?... timing?.... this is for carpet/rubber tire. This is my first deviation from Novak's brushless motors.... I'm excited to try something different.
Hey guys....i just ordered the Duo 13.5 How is the gearing compared to the novak 13.5? I will be running Foam on carpet
TEAM HIGH VELOCITY RACING
www.highvelocityracing.com
MLP Team Driver
NEXUS RACING
MLP Viper F1 Pro, Xray T2 '008 EU & '009 US SPEC, KYOSHO HOR, RC18B
with the trinity motors, I have seen most guys gear these way higher then the novaks, try what you normaly run then go up a tooth from there and so on and check the temp of it..
and as far as timing I leave them at the most timing option, that way you guys can start there. I recommend just going to the middle hole right off the bat to most though, and if you guys want more torque from that point, increase the timing all the way..
maybe I can get maybell to chime in on his opinions,he runs carpet, He can give you a better idea for gearing and etc...
Right now I am geared at a 4.7 on my Novak. When I get my HV Duo I was thinking that I would just start from there and gear up or down. Or do you think I should start at a higher FDR like 5.0-5.2?
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Nexus Racing | Jconcepts | KO Propo | Team Associated TC5 | Kyosho RB5
start at a 5.2 and go from there. I'm sure you will be gearing up
MLP Team Driver
NEXUS RACING
Anytime man glad to see you aboard and welcome to the team
Yeah i will be at nexus trying to get my roar membership now(having issues with paypal) I will be running my VTA and my TC Foam
MLP Team Driver
NEXUS RACING
I wouldnt say that I am a gearing guru but with the HV Duo motors I definately gear higher than most motors...For example most guys are gearing a rubber TC 5.0-5.1 at Seattle Indoor Raceway in 13.5....I am geared 4.8-4.9 with my 13.5 and I have great rip at 150 deg!
Sean Maybell
Team Associated - High Velocity - JConcepts - LRP - Reedy - Factory Team - XP Digital - PPD Billet - Remote Control Hobbies
thanks maybell that will help me to get a starting point
MLP Team Driver
NEXUS RACING
Thanks for chiming in on that maybell. I knew you could give a better answer on that then I could..
