Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-01-2011, 04:31 PM   #1051
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Originally Posted by The MurfDogg View Post
MurfDogg Racing is proud to announce that we will be sponsoring the 2011 IIC race in Las Vegas! We will have our own team pitting area as well as a display of our latest products. If you will be attending IIC this year, please stop by and say hey!
See you guys soon!
I know I cant wait to race WGT at IIC this year!
That's great news! I don't run on-road but I can drink and gamble real good.
Cameron Kellogg is offline   Reply With Quote
Old 09-01-2011, 08:49 PM   #1052
The MurfDogg's Avatar
Perfect, get out to Vegas and party in the MurfDogg pits!
Matt "The MurfDogg" Murphy
MurfDogg Racing - www.MurfDogg.com- ROAR National Champions!
Brushless Racing Motors - Li-Po Racing Batteries - Aftermarket Accessories
Luxury Dirt Oval Racing Chassis and Performance Accessories
The MurfDogg is offline   Reply With Quote
Old 09-03-2011, 05:05 AM   #1053
Trader Rating: 27 (100%+)
hey guys, can someone pm me the email to order a motor? is it the same as the website?
hondafixer is offline   Reply With Quote
Old 09-04-2011, 10:28 AM   #1054
For those using Murfdogg motors in the Asc TC6... are offset spur gears required(ie: Xray 64p offset)?
The longer shaft makes orienting the pinion in the "normal" direction such that it does not mesh with the spur.... and reversing it causes the front belt to rub the pinion "butt"...
Edit: This is with standard spurs.
JamesL_71 is offline   Reply With Quote
Old 09-04-2011, 02:14 PM   #1055
heya
ive always used the rw racing "superlite" spurs and have been fine with my TC6, you will have to turn the pinion around so the grub screw is facing the battery
Ed
Edwin Pibal is offline   Reply With Quote
Old 09-05-2011, 07:37 AM   #1056
Originally Posted by Edwin Pibal View Post
heya
Ed
Thanks for the info. With my current 48p gears, when I reverse the pinion so the grub screw is facing the battery, the front belt lightly rubs on the underside of the pinion.
I have a bunch of 64p gears coming, so I can experiment further.
In the TC6 thread, the guys are saying that they "extend" the flat spot on the rotor shaft with a dremel. Is this recommended/safe? I don't doubt the experience of those who have made this mod, but it seems like it would be difficult to make a uniform flat spot with a hand tool.
Old 09-05-2011, 10:13 AM   #1057
It can be done... but be careful and take your time.... I know PRS made pinions with different size necks... this may help?
Old 09-05-2011, 02:02 PM   #1058
havent needed to do that before, ive run 5 different 13.5 motors before i got my hands on a murfdogg 13.5 none of them needed it.
anyways, this is the murfdogg thread, i can sat with out having to think about it, i have a 81tooth rw racing spur, a kawada 23 tooth pinion and the blue murfdogg motor and havent had any clearance issues at all
i do run my belts on the loose side to get the car to roll better so that could explain the pinion not rubbing.
ed
Old 09-07-2011, 10:47 AM   #1059
spring71's Avatar
Smile
MurfDogg Motors and Batteries are re-stocked at TQ.
Click Here to see the re-stocked items.
Also, we will have 2011 Annual Radio Post Grand Prix on Sept 25th.
It will be a great warmup race for 2011 IIC.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 09-12-2011, 01:23 AM   #1060
photobrat's Avatar
Trader Rating: 33 (100%+)
Send a message via Skype™ to photobrat
Anybody have recommendations on endbell timing for blinky mode racing, 13.5 and 17.5 to get the most speed out of these motors? Timing in the series is allowed on the motor but not the esc. I'll be running 13.5 in a 22 and sc10 and the 17.5 in a 22 if that matters. Thanks!
www.brandonsullivan.com
So many classes, so little time.
photobrat is offline   Reply With Quote
Old 09-12-2011, 09:02 AM   #1061
I find that running zero to +4 deg will give you the most from the motor's in blinky mode. More gear and less timing what seems to run best.
This is my experience running them on average sized indoor off-road tracks.
Old 09-13-2011, 03:33 PM   #1062
Can being geared to short lead to overheating?
I geared my 17.5 blinky @ 4.2 final drive thinking it would be a safe place for the motor... For reference, most of the guys @ my local track are in the 3.8 ballpark I believe.
The motor was running too hot. Unfortunately I had to pack things in before the racing got underway, so I didn't have time to experiment further.
The track layout had a large right hand sweeper leading on to the back straight... and I basically had the car pinned wide open from a few feet into the sweeper, all the way to the braking zone for the first corner.
Im pretty new to electric racing, but was a long time gas on-road guy. When I would be undergeared at some of the bigger tracks, the engine would run substantially hotter. Jumping up a few teeth on the 2nd gear pinion would generally make for a much quicker car, and much cooler/happier motor.
Does this principle apply to electric motors? Would a lower fd have helped me in this situation? Or is the general rule of thumb, lower fd = hotter motor, always true?
Old 09-13-2011, 10:12 PM   #1063
how much timing on the motor are you running ?
Ed
Old 09-14-2011, 07:14 AM   #1064
Ed
Started with 4* on the endbell, per the instructions. Motor came off the track after 5 mins @ ~175F.
Went to 0* timing, motor came off the track @ 180F.
Blinky ESC settings...
Old 09-14-2011, 10:16 AM   #1065
Buckaroo's Avatar
Yes. Brushless motors seem to have a 'sweet spot' where they operate effeciently. Outside that, over or under geared, they get reallly hot really fast.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
