Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 06-05-2011, 09:54 AM   #1006
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Hey Matt,
I ran the Northwest Short Course Nationals this weekend in Pasco, WA. There was a record turnout of 162 entries. The track was a outdoor track with lap times in the 30 second range. Had a great time talking with and helping others running Murfdogg motors at this event. Everyone was really satisfied with their Murfdogg power in the 17.5 class.
This was the biggest track I have run on in years and had a blast. I was running the new SC10 4x4 in the Pro Mod class with the Murfdogg 5.5 (540 motor) and Murfdogg Supercharger battery and Tekin RS Pro speedo. I ended up running -5 on the motor and the speed control in zero mode, AND had to turn my end point down 10 percent. (explain that in a second) Motor temps was not an issue. I ended up qualifying second in the A and placed 2nd overall with tripple A finish of 2nd, 2nd, 1st. Had some great battles with the leader just did not make it happen when time ran out. So most everyone ran 550 motors but I ran good with a Murfdogg 5.5
Settings - As the traction improved I had a big problem with wheelies down the straights. Power was just insane!!! The only way I could keep the front tires from grabbing air was to dial the end point back resulting faster lap times. I have a Venom 60c pack I use also when I practice and this battery would not pull wheelies. It was only a problem with the Murfdogg Supercharger battery. (Nice problem to have... to much punch ) So even running Mod 4w batteries, on a 91oz truck, make a BIG power difference to the motor. I am sure if I had motor and speedo timing added my truck would just jump over backwards.
Thanks again Matt for all your support.
Murfdogg Race on or Chase one....
Cameron Kellogg is offline   Reply With Quote
Old 06-06-2011, 03:02 PM   #1007
The MurfDogg's Avatar
Great Job KID!
Told you the batteries rock!
Matt "The MurfDogg" Murphy
MurfDogg Racing - www.MurfDogg.com- ROAR National Champions!
Brushless Racing Motors - Li-Po Racing Batteries - Aftermarket Accessories
Luxury Dirt Oval Racing Chassis and Performance Accessories
The MurfDogg is offline   Reply With Quote
Old 06-07-2011, 05:56 PM   #1008
Default MurfDogg Sensor Savers
Introducing the new MurfDogg "Sensor-Saver".
Many of today's servo manufacturers are building bigger, stronger, faster servos than ever before. Unfortunately, they are not taking into consideration that many of these servos will be used in vehicles with sensored brushless systems. The problem is that the sensor systems are powered from the BEC voltage provided by the receiver. Many of these big servos are drawing more voltage than the BEC can give out while maintaining proper voltage output to the ESC's sensor system, which in turn takes away the ESC's ability to provide sensored motor running.
The solution: The MurfDogg Sensor-Saver! Simply plug the Sensor Saver into an open slot in your receiver, and then the Sensor-Saver does the rest! The Sensor-Saver stores energy just in case your servo decides to overdraw the BEC system, which can keep you running trouble free!
We suggest the Sensor-Saver if you are using any of the following servo brands(known to overdraw the BEC):
-Savox
-KO Propo
-JR
-Spektrum
-Orion
-XP
MurfDogg Sensor Savers are available in two different lengths:
- 3.75" total length, for use when the Sensor-Saver must be mounted close to the receiver.
- 6.50" total length, for use when the Sensor-Saver can be mounted remotely.
Part #'s: SS-LONG, and SS-SHORT
Price: $8.00 each
Available now!
Old 06-17-2011, 12:28 AM   #1009
MurfDogg wins big at ROAR Region 12 OnRoad Championships.
MurfDogg Drivers Kenny Koch and Dave Berger both qtake home TQ honors and the A-Main wins at the ROAR Regionals in California.
Dave used his MurfDogg SuperCharger 5000mah 60C 1s Lipo to power his Synergy 1.1 17.5 Turn motor to a dominant run in 12th scale 17.5 Non Boost. The non-boost classes are putting emphasis back on the motors and batteries, and MurfDogg Power proved to be untouchable! Dave was the only driver in the class to post 13 second lap times all weekend long!
Kenny chose MurfDogg power in his Pro10 car to take both the TQ and A-Main Event victory
Thanks for choosing MurfDogg Power!
Old 06-19-2011, 08:15 AM   #1010
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks for the support Matt.
The new lipo and motor look sweet in my lil' R5
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-20-2011, 02:30 PM   #1011
calif_bouncer's Avatar
Trader Rating: 18 (100%+)
Pos Car# Laps RaceTime Fast Lap
Berger, Dave 1 2 34 8:02.903 14.303
Smith, mike 2 6 34 8:11.356 14.291
Bishop, Jim 3 5 34 8:15.056 14.519
calif_bouncer is offline   Reply With Quote
Old 06-20-2011, 02:44 PM   #1012
Calif Bouncer - Go look at the heat races and you will see the 13 second lap times...
Old 06-22-2011, 09:03 AM   #1013
Hey matt
a murff dog won and took tq last weekend at our race in WGT and I took 3rd
oh Sent ya an email.
Petra almost done the new layout, plus she need the info on the new products to add in
Andrew
cyrrus is offline   Reply With Quote
Old 06-22-2011, 10:22 AM   #1014
Originally Posted by cyrrus View Post
Hey matt
Andrew
What motor, and setup do you run for WGT ?
Old 06-22-2011, 03:02 PM   #1015
Andrew - I got your email... been busy... I will get the info to Petra soon.
Dave - They run 13.5 Boosted I believe...
Old 06-30-2011, 07:44 PM   #1016
Just ran my 17.5 for the first time and I have to say that I was totally impressed with power, was wondering what temp these motors like to run at in a blitz ese with rs pro 2 cell plus how much difference would a good battery make with this set up I am currently running gens ace batteries
Joe Novak is offline   Reply With Quote
Old 06-30-2011, 07:50 PM   #1017
ALL WEEKEND????
Old 06-30-2011, 08:02 PM   #1018
RA99GT's Avatar
Try and keep the motor temp around 150-160F after a 5-6 minute race. Try not to let the motor get near 180F and all should be good
You will notice higher c-rate batteries will have more punch. Nice to have when trying to clear jumps with short take-offs
-MurfDogg Racing- Race One or Chase One! -http://www.murfdogg.com/
My RC Racing Blog- http://ra99gt-rcracing.blogspot.com/
My YouTube Channel- http://www.youtube.com/user/ra99gt
RA99GT is offline   Reply With Quote
Old 07-01-2011, 12:14 AM   #1019
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Good advice here!! Matt's Supercharger batteries make a BIG impact when racing stock 17.5 with or without timing!!! Get some you won't regret it!!!
Hope you have been well bro!! I assume you have been representing Murfdogg well at SDRC!! I need to come down and get some laps with you one of these weekends. When is your typical race day I'll see if I can make it in the next couple weeks. I've really only ran West Coast for the past few months aside from running a lot of nitro while the weather was good. Getting to hot now need to come to SD!!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 07-01-2011, 08:27 AM   #1020
RA99GT's Avatar
hey brett! ya, i've been racing at sdrc some. but, they don't have much of a stock class down here for some reason. so, i've had to run mod with my murfdogg 17.5! still did pretty well though
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
