Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-28-2011, 03:18 PM   #976
The MurfDogg's Avatar
Default New Batteries from MurfDogg Racing
Introducing the latest additions to the MurfDogg Line-Up...
- MurfDogg SuperCharger 4600mah 60c Saddle pack batteries. These ROAR approved saddle packs won in their first outing in the JBRL offroad series Expert 17.5 4WD class, proving that they have the voltage and Low IR to put you out front!
- MurfDogg Li-Fe RX Packs, in 850mah and 1700mah capacities. We have your nitro RX pack needs covered, whether running an 8th scale or 10th scale. The 1700 gives you reliable capacity, at a great weight savings versus traditional NiMh hump packs which do not match the capacity. Also, for those weight conscious racers like oval guys, we offer an 850mah Li-Fe pack, to help you save as much weight as possible!
- MurfDogg NiMh RX battery pack, rated at 800mah, this is a perfect fit for Custom Works Nitro Dirt Oval Cars, right under the front shock tower.
All are available now!
MurfDogg Motor Works Discussion thread-batteries-4-28-11-001.jpg   MurfDogg Motor Works Discussion thread-batteries-4-28-11-003.jpg   MurfDogg Motor Works Discussion thread-batteries-4-28-11-004.jpg   MurfDogg Motor Works Discussion thread-batteries-4-28-11-005.jpg
Matt "The MurfDogg" Murphy
MurfDogg Racing - www.MurfDogg.com- ROAR National Champions!
Brushless Racing Motors - Li-Po Racing Batteries - Aftermarket Accessories
Luxury Dirt Oval Racing Chassis and Performance Accessories
The MurfDogg is offline   Reply With Quote
Old 04-28-2011, 04:23 PM   #977
I am heading outta town tonight and will not be back till Monday. All questions will be answered then. Thanks!
Matt
Old 05-02-2011, 03:25 AM   #978
jaylow215's Avatar
Trader Rating: 68 (100%+)
Default re motor
how who where can i get one of these super fast motors 17.5 murfdogg motors john australia please pm me anyone
powered by speed passion ,CBs custom gears,21.5 17.5 keilor member
B5,b5m,C4 X6,B44.2,TOP FORCE,,JRX2.TRX10,ULTIMA PRO,ASTUTE,,MANTARAY,FOX,BOOMERANG ,SONIC FIGHTER,WILD ONE,STADIUM THUNDER,JRX PRO SE,ROUGH RIDER,NIKKO F10,
SUPER ASTUTE,HOTSHOT,DYN STORM,RC10 & T
''DUCKS LOVE TO HEAR THEMSELVES FART IN SHALLOW WATER''
jaylow215 is offline   Reply With Quote
Old 05-02-2011, 08:18 AM   #979
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I believe there are some shops that carry them, but you can also purchase them directly from Matt if you e-mail him at dirtoval9@aol.com
Like he said above though he was at a race last weekend so he might not get back to you today.
Cameron Kellogg is offline   Reply With Quote
Old 05-04-2011, 04:04 PM   #980
Our saddle packs are OFFICIALLY ROAR APPROVED!!
Old 05-08-2011, 01:45 PM   #981
MurfDogg is proud to release our new rubber sealed bearing sets. Ceramics are not for everyone. For racers on a budget, try our new Rubber sealed bearings!
Available for Dirt Oval Cars/Associated SC10FT, Associated T4.1/B4.1, and Associated B44.1. Also available in a 10 bearing multi-pack for wheel and hub bearings. If you are like me, and hit the wall, it is ALWAYS good to have spare wheel bearings!
We now offer a Silicon Nitride Diff and Thrust Ball set for the "TLR 22", for the smoothest diff possible.
Also available, Metal Shielded Clutch Bearings for Dirt Oval/NTC3 Clutch Setups.
CBS-17 - Associated B4.1/T4.1 Rubber Sealed Bearing Set - $30.00
CBS-18 - Associated B44.1 Rubber Sealed Bearing Set - $40.00
CBS-19 - Associated SC10FT/Dirt Oval Chassis Rubber Sealed Bearing Set - $30.00
CBS-21 - TLR 22 Silicon Nitride Diff and Thrust Ball Set - $17.0
CB2-22 - 3/16" x 3/8" Rubber Sealed Bearings - 10 pack - $24.00
CBS-23 - Metal Shielded Clutch Bearing Set for Dirt Oval/NTC3 Clutches - $5.00
MurfDogg Motor Works Discussion thread-new-bearings-5-8-11-001.jpg   MurfDogg Motor Works Discussion thread-new-bearings-5-8-11-005.jpg   MurfDogg Motor Works Discussion thread-new-bearings-5-8-11-006.jpg   MurfDogg Motor Works Discussion thread-new-bearings-5-8-11-007.jpg
Old 05-08-2011, 05:15 PM   #982
Farticus's Avatar
Murfdogg:
I sent you an email but I saw this forum and thought I would double the coverage. I bought a motor on eBay (a “1:10 on-road murfdogg 13.5 brushless motor designed for use with a 1s battery”) and I think I might have screwed up. I want to run it in a Associated SC10 Short Course truck with a 2s battery. Can I do this? If not, what options do I have to make it work for my application?
Got your reply (very quickly I might add) Thanks.
Farticus is offline   Reply With Quote
Old 05-11-2011, 01:49 PM   #983
Farticus - You will have no problems...
Old 05-11-2011, 10:51 PM   #984
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
I must say these new packs are on a level of there own! No other manufacture has the customer service, performance and looks in one package as Murfdogg does! As the motors this is the best stuff on the market! And now with bearings and diff kits!! Way to go Matt keep it up!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 05-12-2011, 02:24 PM   #985
On that note, Let me one up it once again...
Introducing the NEW MurfDogg SYNERGY 1.1 Motors. Same great motor design, refined in every possible way.
-Currently available in 17.5, 8.5, 7.5, 6.5, 5.5, 4.5 turn winds.
-New Solder tabs are 1/12th scale friendly. Much easier to solder now with our new revised Solder Tabs!
-All SYNERGY 1.1 Motors will be finished in our Matte Black wrinkle finish, and are Identified by the Lazer Etching around the Circumference of the Motor Can.
MurfDogg Motor Works Discussion thread-synergy-1.1-001.jpg   MurfDogg Motor Works Discussion thread-synergy-1.1-002.jpg   MurfDogg Motor Works Discussion thread-synergy-1.1-004.jpg
Old 05-12-2011, 02:40 PM   #986
RA99GT's Avatar
looking good matt!
-MurfDogg Racing- Race One or Chase One! -http://www.murfdogg.com/
My RC Racing Blog- http://ra99gt-rcracing.blogspot.com/
My YouTube Channel- http://www.youtube.com/user/ra99gt
RA99GT is offline   Reply With Quote
Old 05-12-2011, 03:02 PM   #987
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
NICE !
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-12-2011, 03:07 PM   #988
RA99GT's Avatar
matt, do you have an update catalog or price sheet? you have so many products now, i can't keep track of them all!
Old 05-12-2011, 07:11 PM   #989
Rodney,
Check your email!
Old 05-12-2011, 07:15 PM   #990
Default MurfDogg Product List as of 5/12/11
S-035 - Synergy 3.5 Brushless Motor
S-040 - Synergy 4.0 Brushless Motor
S-045 - Synergy 4.5 Brushless Motor
S-055 - Synergy 5.5 Brushless Motor
S-065 - Synergy 6.5 Brushless Motor
S-075 - Synergy 7.5 Brushless Motor
S-085 - Synergy 8.5 Brushless Motor
S-105 - Synergy 10.5 Brushless Motor
S-135 - Synergy 13.5 Brushless Motor
S-175 - Synergy 17.5 Brushless Motor
S-215 - Synergy 21.5 Brushless Motor
S-SB - Synergy Hall Sensor Board
R-123S - Synergy 12.3mm Spec Rotor
R-125S - Synergy 12.5mm Spec Rotor
R-120M - Synergy 12.0mm Modified Rotor
R-123M - Synergy 12.3mm Modified Rotor
R-125M - Synergy 12.5mm Modified Rotor
CBS-08 - Ceramic Bearing Set for Dirt Oval Clutch Bells (NTC3 Style)
CBS-09 - Ceramic Bearing Set for Novak SS/Ballistic Brushless Motors
CBS-10 - Ceramic Bearing Set for Custom Works Dirt Oval Cars
CBS-11 - Ceramic Bearing Set for Synergy Brushless Motors
CBS-12 - Ceramic Bearing Set for Pan Cars with 1/8" Front Axles
CBS-13 - Ceramic Bearing Set for Pan Cars with 3/16" Front Axles
CBS-14 - Silicon Nitride Diff Ball Set for Pan Cars (1/8")
CBS-15 - Silicon Nitride Diff and Thrust Ball Set for Dirt Oval
CBS-16 - Ceramic Bearing Pair - 3/16" x 3/8"
CBS-17 - Rubber Sealed Bearing Set for Associated B4.1 and T4.1
CBS-18 - Rubber Sealed Bearing Set for Associated B44.1
CBS-19 - Rubber Sealed Bearing Set for Dirt Oval/SC10FT/Deviator
CBS-20 - Ceramic Bearing for SC10 Gear Diff Outdrives
CBS-21 - Silicon Nitride Diff and Thrust Ball Set for TLR 22
CBS-22 - Rubber Sealed Bearings - 10 Pack - 3/16" x 3/8"
CBS-23 - Metal Shielded Clutch Bearing Set - Dirt Oval/NTC3
TP-01 - Turbo Plugs - 4mm Power Plug - 1 Pair
TP-02 - Turbo Plugs - 4mm Power Plug - 2 Pairs
TP-10 - Turbo Plugs - 4mm Power Plug - 10 Pairs
L-5500-65-2S - SuperCharger 5500mah 65c 2s Lipo
L-5000-60-1S - SuperCharger 5000mah 60c 1s Lipo
L-4600-60-2S-SP - SuperCharger 4600mah 60c 2s Saddle Pack Lipo
NiMh-800 - 800mah AAA Nimh Rechargeable RX Pack - 6V
LiFe-850 - 850mah LiFe RX Pack - 6.6V
LiFe-1700 - 1700mah LiFe RX Pack - 6.6V
T6-Charger - Thunder T6 Charger
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
