Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-28-2010, 11:23 AM   #646
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Most of the on-road people account for tire size also, so when he says 91mm the car move 91mm to 1 turn of the motor.
Cameron Kellogg is offline   Reply With Quote
Old 10-28-2010, 11:31 AM   #647
pvalenti's Avatar
WOW...they are geared WAY different than my B4/T4's are then. I mean if I understand it all correctly (found an article on how to calculate rollout) my B4 should have an approximate tire diameter of 3.5 inches and a final drive ratio of 5.35 (72 spur / 35t pinion x 2.6) giving me a rollout of 0.6542056 inches or 16.616822239982053 mm. Quite a bit different indeed!
Paul Valenti
AE B44FT - Orion Vector Pro 8.5t - Ko Propo BMC Pro Mod
AE SC10 4x4 - Castle/Neu 1410 3800kv - Castle MMP
*Airtronics* * *JConcepts* *Sticky Kicks* *SAVOX*
pvalenti is offline   Reply With Quote
Old 10-28-2010, 11:34 AM   #648
JayBee's Avatar
Trader Rating: 31 (100%+)
You're missing a very important variable.....PI (3.14)
The mathematical equation for ROLLOUT is-
Tire size (I like to use millimeters) X PI (3.14) X pinion / spur
41.10mm X 3.14 X 51(pinion) divided by 72(spur) = 91.41mm
We use rollout (NOT FDR) with FOAM tires because of our tires changing size from run to run.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-28-2010, 11:36 AM   #649
pvalenti's Avatar
Nevermind that...3.5 was the diameter not the circumference. That would make the circumference about 10.99, giving me a rollout of about 52.17682223994365 mm
Paul Valenti
Old 10-28-2010, 11:38 AM   #650
I believe most on-road cars fdr's are in the three's
Old 10-28-2010, 11:41 AM   #651
The mathematical equation for it is-
I found an I-phone app (Ratio Calc) that is free and does all the math for me.
I eat PIE instead of calculate it.
Old 10-28-2010, 11:44 AM   #652
pvalenti's Avatar
Okay that gives a wildly different result altogether. That would stack up like this -
88.9 (3.5 inches) x 3.14 = 279.146 x 35 (pinion) = 9770.11 / 72 (spur) = 135.695787 mm rollout.
Why is that so much different from the one that I had previously?
Paul Valenti
Old 10-28-2010, 11:53 AM   #653
JayBee's Avatar
Because you left out the all important PI (3.14).
And what you calculated above is exactly right...that's why you were way off. But why are you trying to use this formula with RUBBER tires? Rubber tires don't have the wear that FOAM tires do. Plus camber and caster changes the 'shape' of our tires on our 1/12th & 1/10th scale pancars. Most of us 're-true' (shave down) our tires, so the tire size changes and to maintain the same speed (rollout) pinion size has to increase. A couple of other factors are involved but this is it basically....
Still confused?
Old 10-28-2010, 11:57 AM   #654
pvalenti's Avatar
Still confused?
Pretty simple to figure out really. I read you all talking about it and wondered how it applied to me. I had no idea whether you were talking about street or dirt and nobody really said (so far as I could tell). As I said before...I'm new to this hobby and just want to get up-to-speed on the tech side of it all.
Make sense now? So I take it you are saying that I shouldn't be concerned with rollout at all then?
Paul Valenti
Old 10-28-2010, 12:03 PM   #655
JayBee's Avatar
Brah...calm ya nerves. Nothing that I've said and how I've type it should have came across as demeaning. If it has, I apologize. But whether your new or not....I'm explaining.
And yes....If you are running offroad w/RUBBER tires, ROLLOUT doesn't apply to that application.
(I'm smiling at you)
Old 10-28-2010, 12:27 PM   #656
The MurfDogg's Avatar
Hey buddy, yep...had that in the endbell at first. Opted to try less endbell timing with throwing a couple more teeth at it. Final rollout of the night was 91mm.
I do everything in inches... You are at 3.58".... we run 3.4-3.5 usually.
PM me your ESC setup...
We will get you where you need to be!
Matt
Matt "The MurfDogg" Murphy
MurfDogg Racing - www.MurfDogg.com- ROAR National Champions!
Brushless Racing Motors - Li-Po Racing Batteries - Aftermarket Accessories
Luxury Dirt Oval Racing Chassis and Performance Accessories
The MurfDogg is offline   Reply With Quote
Old 10-28-2010, 12:31 PM   #657
Well I know off-road or on-road the Murfdogg motors are freeking sweet.
Nice to see more and more local racers are running blue motors. The down side is my speed advatage is being matched by them now.
Old 10-28-2010, 01:09 PM   #658
pvalenti's Avatar
Oh I wasn't insulted at all...just explaining since you asked is all. (I'm smiling back).
From MY perspective your statement that you were trying to figure out why I was trying to figure rollout on an offroad car with rubber tires wasn't really explaining...it was confusing. So I felt the need to explain myself.
Sorry...text can be taken in so many different ways...I like to use caps and bolds and stuff to infasize things I think are important..it's not yelling or me being pissed or anything. If I was mad or insulted you would have no doubt in your mind, plus I'd probably use the RED smilies!
Paul Valenti
Old 10-28-2010, 02:05 PM   #659
JayBee's Avatar
Matt
Sent ya PM buddy
Old 10-28-2010, 10:42 PM   #660
bkspeedo's Avatar
They may be matching speed but are they lasting as looooong. I know in WGT the MD motor is still pulling fast laps when everyone else is dropping off.
Great motor Matt, looking forward to your new 1S rotor version.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
