Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree2Likes
Old 11-21-2012, 11:54 AM   #376
Rick Hohwart's Avatar
Default Reedy Cyber Monday Sale
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-03-2013, 05:31 PM   #377
ShaunMac's Avatar
Anyone had a chance to run the new 2S 7000 65C packs?
How did they perform for you? What class did you run it in?
ShaunMac is offline   Reply With Quote
Old 04-03-2013, 05:45 PM   #378
B00t13g's Avatar
I was driving today and I pulled off after about 4 minutes because my car felt weird. I temped my motor and it was at 170. My motor usually runs at 155-160 max. It now feels like it has a lot of drag brake. Any ideas?
Reedy mach 2 4.5 orca vx. The whole setup has 20 packs at most through it.
New packs are great. Running in 17.5 and mod sedan.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-04-2013, 03:21 PM   #379
B00t13g's Avatar
Mackenzie Meyercord
Old 04-04-2013, 03:58 PM   #380
hanulec's Avatar
Trader Rating: 27 (100%+)
yeah - it is about to blow up. it got too hot...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-04-2013, 04:51 PM   #381
haywood's Avatar
Trader Rating: 48 (100%+)
He my need one of your fans!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 04-04-2013, 04:55 PM   #382
hanulec's Avatar
could be.
i've blow up my fair share of motors even with fans. i don't remember if popping that pole means there is too much gear or too much timing. it is one of the two....
Old 04-04-2013, 05:46 PM   #383
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
How do you measure your temp ?
Right away after a run, with no time to let the fan cool everything down ?
Do you measure can temp, or inside temp ?
Just curious
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-04-2013, 08:11 PM   #384
B00t13g's Avatar
I measure temp the second I pull off the track. My temp gun is set to hold at the max temp and I run it all around the can. My 17.5 mach 2 routinely comes off the track at 165+ and I've never had an issue with it. I now have a speedzone 5.0 in my car, lets see what reedy says. I needed to send in a flow anyway. I don't run a fan on my mod car, but I do on my stock car. Side piece racing of course!
Mackenzie Meyercord
Old 04-05-2013, 05:25 PM   #385
Losiho's Avatar
I regularly run 80 - 85 degrees C (180 - 185F) with no fade, burning smell or rotor problems (Sonic 21.5 boosted touring). Furthermore, Rick Howart himself has said right here on rc tech that 80 -85 degrees C is not hot for a Sonic.
Losiho is offline   Reply With Quote
Old 06-24-2013, 08:39 PM   #386
racer x 1's Avatar
will a 17.5 mach 1 stator fit in a 10.5 mach 1 can?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 08-18-2013, 10:12 PM   #387
Trader Rating: 16 (100%+)
Send a message via AIM to DJGonzo69
Rick- just bought a Reedy 17.5 motor. What gearing should I use for Norcal?
Also where do I set the motor timing at?
Thx-John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 08-21-2013, 08:12 PM   #388
Burlap's Avatar
Send a message via MSN to Burlap
I had my Reedy Sonic Mach 2 21.5T motor die out of the blue last night when I was doing some practice work before racing.
The motor had not be used that night before the incident, and had been working fine on previous race nights. I run a LRP fan/heatsink unit on it, so it barely gets hot (especially with it being winter down here in Australia at the moment!).
What happened was I put the car down on the track to check some changes I had done to the suspension and noticed that it was down on revs when taking off. Soon after that the car just stopped. There was no smoke, nor the burnt electrical smell.
The motor is connected to a Tekin RS v.2 ESC. The ESC told me that the motor type was incorrect. I swapped over the sensor cable, as one of my friends had an issue with a Mach 1 21.5T motor which wouldn't rev out because the sensor cable went bad. After swapping the cable the motor still wouldn't turn, and the ESC was telling me the motor type was still incorrect (Lights 1, 2, 6 and 7 are on).
The motor spins freely enough when I pull on the belts in the car, so it had not jammed up.
As a test to make sure the ESC had not gone bad, I reconnected my Mach 1 21.5T motor to the ESC. The motor worked correctly and there were no errors with the Mach 1 connected. I reconnected the Mach 2, but still coming up with incorrect motor type error.
So from what I can see, the Mach 2 motor has died. Is it worth for me to send the motor back to shop I purchased it from for a replacement? I have not opened the motor.
Burlap is offline   Reply With Quote
Old 09-24-2013, 06:22 PM   #389
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Hi, can someone explain the difference between the new Competition Lipo 7000 65C:
http://www3.towerhobbies.com/cgi-bin...?&I=LXDCUE&P=0
the 'older' 5500 60C:
http://www3.towerhobbies.com/cgi-bin...?&I=LXASTV&P=0
and the Wolfpack 5500 60c:
http://www.reedypower.com/products/details/739/
Apart from the obvious numbers, will the cheaper packs be ok in 13.5 Blinky Touring Car racing. I only race at club level and the occasional interstte event, but I obviously want to be cometitive at that level.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 10-08-2013, 07:33 AM   #390
~McSmooth~'s Avatar
Questions??
Edited - Found the info I was looking for!
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Futaba MC800, Reedy Neo One 6.5, Reedy Ti Mods convikt R/C Items: For Sale/Trade 6 10-08-2007 05:38 AM
Comm Lathe, NIB Reedy 19T Armature, Reedy 766 or 767 brushes, Sonic Fiddlestick Cain R/C Items: Wanted to Buy 4 06-12-2007 06:43 AM
Airtronics Synthesized-stuff,FM rec's,REEDY BRUSHESS,REEDY MOD MOTORS,etc,etc, nobike R/C Items: For Sale/Trade 89 03-22-2007 09:33 AM
JR XS3, LRP 7.1, Reedy Quasar Pro, Reedy 12 double S.Heath R/C Items: For Sale/Trade 1 10-31-2005 06:48 AM
MR-4TCSD, Reedy X-Cell 3300, Reedy Kr Randy Caster R/C Items: For Sale/Trade 9 07-03-2003 07:27 PM
