Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-31-2008, 01:00 PM   #136
Rick Hohwart's Avatar
Originally Posted by Syber Serulean View Post
alright i have a strange issue with my stockstar...
but first...a friend of mine ran his and it delaminated in his first heat of the JBRL. It wasnt even hot...strange issue as mine worked great all day.
anyways, my issue...
the motor never gets hot. Granted is mainly 50 degree weather and i always froze my the motor with a can of Dust Off upside-down before my heat...it still never got hot. I started off at 20/81 (i have a b4). Then 18/81...then 16/84...the motor still didnt get hot. How low do i have to gear this thing? lol. I originally started at the recommended FDR of 10.00...im at 10.65 it looks like right now. Any tips? help? Im probably just gonna leave it as it is for now cuz it runs pretty good so no complaints, but if you guys have better tips or gearing tips with that motor lemme know. Thanks.
You are gearing the wrong direction. For the motor to get hotter, you will have to increase the size of the pinion gear. So you will want to dip into the 9s for FDR.
But the most important thing is the performance. If you are happy and it is running cool, that is great!
Rick Hohwart is offline   Reply With Quote
Old 03-31-2008, 02:09 PM   #137
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
the motor wont get hot if its undergeared?
alright well ill try gearing back up to see what happens, maybe one of these days during practice. Thanks.
Syber Serulean is offline   Reply With Quote
Old 03-31-2008, 02:58 PM   #138
There are some that tha an undergeared motor can overheat. But I have never experienced this. Go bigger on the pinion and the motor should run even faster. A motor should run pretty hot when it produces maximum power.
Old 03-31-2008, 03:24 PM   #139
corallyman's Avatar
Trader Rating: 97 (100%+)
Rick,
Do you have more info for us on the Lipo charger and balancer that you guys might be recommending for usage on your new Lipo packs.
I am hoping to get some new equipment soon for the summer.
Thanks,
Steve
corallyman is offline   Reply With Quote
Old 04-01-2008, 03:38 PM   #140
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Unhappy
It was my motor that delaminated.
i was running second in my heat and the motor was fast.
i hope reedy will replace it, the motor didn't even last 4 min.
metalracer2 is offline   Reply With Quote
Old 04-01-2008, 03:51 PM   #141
rc pete's Avatar
Rick, do you have any pics or description of the LiPo/weight solution for the TC5?
I've been running the thick chassied XRay on carpet with foams successfully, but we've decided to swap to rubber tires in our region, so I need a thinner chassied car, like the TC5 or Cyclone, which I'd like to run with LiPos. I'm likely not going to the EU series of the XRay, because their chassis turn over is a little too high.
Thanks.
rc pete is offline   Reply With Quote
Old 04-02-2008, 10:25 AM   #142
Any chance on some new Reedy mod motors based on the Stockstar/Challenger design? Maybe with aluminum endbells? A few of us still run brushed motors from time to time. Thanks, Billy
BCall is offline   Reply With Quote
Old 04-02-2008, 10:49 AM   #143
Reedy is sending you a new armature.
Thanks.
We don't have any pics as the design is continually changing. The basic idea is to use the existing battery strap holes and screws to mount nickel plated brass ballast pieces that key into the bulkheads so that they do not move. The battery is then secured with tape. With this set-up, the car is nearly perfectly balanced left to right.
No chance. Originally we had planned on it, but the demand for brushed modified is so low that it is not worthwhile to pay for any additional tooling just for modified motor sales.
Old 04-02-2008, 11:55 AM   #144
i sent in the hole motor so i hope they send the can and everything else too
Old 04-02-2008, 12:16 PM   #145
how soon should we expect more variety in brush compounds? (for the stockstar)
Old 04-02-2008, 08:45 PM   #146
Are the stockstar motors actually roar approved??
Floss_LUC is offline   Reply With Quote
Old 04-03-2008, 08:43 AM   #147
POUNDITRACING's Avatar
Hay Rick, I had a question about the LRP Sphere TC ESC. I heard that there is timing built into it. What amount is buils in and what do you suggest for a 10.5 and a 13.5?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 04-03-2008, 09:06 AM   #148
If you sent in a complete motor you will see a complete motor returned. I only saw the armature when it was removed.
Sean C is working on this right now. I hope by summer.
ROAR has already done the tests and received the paperwork with proof of availability. This means it will appear on the approved list within the next 7-10days.
I am not familiar enough with the ESC to comment. It does have adjustable throttle profiles that change the timing among other things. I use throttle profile 8 with a 10.5 and you would probably use that same profile with a 13.5 or 17.5.
Old 04-03-2008, 09:20 AM   #149
That's good for me. Thanks for the help.
Old 04-03-2008, 09:57 AM   #150
do you know how they sent the motor? Ups or Fedex
Futaba MC800, Reedy Neo One 6.5, Reedy Ti Mods convikt R/C Items: For Sale/Trade 6 10-08-2007 05:38 AM
Comm Lathe, NIB Reedy 19T Armature, Reedy 766 or 767 brushes, Sonic Fiddlestick Cain R/C Items: Wanted to Buy 4 06-12-2007 06:43 AM
Airtronics Synthesized-stuff,FM rec's,REEDY BRUSHESS,REEDY MOD MOTORS,etc,etc, nobike R/C Items: For Sale/Trade 89 03-22-2007 09:33 AM
JR XS3, LRP 7.1, Reedy Quasar Pro, Reedy 12 double S.Heath R/C Items: For Sale/Trade 1 10-31-2005 06:48 AM
MR-4TCSD, Reedy X-Cell 3300, Reedy Kr Randy Caster R/C Items: For Sale/Trade 9 07-03-2003 07:27 PM
