Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#1173
Tech Legend
Trader Rating: 51 (100%+)
The Novak one is for what ever reason one of the harder ones to get to work. The Trinity Duo is suppose to work great. Hope to be testing one soon.
#1174
wyd how do you find the new castle softwear when using the mamba esc/orion motor combo did they iron out the hesitation you get.
#1175
Tech Legend
I tried the proto type Sidewinder I had with the software in and it did hesitate but the Production version Sidewinders have updated software over the prototype I had so it could be better. I want to try it again with my Orion 13.5 but not sure when I can make it to the track to run touring cars but when I do I will more than likely just use my Mamba Max as I updated all the software and I will have my laptop with me so I can try all kinds of stuff a little quicker than I can with my Sidewinder at this time. It will only take seconds to change start power and timing postions and see what effects I get.
The track I test at I don't get much time onc I get their and its two plus hours away. Might be a few weeks til I can make it back.
#1176
130bux, sheesh so much for sellin my max ha!
R
R
#1177
We found a small problem (I think) with a friends Mamba Max after updating to the new firmware (1.17). The only change was the firmware update, we made no other adjustments.
With the car switched on and just sitting on the ground it makes a low beep sound randomly 15 - 30 seconds between beeps and the yellow light flashes at the same time. It doesnt seem to cause any problem when driving. The beep and flash never happened with the previous version of the firmware (1.09). We changed the firmware back to 1.09 again on Sunday just to confirm that it was the firmware change that made it happen and the beep and flash went away.
The vehicle is a Losi MF2 with the Mamba Max 5700, 4200 packs and a 2PL radio. I dont have the settings as we were using my friends laptop.
The beep and yellow light doesnt seem to cause a problem, its just a little annoying random beep and flash and we dont know what it means.
Anyone have a suggestion?
#1179
Not a problem...it was intentional. It's to remind you to unplug your battery pack.
#1180
hi joe need some help with setting up my transmitter with mamba new softwear i have a JRZ1 (ex10)what is some good parameters to start with.i am using v1.17.
#1181
Tech Legend
What car are you running and what motor are you going to use will also be needed to get you better info.
#1182
racing at all this wkend brian? still racing stock 1/18 down here, buildin mod car back up in prep for its replacement speedo. looks like micros are still invadin frederick in 2wks time. sounds more fun than freezin ur butt off only to get bounced outta monster truck at motorama b/c ur brushless
R
R
#1183
Tech Legend
R
R
#1184
thanks.
#1185
when should the mamba monster max be out? what are some of the specs on it? im seriously interested in it and if it suits what i need then i plan on getting one first week out
