Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#541
Tech Legend
Trader Rating: 51 (100%+)
CRASH sent you some pics.
#542
Later,
#543
Tech Legend
Originally Posted by CRASH
About time!
Later,
Later,
I wanted to make sure I have everything right first.
#544
Originally Posted by Joe Ford
tomislav...as long as you have a receipt we will warranty the product for 1 year. No LEDs? Does your steering servo function? Any sounds? Let me know.
addicted...the new GF was the reason I got it. She's a critical care nurse at Olathe Medical Center...brought it home with her on her scrubs.
#545
well low start power, low timing and 100% control. standing start...yielded wheelspin and a torque steer to broadside in less than 30in (yes i measured lol). also like gettin outta the pits at monaco style. good thing i was last on the grid (finished better though).
i'm now back to full linear curve, tired of messin with it. -40% expo (JR) and 5% off the epa.
R
R
#546
Tech Legend
R
R
#547
EXP on the radio will alter how much "trigger" the speedo thinks you are pulling, so it will always effect responce.
#549
bri, cant go any further on slipper. thats for sure.
i'm already someone who is soft by nature on the throttle. grew up on elecs so i dont have a 'wah-wah pedal'.
my main goal was tryin to calm the bomb goin off up top, but anyway i can soften the initial hit of throttle would help for those times i'm off my game.
thx
R
thx
R
#550
for the 1st time im running -50 on the throttle exp
this may seem alot but it works really good and you will always have full throttle at full trigger.
i really like this mamba bl thing and speedo.
#551
A max RPM gain function will be nice... something that will limit the RPM that could be gain in a certain amount of time... if the RPM go up suddently it's because you loose traction and the wheel spin. A brushless system could sense this and control it... Hummmm electronic traction control It will certainly be illegal but...
#552
Sup guys
I have a couple Q's with my MM7700 combo
I think should start @ the begining
Me and couple of friend bought rtr electric r/c for drift
Then one of my friend throw in a novak on his r/c (tamiya) so I decided to get a mamba which I think everyone like.
I'm going to use this MM7700 COMBO
On my tc4 rtr
My question is
1>>>>>>How do you program this esc. Do I need to to connect the battery first then plug it in on my computer?
Or I just set it up first on my r/c then plug it in on my computer?
2>>>> can I use SMC 3800 HIGH PERFORMANCE INTELLECT BATTERY TO POWER UP?
3>>>>>>WILL I BE ABLE TO CATCH UP WITH A NOVAK 4.5 TURNS? WITH THIS MM7700
Thankx everyone for taking a time to reply. With my noob questions
On my tc4 rtr
My question is
#553
Mate, u might have some trouble with the 7700. I had a 5700 in my TT01D that i also use for drifting only, and using steel universals the 5700 managed to put wear marks in all my cup joints, including my prop shaft joints. So u might have trouble with a 7700 with an rtr TC4. you really dont need all that power for drifting in my opinion. Im going from a 5700 to a 4600 for longer runtime aswell as better control in drifts.
If you are still going a 7700, and your trying to extract as much power as possible, invest in a 2 cell lipo, u will not be dissappointed, and u will have no trouble gunning past a 4.5!!
Now the programming, it says step-by-step on how to program in the manual, but basically u install castle link on your comp, and plug the esc into the comp using the usb cable its supplied with. you dont have a battery plugged into the esc while your programming it on the comp because the esc is getting powered by the computer through usb.
Hope that clears a few things up mate!!
#554
well im making an electric truggy out of my dark impact. so far its gone pretty good. bout to get a longer chassis and better body posts, and want to go from a 17 mod to a brushless. im either going to get the 5700 or the 6900. im a little worried about the 6900, because people i have tlaked with said that the 7700 would get pretty hot on a 85/23 gearing, and thats as high of a gearing it can go... and im worried with the bigger heavier tires, the 6900 might be a little hot with a high gearing. what do yall think on it?
#555
Thank you very much drifter demon
That help's a lot
Well we bought rtrs for drift
But since were using brushless now
Were turning it to drag race hehehhehehe
Big bucks on the line here
We play for $200.00 bucks
Just as friends though
Anybody know a good set up for drag racing with this tc4? Using 7700?
Thanx again demon drifter
