i saw a link on www.castlecreations.com about a new monster series. is that supposed to be a strong series? will it be good for a single motor monster truck? something like a converted revo possibly?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
Works fine w/4 cells as long as you disable the BEC on the controller (lift the tab and pull the red wire out of the servo connector). Then use a jumper from the ESC side of the battery to ESC connection and plug directly into your receiver.
We tried a 5700 system in a T2 the other night with foams on carpet. The guy who put it in said he set it up right, yet the throttle felt like an "On/Off" switch with unreal power. Was something set up wrong? I checked it with the Castle Link and it was set stock with the throttle curve going diagonally up from o to 100. Any thoughts?
Joe Glorioso
Team Driver:
Schumacher USA / Speedpassion / Core RC / Express Motorsports / John's BSR Tires / TQ Cells
NJG Racing
Hi Joe, just a few more questions regarding running 4 cells:
1) I've read elsewhere on this forum that the 7700 is quite power hungry. Will the 7700 work well with 4 cells?
2) Regarding the rewiring to run 4 cells, do you have some pics or diagrams?
3) Again with the rewiring, if this something that can be included in your website and instruction manuals so that it is more "official" and therefore doesn't void any warranties, etc.
Sorry to be a pain but I was all set to buy... So just want to get a few things confirmed before I do.
Cheer,
Vincent
TRF416 :: F104 Pro :: Buggy Champ
Joe...have the guy at your track make sure he has his endpoints on his throttle (both foward and reverse) at ~125% if he has a computer programmable transmitter. Even if he doesn't tell him the #1 thing to do is calibrate the controller...if he hasn't done this it would act just like that...very choppy throttle because you're not spreading the throttle range out with the entire travel of the trigger. The other thing to consider has already been mentioned....gearing.
Vincent...I ran the 7700 on 4 cells in a XXX-s to test and vented the GP3300 pack I used. Better to have IB3800/4200 or GP3700/4300. Turn timing to "lowest" using the included Castle Link software. Should work fine. Here's a quick drawing of proper wiring superimposed on our MM User Guide. I'll see what we can do about getting something official up.
Joe Ford
Product Specialist
Castle Creations
Thanks for the reply Joe. How would you rate the speed of a 7700 on 4 cells compared to 6 cells - eg 10T motor on 6 cells? Sounds like I might better off getting a 7700?
Thanks Joe....I have a feeling he only had his endpoint on 100%. I'm going to put it in my RDX this week and set my Throttle EPA as high as it will go to smooth it out.
Joe Glorioso
Team Driver:
NJG Racing
Tom...the 4600 is the closest to a 19T...it's about a modified 12T.
Drew...click file, save settings, and save the file to your desktop so it's easy to find. Then email it to your buddies or post it on here by adding it to the email/post. Use the attach function in emails, use manage attachments on forums.
Joe Ford
Product Specialist
Castle Creations
