Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#1951
Hey all....I just finished and 8th scale conversion with a Mamba Monster Max and a 2650 Motor. Armed and calibrated fine, bu it seemed strange that the cooling fan came on immediately. I thought it only came on once the esc hits 150? Anyway, I made 4 or 5 60 to 70 foot passes, checked the motor temp and it was still cold, then took it for another pass and the car just stopped dead. Servo still works but no chirping from the motor. Hooked it up to the Castle Link, updated the firmware, went to recalibrate and still no chirps. I'm running a Kyosho 777WC with the MMM v3 2650 Combo, Stock 48 Tooth Spur, Robinson 13 Tooth Pinion, 4s 5000mah pack.
Anyone have any clue what may be going on? I've run CC systems before with no problems at all....I hope this didn't fry already?!?
HELP!!!!
HELP!!!!
#1953
Joe Ford....You have Email...
#1954
HELP!!!!
HELP!!!!
It seems you got taken just like me.
#1955
HELP!!!!
HELP!!!!
#1956
HELP!!!!
HELP!!!!
I have the Mamba Monster 2200KV Combo in a 8ight-E and the fan on the ESC comes on when it's switched on then goes off until the ESC reaches a certain temp.
My motor churps when the ESC is switched on.
have you tried switching your motor wires around?
#1957
I've tried everything. ESC comes on, the lights respond properly for calibration, then they respond properly for all throttle and brake inputs from the controller. Seems like its something with the motor thats why I noted in my first post that the motor was cold. I'm really hoping it's something silly that I'm missing. My track has it's Friday Night Series starting May 8th and I don't want to miss the first race. The guys at Castle are top notch so hopefully I'll hear from someone and it's a quick fix as I know it's absolutely NOT user error.
#1958
Hello guys. I have a question about golden connectors from the MM ESC to the motor. They are started to glued eachother from the heat insulation(heat tube is melted). I gues if I dont do something, they can make a shot circuit. The wires are getting hot, but the connectors are much more hotter. They looks just like new. No scales, everything looks like new and shiny. They fit very tight. I'm woundering if my ESC can get hotter becouse of this connectors? I think its something wrong with them, even if they looks like new. I'm thinking to cut them and weld the wires together. Any suggestion please?
Thanks,
Stanislav
Thanks,
Stanislav
#1959
You would need this http://www.castlecreations.com/produ...stle_link.html it hooks onto your receiver plug.
#1961
HELP!!!!
HELP!!!!
#1962
Castle = Junk
4-18-09 "Cut your losses and buy a good esc. That's what I had to do. They will blame your problem on everything else but their own product.
It seems you got taken just like me."
#1963
Remember.......I tried to tell you that when you first posted about your problem. I just installed my new LRP esc and all my problems were fixed and the tech at Castle Creations blamed every other component on my car as the problem.
Castle = Junk
Castle = Junk
No need to come on the forums and openly bash a very reputable company, even though you had a bad experience.
#1964
Give us a call. 913-390-6939 and hit 1 for tech support. We'll get you out an advanced replacement as you just got the system. Fan shouldn't come on with that setup anywhere near when it is, if at all.
#1965
This is the normal operation.
