LIGHTSPEED PRODUCTS
#46
we did get 3 quals and A1 in on saturday and thanks to Jeremy and Lightspeed, everone had motor. jeremy did not race the regionals. instead he tune everyones motor. Lightspeed also provided brushes and spring to all the handouts and the brushes were the brushes that work on that motor. with our hand out, Lightspeed provided F brushes, not a set of cheap brushes everyone would throw away.
thanks Lightspeed!
thanks Lightspeed!
#47
Jeremy: got my package and the numbers look great - I'lll let you know how they work after the NE race. Thanks for the hook up.
David: So is the entire regional race going to be rescheduled and if so can a person that was not in the orginal sign up for the rescheduled one? It just so happens I have the Nov 10-12 weekend off.
Yang: Sounds like you had a good time racing my friend!
L8R Steve
L8R Steve
#48
thanks Lightspeed!
thanks Lightspeed!
#54
Originally Posted by CarlosG.
Yang said he would not be able to make it. However, if he does, it would be good to have someone to chase down again. I hope to do better and give him a run for his money.
thanks david. I did consistent laps with the bad motor. when I finally got some power, I was not sure what to do with it. but I know I will figure it out in short order. the car was on rails. really easy to drive hard into the corners and with the good motor, fast coming out.
#56
here is the only thing I could not figure out. the sweeper at the end of the straight. The car turned in way too hard. i know that is just the opposite of the norm, but I had way too much high speed turn in to the left. that is the only one turn i can say that about, but there really is not another high speed left hander on the track. I probably need to try and move my shims on the caster blocks to kind of reduce that turn in just a little. it was soo dramatic, that I had to let off into that corner, not to scrub speed, but just to let the car settle. going full power into that turn would put me too close to that inside board.
everywhere else I like the car, it gave me enough to drive it hard in the turns, but if I needed to slide under someone I could turn a little harder without loosing too much speed
#58
This sounds like its going to be better than the first with all you guys getting ready know it will be awsome. I cant wait to strap some ponys in Tims car again, he will be tuff to beat, well i mean for an older guy! I had a blast in San Antonio even though it rained, I look forward to doing it again. Their is another race im looking at going to in december if any ones interested, its the 8th,9th,10th in Blue springs, Mo the flyers on their home page www.fastlanehobby.com you get to bring your own motors It sounds like fun, Let me know what you think. Jeremy
#59
I'll have to see if I can get the time off for the race at fastlanes. I have raced there before (it was for the region 8 regionals) and had a good time. I'm up for the trip if I can get the time off and I should be able to get it.
The track is smaller than Mike's but the traction came up really quick and I got to race with some pretty good drivers. Some of the St Louis guys made the trip, maybe we'll be luck and they'll show up again for some more fast racing.
L8R Steve
L8R Steve
