LIGHTSPEED PRODUCTS
#166
BATTERY SALE
Hey guys running a battery sale IB4200wc on 2 or more packs for 48.99 while supplys last...Thank you Ron
#169
4 and 6cell num.
i have 500 to 540 run time and 1.225 to 1.240+ on the voltage depending if your running stk or mod.makeing room for more batteries on the way.so iam passing the saveings on to the racer.you can contact me at [email protected] as i only check the boards at the end of the day...Thank you for choosing Lightspeed Products.....
#170
for eric w
all batteries are loose cells and require assembly.assembly kits av. for add. cost.Thank you Ron
#172
batteries
the packs for 48.99 are 6cell,,and the packs for 30.99 are 4cell...Thank you Ron
#173
ron,
do you do 1/18th motors?
chris
chris
#174
8x1 coming your way
Hey Ron,
My 8x1 cobalt drag motor went back to you USPS Class A mail Monday. It should arrive your location today. Please check it out and advise.
It has four runs with 8cells on it: First two runs came in at 2.868sec E.T. and 45.1mph; 2.85sec E.T. at 45mph.
Next two runs the car began experienceing radio glitching and an unexplained reverse backup. Drag cars don't take to backing up, so I replaced the Lightspeed with my other motor - a NEO magnet can 10x2 flat wire. Come to find out my ESC has a double pump brake /reverse feature I didn't know it had. I now suspect the 8x1 was performing O.K., but check it out any way and let me know. Please etch a zero degreee timing mark for me as the end bell is one 180 out from when I got the motor from you. I need a set of HD springs too. How do the brushes look? They are the hard serrated you asked me to try instead of the high silver content.
Regards,
//AC//
Regards,
//AC//
#175
8x1 motor
Hi ac,yea sent it out yesterday.you should have it before the weekend the springs you put on the motor was causeing the motor to get hot it was brush bounceing i put a little harder spring on it.trued com.com is 282 when com gets down to 250 or 260 i would sell it or keep it for a back up i retarded the timeing a little so it would act like a new motor..i allso got my 6t sin. and doubles in if you are wanting a sick motor my drag racer guy in cali. is testing it in a rail he said it was the fastest 6t he had ever run.and he holds track record at all4 of the tracks with it ...Thank you Ron
#176
1/18 motors
sorry guys not doing 1/18 motors not a big enough demand..thank you Ron
#177
BATTERy SALE
Hey guys and gals battery sale ends wend. 2-7-07..then they go back to reg. price getem before the end tomorrow...thank you Ron
#178
#180
the website was down. i talked with ron on the phone and ordered some packs. but i forgot to ask about the 1/18th packs!!
