BANZAI Motors
#1922
Thanks Casper, and SOOOOOOOO glad you're home!
Now I can stop worrying about weather!!
My guess is J97 may need help with gearing more than
set-up. These tight tracks seem to throw everyone off
in the gearing department. Might want to post what you're
running the monster in J97.
Judi
Does anyone know where the Sizzler is for the Cactus??? YES,
I will be making the trip this year!!!!!
Judi
#1923
Sweeeeet.... It's good to know that our Mom will be there...
#1924
You running a truck or buggy and what brand AE or Losi? Monsters are not the best motor for tight tracks as they have tons of RPM. Black (p2k2) or Blue (CO27) motors are better on tighter tracks as they have more natural torque. Monsters (green) can work though. So Cal is a pretty tight track with better then average traction and people have had good success with monsters. You just need to gear them down low enough.
#1926
Oh after I rebuilt it I hooked it up to my charger to break in the brushes. Everything was fine but when I installed it in my car and turned it on nothing but smoke came out. I had to take it apart again and found a half inch piece of metal wire inside. How that get in there I thought Thats the second time I have had that motor smoking.
#1927
It's hard to tell exactly what happened to it without looking at it, but it might be a good idea to drop that one by the shop to have a look. Where did that missing shim go? If it was floating around in the can, it can do all kinds of wicked things.
Scott
Scott
#1928
im running it in a bk1 1/2 18/82 is where i was last time but i was going to start with 20/82 this time. I have 2 co27's but they dont have real good rpm's one is 21,203 with 100.2 on the torque.the other is 20,874 with 101.0 on the torque. but the last time i raced there i could keep up with the big guns in the techinical part but got whooped in the 50 ft strait by a car lenght or more!The only reason i wanted to run the banzai was for the rpm. am i looking in the wrong place for top end?
#1929
Banzai mom, Thanks for the motors, got them in todays mail.
Which just happened to be right after round 2 of quals today.
Keith had stopped by with some batteries during the first round so I did not run.
But After round 3 was over(and I was killin them with the Banzai Blues),We sold all the stocks, except one.
Checks in the mail
Checks in the mail
#1930
I gear 20/78 with the Banzai Blues with the Gen 1 tranny. Go to a 21 with athe 82 spur. The Monster I would not go higher then 20/82 as they will over heat and fade really bad. I usually gear my motors for the infield. You will make up more time in the infield clearing all the jumps and getting out of the corners faster then winning the drag race down the straight. You may want to try 19/82 with the monster to see how it feels. It should be better in the infield and still let it wind out in the straight for the top end you are looking for.
Downtown-- Let us know when you get a chance to run those new EP cells. I am sure you will like them!
#1931
Will do Casper.
Lookin forward to trying them in the new x-6 tomorrow.
#1932
last time i will bother u casper i am running the panther switch rears they are the soft compound and love them do u run the stock foams or others?
#1933
J97--You can bother Casper anytime, he's a gluton for punishment....
#1934
I have tried the stock white foam. I think it is a little soft. I liked Bomb 1 Better. If you have lots of traction you may want to try proline grey white 2 stage.
As Keith mentioned. I like to answer questions so ask away. The only dumb qustions are those that are not asked!
#1935
HAY MOM IS THE VAGES TRACK ON THE BABCOCK THIS YEAR
