Diggity Designs Custom R/C Components
#1384
I went to the track for there first practice day today on carpet and decided to dust the Cobb webs off of the dc4 le for opening a case of whoop ass on everyone else running 17.5. The car drove extremely well today. I will post a setup in the next couple of days but the big thing is I did a little machining on my mill to the lower chassis to narrow it 18mm and drilled and slotted for the use of a shorty pack. Using a shorty pack brought the race ready weight down to 1309g so now weight can be added to get the balance where you want it without the worry of being quite a but over weight. Here are some pics.
On another note if anyone would like the same thing done to there dc4 le chassis' please p.m. me I would be happy to do it but we can go over details via p.m.
#1386
Taking notes here..... I did remember suggesting skimming down the chassis a while back.... Good to see positive results !!!!
If you were using a Protoform lightweight(90gram) body, give the (60gram)blitz gsf 0.5mm body a try, with a thunderpower shorty pack, and a gforce supercapacitor...
Your lap times will fall.....
#1387
Jeff,I understand the shorty pack thing.......What was your reason for narrowing the chassis 18MM and not moving anything to the centerline of the car.....Just asking.....Doug
#1389
#1390
No problem Jeff.... I think Amain hobbies has the GSF 0.5mm in stock.... You should be lapping the field twice with that body...lol....
#1391
#1393
Are you planning to upgrade the Nanotech shorty pack ???
From the pictures, I can tell you don't have an aluminum screw set installed, and I suspect the bearing shields were not removed,the driveshaft is not CF,etc..... That car can go way faster cheap...just sayin....
Ps: Putting the tc4 on the podium is all I care about ! BY ANY MEANS NECESSARY !!!!!!!!!!!!
