Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-18-2014, 07:00 AM   #1351
Default Top Racing Rebel 12 - 2mm Carbon Fibre O-Ring Battery Holder
This new Top Racing Rebel 1/12 O-Ring Battery Holder is really cool.
if only if you can build a version for Yokomo R12.
Any plan for that ?
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 02-03-2014, 07:13 AM   #1352
NutDriver's Avatar
Trader Rating: 14 (100%+)
Is the DC4LE off of the year end sale now? The sale price seems to be gone from the site and I don't see them listed on Ebay anymore.
scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 02-27-2014, 07:48 PM   #1353
Schs2013's Avatar
The DC4 LE is my next step in upgrading my TC4! from what i hear its worth it.
VBC Lightning 10LM, Tamiya M05v2
Losi TEN MT, Traxxas 1/10 Summit LT, Vaterra K-10
-Marc Gill
Schs2013 is online now   Reply With Quote
Old 02-27-2014, 07:53 PM   #1354
Schs2013's Avatar
-Marc Gill
Old 03-21-2014, 07:17 AM   #1355
NutDriver's Avatar
Three weeks without a post. Anyone been racing their DC4LE? I know Dumper has signed a contract recently and I expect he is busier than before. I was hoping to see a setup sheet from him.
USVTA member #111
Old 03-21-2014, 11:14 AM   #1356
Smile
+1
THEBIGBULL is offline   Reply With Quote
Old 03-22-2014, 09:57 AM   #1357
NutDriver's Avatar
OK, a serious question for the DC4LE owners out there. I have a 60 tooth spur and a 35 tooth pinion on my car. I have the aluminum rear suspension blocks as well. My problem is being able to access the lower screw used to mount the motor. The procedure that I did last night was to set the gear mesh and tighten the upper (non-sliding) screw to hold the setting, then take off the pinion gear so that I could get to the lower screw with a long hex wrench going above the RR suspension arm and under the half shaft.
I don't want to grind on my pretty blue suspension mounts and I don't have a 2mm ball-end hex driver (yet).
Suggestions on spurs, pinions, techniques and/or processes?
Scott
USVTA member #111
Old 05-25-2014, 02:22 PM   #1358
Smile Re...asphalt setup
Nothing on this site for 2 months....Any one have a good asphalt setup for 80'X140' fairly open track. Nutdriver....I bought a long shank driver 5/32 for the Associated motor screws. I am able to get to the bottom screw by lifting the RR susp arm but it is a pain the butt.
Old 05-25-2014, 05:57 PM   #1359
NutDriver's Avatar
Thank you, BigBull. I was hoping Dumper would have a good setup out, but he signed some new deals and may not have time. The track where I race is reasonably small, indoor, and carpet. Not sure I would be much help.
USVTA member #111
Old 06-13-2014, 10:56 AM   #1360
Diggity's Avatar
Trader Rating: 29 (100%+)
Sorry no posts lately... We have been very busy this summer. I have not had time to do much testing with the DC4, our indoor track closed for the summer and we do not have a local outdoor facility to race on. I was really hoping that other DC4 drivers would chime in and keep the forum updated with setups.
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 06-13-2014, 11:49 AM   #1361
NutDriver's Avatar
I just bought another to run into VTA, as well as the one for USGT. Can't say that mine will be very good, but I'll share.
USVTA member #111
Old 06-23-2014, 10:18 AM   #1362
NutDriver's Avatar
Ran my car in USGT trim for the first time yesterday. Had been running a 60t 48p spur. Was having problems gaining access to the lower motor screw, so I went to a 66t spur. This helped a great deal. I wish Damon would've made the motor mount with the sliding scre on top. I may work on changing the chassis to a eccentric cam, like the stock TC4.
USVTA member #111
Old 06-26-2014, 03:16 AM   #1363
Airwave's Avatar
Hello everybody... As many parts seems to be compatible between TC3 an TC4, would it be possible to use the DC4LE on a TC3 basis? (Sorry if this question has already been answered)
Parts that are compatible. Drive shaft, motor mount, diff boxes, bearings, roll bars, diffs, shocks, springs, shock towers, CVD's, ball cups, chassis braces, steering knuckles, rear hub carriers, drive cups and wheels.
Airwave is offline   Reply With Quote
Old 06-27-2014, 09:46 AM   #1364
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
hello, I would say yes but I think that the arm mounts on the tc3 may have a different hole spacing for mounting to the chassis. and also the steering rack wont mount so you for sure would have to change out for the tc4 dual bell crank system.
jeff jenkins is offline   Reply With Quote
Old 07-08-2014, 10:12 PM   #1365
DesertRat's Avatar
I just wanted to post my car with the aluminum TC3 steering rack mod. I was unsatisfied with the stock plastic steering bellcranks and the large amount of slop it had, preferring the aluminum rack. All the mod required was two carefully drilled holes, and I think it would be cool as hell if Diggity would consider measuring out where sliding rack mount would be placed and include two countersunk holes for the rack posts
Other than that, the car has been good. I will likely keep it for a long time. Shaft drive is just kinda fun somehow, and the TC4 chassis just wouldn't cut it.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is online now   Reply With Quote
FS: Diggity designs 18t! KleinSprizzle23 R/C Items: For Sale/Trade 5 01-04-2008 03:05 PM
Diggity Designs knapster Electric On-Road 20 02-14-2006 10:43 AM
Diggity Designs XL-R8 academygaz Electric On-Road 3 05-11-2005 07:46 AM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 03:33 AM
