Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-18-2011, 04:24 PM   #1216
Robert421's Avatar
Originally Posted by Diggity View Post
As of now there are no plans to produce a new motor mount. If you are and can be a little bit of a hobbyist, then I would recommend using a dremel and grinding out enough of the slot in the motor mount to get a couple more teeth on the motor. I know of a couple drivers that have suggested this to me. Thought Ide let you know.
Digs
I know that you do not have plans to produce a new motor mount, but with brushless motor requirements, it only makes sense to give the public what they want.
Associated TC4 stock
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Robert421 is offline   Reply With Quote
Old 01-19-2011, 11:50 PM   #1217
Trader Rating: 22 (100%+)
are you guys coming out with a new version of the inline conversion kit for the associated 1/12 scale ? could i special order a conversion kit or can i buy all the parts separately to make one ? thanks
thefnshow is offline   Reply With Quote
Old 01-21-2011, 12:58 AM   #1218
Diggity's Avatar
Trader Rating: 29 (100%+)
Bob,
I know we have talked about this and it sounds like you are planning on taking charge on this.
If I had more racers asking for this option then it is something I would think about doing, but when only about 4-5 racers need this option then it would cost way too much to produce something that will not be necessary at this time.
Keep me updated on the motor mounts that you are working on.
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 01-21-2011, 01:00 AM   #1219
Diggity's Avatar
Im glad there are still racers interested in our 1/12th products, they were some of our favorite projects. At this time we are not planning on any updates, we might work on something for the fall carpet racing season. Check the website for any updates.
Old 01-21-2011, 05:06 PM   #1220
an inline 1/12 scale is something i've always wanted
Old 03-25-2011, 08:26 AM   #1221
beemerfan's Avatar
Trader Rating: 34 (100%+)
Bob,
I think the need for expanding the mounting holes is mute now. Robinson is making some very small spurs with some very large pinions in 64P. A 73 tooth spur with a 50 tooth pinion would have a final drive of 3.65:1. That ought to be low enough for any situation and I'm pretty sure it would bolt right in. I spent way too much time in the past modifying my TC3 motor mounts to fit big 48P pinions only to discover these newer 64P pinions/spurs negated the need for anything I did.
beemerfan is offline   Reply With Quote
Old 03-25-2011, 12:45 PM   #1222
Robert421's Avatar
Default motor mounts
Damon, no problem. The mounts that I worked on are doing fine with the FDR using 48p gearing. I think that 64p gearing could also be used to acheive the FDR that a racer wanted with the old mount.
Thanks for the carbon fibre, I will put it to good use. The season is coming to an end next month, so I will be working on the chassis this summer for next season.
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 04-06-2011, 02:57 PM   #1223
Diggity's Avatar
Default Diggity Designs Battery Strap for the Losi Duce Duce!
We have just released our 2.5mm Carbon Fiber battery strap for the TLR 22. Standoffs and 4-40 mounting hardware is included. Brace is triangular shaped to place more surface area on the battery and can be flipped over and mounted either way to accommodate the different lipo pack sizes. Some pics are below as well as a link to where you can find it.
http://www.diggitydesigns.com/D3_Los...teryStrap.html
Old 04-06-2011, 03:08 PM   #1224
Diggity's Avatar
Default Diggity Designs Parts for TQ Racing
Diggity Designs offers a couple of performance upgrade parts for the TQ racing SX10 and SX10T. 4mm shock towers for both vehicles along with a raised front tower for the SX10T that will allow you to mount up the JConcepts Punisher and Protoform Bulldog bodies with ease. Both rear towers have the optional 4th hole mounting position. Some pics and links -
SX10 -
SX10T -
http://www.diggitydesigns.com/D3_Off...oducts_TQ.html
http://www.diggitydesigns.com/D3_Off..._TQ_Truck.html
Old 04-06-2011, 06:36 PM   #1225
bring it on's Avatar
very nice
Toro ESC - SkyRc - Caster Racing USA - Pr Racing USA - Gens Ace - Ares Motors - Highest Servos - Radiopost
Thanks to my sponsor at crpplus.com
bring it on is offline   Reply With Quote
Old 04-06-2011, 07:51 PM   #1226
rob martin's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rob martin
Lovin it. Nice work. Def picking up the towers
SX10 -
SX10T -
Rob Martin~
~Ridgeway bodies~B-Fast Performance Diffs~Flying Farmer Traction Sauce
rob martin is offline   Reply With Quote
Old 04-11-2011, 11:00 PM   #1227
Diggity's Avatar
Originally Posted by bring it on View Post
very nice
Hey Rick,
Good to see you on here!!!
Old 04-11-2011, 11:02 PM   #1228
Diggity's Avatar
Hey Rob,
Sounds good bro... The raised front truck shock tower is the bomb for running the new Punisher and Bulldog bodies on the TQ....
Old 04-12-2011, 07:48 AM   #1229
I have had diggity shock towers on my caster e-buggy for over 6 months now with out any breakage. Last month i even went to the nitro pit nitro challenge in AZ, one of the biggest and toughest tracks in the USA. Diggity's stuff is top notch.
http://www.youtube.com/watch?v=zRsuSo6HKfo
Old 04-25-2011, 02:48 PM   #1230
Doodad's Avatar
Send a message via Yahoo to Doodad
Guess who's back.
Doodad is offline   Reply With Quote
FS: Diggity designs 18t! KleinSprizzle23 R/C Items: For Sale/Trade 5 01-04-2008 03:05 PM
Diggity Designs knapster Electric On-Road 20 02-14-2006 10:43 AM
Diggity Designs XL-R8 academygaz Electric On-Road 3 05-11-2005 07:46 AM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 03:33 AM
