Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-29-2009, 12:29 AM   #1156
Diggity's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Masterofpuppets View Post
Diggity......I have emailed you 2 times and have received no reply yet...........
I reply to all emails, who is this?
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 12-13-2009, 03:12 PM   #1157
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default Brushless 1/12
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 12-16-2009, 10:00 AM   #1158
turbomeyers's Avatar
you should do a 200 mm conversion fo the xlr8 v2 , i find my 1900 mm bodies dont fit as good as they do n a stock tc3 .
Chris Meyers
Clutch Nutz R.C. Club Of Red Deer AB. Canada
Prop Busters R.C. Club Of red Deer
turbomeyers is offline   Reply With Quote
Old 12-17-2009, 03:24 PM   #1159
SSS Racing's Avatar
Hi
Do you have the Flexy upper decks in stock for the B44? Need front and rear decks.
Just wanted to know before placing order.
Ryan
SSS Racing is offline   Reply With Quote
Old 12-20-2009, 03:24 PM   #1160
Scottrik's Avatar
Trader Rating: 241 (100%+)
All right, I'm ready to try this again...
I ran my XLR8 conversion at our Regionals in Stock Rubber in March '08 and found the car to handle, accelerate, etc very well. The only problem (and it was a biggie) was that the outboard hinge pins on the rear arms walked their way out EVERY heat. Machined a couple Jaco spec tires/wheels into 2-parters from the inside like the pin was a dull parting tool. This was frustrating enough that I parked the car on the shelf since.
The front arms have holes for the 2-56 screws to capture the pins but the rears, oddly enough, do not. Nor do the spare set of arms I've got.
Over a year and a half on I want to get the car back on the track. My intent is to set it up as a Vintage TA car where we still support 4-cell formula locally. What do I need to do to keep the darn hinge pins from walking out? Worst-case I can drill and tap the rear uprights to use grub screws to anchor the hinge pins in place like we did on our RC500's "in the day" but to really do that properly I should put Helicoil inserts in there as well and I'm not "jazzed" about doing that either.
Am I the only guy who's struggled with this?
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 12-20-2009, 05:11 PM   #1161
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
try emails,i sent a pm and email in sep with no response,but what i wanted was no big deal so i let it go,but i would shoot him a couple
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is online now   Reply With Quote
Old 12-20-2009, 07:44 PM   #1162
KAHUNA's Avatar
Cool
eazy fix - remove them - then add one maybe two drops of thin CA run the length of the pins , try after first drop drys . may need second drop - let them dry complete . they are good and tight , you won't need set screws . I did this when I first put the car together . Haven't had one move / come out yet ! I think it is a good car for VTA racing !
If you need Damon you need to email him . . . .
Good Luck !
Team Scream Racing Middle River Hobbies GQ AMERICA Diggity Designs Castle Creations ✦TheRCShack✦ www.castlecreations.comwww.teamscreamracing.com www.diggitydesigns.comhttp://www.gqproduct.comMini www.middleriverhobbies.comTom Brown The Rev 7 XRAY ✦ M05 Surfs Up DudeMiddle River Hobbies
KAHUNA is offline   Reply With Quote
Old 12-20-2009, 07:57 PM   #1163
Scottrik's Avatar
And that doesn't cause binding in the arms themselves where they need to pivot freely? I'll give it shot.
Still seems odd that they'd drill and tap the front arms (front and back!! Couldn't make a near "blind" hole like the TC5, etc) for the capture screws but not the rears. Ah well. Kind of a weird oversight for such an otherwise well-executed conversion. I tell people it's the car Xray would build if Xray were building shafties.
Speaking of shafties, and to your point re: VTA, I think shaft drive and front spool are THE ticket for such a power-limited class. These put the power STRAIGHT down to the track. No muss, no fuss, no backlash...just GO!!
Old 12-27-2009, 09:04 PM   #1164
xl8er's Avatar
dose anyone know if i can use my spool and oneway with the v2 kit on my
tc4.
xl8er is offline   Reply With Quote
Old 01-11-2010, 10:10 AM   #1165
i have a xlr8 v2 nib for sale 150 bones , pm me
Chris Meyers
Old 03-01-2010, 05:54 AM   #1166
jw_rooster's Avatar
Just got my shipment of CF parts for my GV2. These parts look great and have super fit and finish!! Excellent job Diggity Designs!! I can't wait to get to the track for testing.
jw_rooster is offline   Reply With Quote
Old 03-01-2010, 05:59 AM   #1167
jw_rooster's Avatar
Take a minute or 2 to go to this link and vote for Diggity Designs to be a part of NASCAR
http://www.sponsafier.com/share/105819
Old 03-08-2010, 02:58 PM   #1168
jw_rooster's Avatar
First race with the new CF parts went well. The 4mm rear shock tower that is slightly taller is great on the GV2. I noticed a quicker reacting car in the corners and it had a more direct jumping feel. I would sudgest any GV2 owner look into these quality upgrades!
Old 03-13-2010, 03:01 PM   #1169
Send a message via Skype™ to Rich Roberts
Hey Diggity,
Do you still have this kit/upgrade in stock XLR8-V1?
Have sent three emails and had no response. maybe somethings not getting through, so thought I'd try you here.
Also would be very interested in a Rally kit 200mm. Originally got in for the T/A racing and am pretty new to it but found others talking about this Rally kit TA used to make. Sounds like even more RC fun.
thanks
Rich Roberts is offline   Reply With Quote
Old 03-15-2010, 10:13 PM   #1170
Diggity's Avatar
Hey Josh, good to see you in the Diggity forum... Your hardware will go out today (tuesday), was pretty busy on Monday..
Keep up the good racing and repping Diggity products
FS: Diggity designs 18t! KleinSprizzle23 R/C Items: For Sale/Trade 5 01-04-2008 03:05 PM
Diggity Designs knapster Electric On-Road 20 02-14-2006 10:43 AM
Diggity Designs XL-R8 academygaz Electric On-Road 3 05-11-2005 07:46 AM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 03:33 AM
