Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-12-2007, 10:28 PM   #406
Diggity's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ShrekNZ
Looks good the old one tends to blend into a body qite a bit.
We are running CD12 on both Carpet (Astroturf) and tarmac and ran on tarmac for the first time last weekend. However we gave up after a few runs as traction was a real problem (dust on the track was a problem) and in NZ we don't use tyre additive.
Any ideas of a starting point
we are using
Associated Silver (blue) center spring
White Side springs
300 Much More Shock oil
10,000 Mugen oil in the dampners
Kawada 25 rears (we have found these work best in the low grip with no compounts)
Kawada equlivent to purple on the front
0.20 Front springs
A little over 3.0mm ride hight all round
Using a V2 9 single
Bascially the same as we ran in the L4 donour but no t-bar is kind of different.
Any pointers would help thanks.
Well you can soften the whole car all around to get it to gain traction... If your problem is oversteering and spinning out then you will want to make the front end harder and soften the rear (you can use harder front springs, less aggressive caster, less dampening and shock oil, harder front tires, softer rear tires, use blue rear side springs, use a softer shock spring, and batteries positioned to the rear) If the problem is that it pushes then you would do the opposite (use softer front springs, softer tires in the front, harder in the rear, use harder shock oil and more dampening, use the red side springs, use a harder shock spring, batteries positioned to the front). If you can explain in better description on what was making it lose traction then I can get more in dept! If all the cars on the track had the same problem then Im guessing that its the surface?? 3mm ride height is quite low for asphalt and I would assume for astoturf also, try running about 3.5 to 4mm ride height..Let me know..
Damon
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 03-12-2007, 10:56 PM   #407
ShrekNZ's Avatar
Thanks for the reply we were mainly having rear traction problems but the track was really dusty which I think was part of the problem (I'm just the mechanic here)
One other question when we push down a rear body post it will lift a front wheel - is this something to worry about or is a mismatch between the center spring and side springs. Sorry for the noob questions just finding this car a little different to the old L4.
Yep first race this Saturday on astroturf so we will get an idea of how it goes
ShrekNZ is offline   Reply With Quote
Old 03-12-2007, 11:30 PM   #408
Diggity's Avatar
Lifting a front wheel when you push on the rear body posts is perfectly normal! If you follow the tips in the last post for the rear traction then you should be set, definately let me know how it goes!! and make sure they blow off any dusty tracks with a leaf blower or something that should help some, possibly ask if you can spray grape soda in the corners and that will help allot also!
Damon
Old 03-13-2007, 06:32 AM   #409
Dave G's Avatar
Damon: I really dig...(no pun intended) the new logo, I think its a little hard to read though. I will take a stab at it myself later on... Hope your getting some sleep and enjoying your new child. Talk to you soon!!
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline   Reply With Quote
Old 03-13-2007, 06:34 AM   #410
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Damon,
The car was great down at CEFX.....WOW thats A LOT OF TRACTION!!!!!!!! Had to glue both front and rear tires. My CD12 was dialed though. I though I did pretty good with 8 Month old batteries and James Brink power plant!!!!! I wanna thank Terry Rott for hookin' me up with the new speedo after mine went nuclear banana on me. yeah my car was dialed if i had some good batteries i could have been at the top of the B!!!! I was the only Diggity designs driver that got 43 laps woot!!! maybe i'll see you on saturday?? I have all my touring car stuff ready for you...
Congrats on the new addition to the family...
Max K
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 03-13-2007, 05:35 PM   #411
Trader Rating: 32 (97%+)
lol max, hey thanx for letting me by in the main, that was cool. even though i did the best out of the diggity team, and got the fastest lap, i wont brag, lol. man the traction at cefx was wicked, no tration one minute then traction rolling the next, crazy. never take the glue off youre frt tires, EVER. well, ill see team diggity at the local this saturday. but leave the teeth on my spur k max? lol. fasha fasha fasha.... fasha can u hear me.... fasha fasha fasha, lol, a little inside humor.
john "apple" mcintosh, Roar onroad national champion, Roar region 5 champion.
www.modxrc.com.com www.diggitydesigns.com www.rcproductdesigns.com
www.robinsonracing.com www.gsracing.com www.fioroni.com Apples paints
Apl Hed is offline   Reply With Quote
Old 03-13-2007, 05:37 PM   #412
dialed
Old 03-13-2007, 06:12 PM   #413
OMG!!!LOL I re-watched that movie. I thought you were crazy, but now i can see your nuts....ah thank you
I think that Mo payed me back in 19turn...
Max K
btw: nice sig
DIALED
Old 03-13-2007, 06:40 PM   #414
KAHUNA's Avatar
Cool HOT DIGGITY
Digs I like the flames and the D's looks like cat eyes ready for attack !
I'll take some of them with a few parts that I'll be ordering please ! - - cool !
Also the package was delivered to are secret agent Nano !
Team Scream Racing Middle River Hobbies GQ AMERICA Diggity Designs Castle Creations ✦TheRCShack✦ www.castlecreations.comwww.teamscreamracing.com www.diggitydesigns.comhttp://www.gqproduct.comMini www.middleriverhobbies.comTom Brown The Rev 7 XRAY ✦ M05 Surfs Up DudeMiddle River Hobbies
KAHUNA is offline   Reply With Quote
Old 03-13-2007, 07:33 PM   #415
Max K
btw: nice sig
DIALED
lol i love gold, the tashte of it, the shmell of it, the texshture.
Old 03-14-2007, 01:20 PM   #416
hehe, """""Minus 22"""""""
Anyway....Im ready for nitro season! All this nice weather is great.
Digs,
That race sounds like fun....if its an invational then you kinda have to be invited right??? I wonder if i could get out of school again??? hehe maybe. When and where is it?? LMK
Max K
(DIALED?????)
Old 03-14-2007, 06:04 PM   #417
Digs,
Max K
(DIALED?????)
WHAT!!!!??? i didnt have any CORN!!!??? lol
I left a floata!!!!!
the invitational is in cleveland at the gate, and the "invitational" part is its own class, for the pros that earned it, somehow i dont know. but anyone can sign up, just the ppl that were invited will be in the invited class. ill just run the 1/12 normal joe class. i thank you, lol.
Old 03-14-2007, 06:06 PM   #418
oops i forgot........
d i a l e d
Old 03-16-2007, 08:03 AM   #419
Diggity's Avatar
Max: Its called an invitational, but they are running an open class also for touring and 1/12th scale. I just really wany to go since I missed the Nats..
Apl: "Jimmy John" is that Dialed or more like this Dialed?
Old 03-18-2007, 10:26 AM   #420
Diggity's Avatar
Had a great time at our local track yesterday!! It was good to get back out after a 4 week break.. I had fun trying to beat Terry and James, I was right there!! I wanted to say great job to Jason DOODAD and Max as they were really strong in the A-main also!! Seems like the new D12 cars have helped turn you both into some fine drivers!! The article about the 3D12 in the April issue of Extreme RC cars is pretty cool, its neat to get a little recognition!!
Damon
FS: Diggity designs 18t! KleinSprizzle23 R/C Items: For Sale/Trade 5 01-04-2008 03:05 PM
Diggity Designs knapster Electric On-Road 20 02-14-2006 10:43 AM
Diggity Designs XL-R8 academygaz Electric On-Road 3 05-11-2005 07:46 AM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 03:33 AM
