Diggity Designs Custom R/C Components
#151
Originally Posted by rm25x
I don't have any plans of running a touring car body on mine.
Rob: Great Props bro... been getting a few calls and purchases from guys that have talked with you and seen you running your XR18 kit! Must be layin it down Keep up the good
#152
R/C Tech Elite Member
Originally Posted by Diggity
Chris: There is no toe-in built into the rear arms, the kit should have came with a 0deg block for the front and a 1deg and 2deg block for the rear. So if you are aiming for 2deg then you should be able to just use the 2deg pin block.. If you dont want the arms to be at an angle then you will just want to run either a 1deg block with 1deg Losi hubs or another 0deg block with 2 deg Losi hubs.. I hope that helps
#153
Been sporting it on all the major forums. If anyone wants to see what everyone has had to say on one18th.com, check out this link. Its one of the biggest forums for micro racing.
http://www.one18th.com/forums/showth...d=1#post308745
#154
D12
Damon,
How does the D12 do in 19t and modified? Because if i'm right Terry R said that t-plate cars handle the speed better than the piviot ball cars in the 19t and modified classes.
Max K
Max K
#155
What's up Max? Long time, no see! Not to speak for Damon, but the T-bar cars tend to be stiffer in the back, allowing for higher speed cornering. Damon and I were messing around with different weight oils in the dampers. We put some 30,000 weight diff lube in them and the rear feels just like a t-bar. The D-12 will have no problems with 19t or mod.
P.S.- When we gonna see you at Barstools?
Jason
Jason
#156
Jason
Jason
LMK if you need any bodies painted!!
Max K
#157
Max,
Jason is right the D12 is good in 19 turn. I only got to run my car once last year before they closed the track, but it was pretty good.
As for t-bar vs. link cars, that debate will probably go on forever. Each person has their favorite. The t-bar car is good on smooth tracks but is more likely to break. Link cars are better on bumpy tracks and very durable(no t-bar to break). Both cars are winners.
Link cars 1-2-3 1/12th mod at Cleveland
T-bar won snowbirds and nats on carpet
both cars in A-main at the worlds.
So, yeah the D12 will work for what you need.
Larry
Larry
#158
Max- Nobody has been running 1/12 at Barstools, anyway. We're having a good time running TC, though. Glad to see you're doing well with the MARS races. And yes...I'm Cleveland bound come Thanksgiving.
Larry- Thanks for clearing that up. Seems to be more of a personal preferance than anything else.
See ya'll soon!
See ya'll soon!
#159
Max: Sounds like you have been haveing fun this summer with some Diirrt! Youre not missing much action as far as indoor onroad goes here bud.. Barstools seems to help pass the time, but damn I cannot wait much longer for a good track to open... Ive heard a couple things through the grapevine but nothing set in stone.. As far as T-bar and Pivot ball cars, I would think that pretty much what Oppie said is right on.. As far as the D12, I think it has a different reaction than a pivot ball and a T-bar car because its not a pivot ball or T-bar car. There is also a center spring wich acctually acts like a small shock.. Didnt you see me rippin on Terry R the first time out with the kit?
Oppie: I got the hook up for you to win at Cleveland
Ran the XLR8 this weekend with a stock for the first time in a loooong time, and it was insane!! Got a good mote off of my man Denny and that was it.. fastest car on the track no doubt, and there were 3 xrays that are always fast!
#160
I guess your right, you were beating Terry R. The D12 does seem like a pretty kool car. but i guess i'll stick with my CRC car!!! Unless you got a better deal for me.
Max K
Max K
#162
Cant wait to try out my new XLR8, Anyone have any good tips? Almost finished building it
#164
I picked up the kit to build the stadium truck for the winter. Need a chassis setup for it. LMK.
#165
Max: Youre not missing much action as far as indoor onroad goes here bud.. Barstools seems to help pass the time, but damn I cannot wait much longer for a good track to open...
