Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-07-2006, 04:44 AM   #136
wow thats different.
rm25x is offline   Reply With Quote
Old 08-07-2006, 10:43 AM   #137
Diggity's Avatar
Trader Rating: 29 (100%+)
Rob: Yeah its a little different, but when we first got our RC18T's thats the body we used for onroad carpet. It acctually helps keep the car planted and when we run them on tight coursed it helps keep everything under the body. Its like a mini 1/12th scale Its the same body we are using in the videos below... Im still looking for a touring car body to fit, even asked Parma to make one with us funding it but they never returned our emails? If anyone knows about a touring body that might work let me know..
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 08-07-2006, 05:32 PM   #138
What about HPI's mini bodies for the Mini RS4 series?
SPECS: Length: 15-1/4" (387mm)
Width: 6-1/8" (156mm) (at center)
Height: 4-3/8" (111mm) (un-cut)
Wheelbase: 8-7/8" (225mm)
Thickness: .03
Old 08-07-2006, 07:20 PM   #139
XrayFK's Avatar
Maybe this:
http://www.speedtechrc.com/store/ebp...nid=412&id=791
XrayFK is offline   Reply With Quote
Old 08-08-2006, 12:18 AM   #140
Diggity's Avatar
Rob: I think the RS4 series has too small of a wheel opening to fit.. I think the one XrayFK pointed out for the 1/12th yokomo car will work, too bad they are out of stock I will have to see where I can get one.. I think the 1/12th mini Xray bodies will work also?? Thanks to both of you!
Old 08-08-2006, 04:39 AM   #141
yeah for you guys running 1/10th scale tires. Might be just right for the 1/18th foams. I haven't measured to see if it would fit though.
Old 08-08-2006, 11:23 AM   #142
Diggity's Avatar
Rob: Great Job!
I also wanted to post a couple pics and some vids of the XR18 kit that we run here upstairs at the shop. We run with 1/10th touring foams and a Parma Speed 8 body on carpet. Check it out...
VIDEO 1
VIDEO 2
VIDEO 3
VIDEO 4
Some of you have asked me what kind of files .flv are, and they are just flash videos. If you cannot open them in your browser then you can download this free Riva FLV player at: Riva FLV download
Rob: Im going to be getting one of the Yokomo or Xray stratus bodies to see how it will fit. If you get one of the HPI bodies and it fits good let me know..
Old 08-08-2006, 02:20 PM   #143
Conrad's Avatar
Diggity, you might want to take a look at these bodys [click]. They're made in the UK by a company called Kamtec for Mardave V12 cars. They're a very cheap form of racing thats been around in the UK for years, the shells are available in lexan of ABS, the dimensions are listed with each body.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 08-09-2006, 04:44 AM   #144
fathead's Avatar
Quick question, has the D12 V2 got any major dimensional changes over the D12 geometry wise?
What parts are the ones that tend to break (if any)?
Cheers
Damon
Slavich Design
fathead is offline   Reply With Quote
Old 08-09-2006, 08:01 AM   #145
I don't have any plans of running a touring car body on mine.
Old 08-09-2006, 08:49 AM   #146
Cheers
Damon
The only parts that tend to break are the parts that Damon doesn't make. Such as front lower arms, the front lower arms, and the front lower arms. The only time I broke a front arm was my fault, entirely. Shouldn't have been hitting stuff in 1/12 anyways.
Stampede is offline   Reply With Quote
Old 08-09-2006, 11:13 AM   #147
Diggity's Avatar
Cheers
Damon
Damon: great name by the way We didnt make any major dimensional changes. The lower rear links have been shortened and straightened from the V1 for better mounting of electronics to the rear. The bottom pod plate and top pod plate have been redesigned but no dimensional changes. The rear bulkheads have been slid back a little to allow for larger gearing as needed in stock and 19T classes..
Old 08-10-2006, 04:59 PM   #148
CCristo's Avatar
Trader Rating: 55 (100%+)
Damon,
Does the XLR8 have any toe in built into the back arm? If so, how much? I'm aiming for 2 degrees and need to know which losi rear hubs to buy.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 08-10-2006, 05:01 PM   #149
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
chris there is a 1 deg. block an a 2 degree block an a 0 degree block i talked to damon today im gonna try a 0 deg. block with 1/2 toe in losi blocks
DENNIS STORTI is offline   Reply With Quote
Old 08-10-2006, 06:44 PM   #150
Diggity's Avatar
Originally Posted by CCristo
Damon,
Chris: There is no toe-in built into the rear arms, the kit should have came with a 0deg block for the front and a 1deg and 2deg block for the rear. So if you are aiming for 2deg then you should be able to just use the 2deg pin block.. If you dont want the arms to be at an angle then you will just want to run either a 1deg block with 1deg Losi hubs or another 0deg block with 2 deg Losi hubs.. I hope that helps
FS: Diggity designs 18t! KleinSprizzle23 R/C Items: For Sale/Trade 5 01-04-2008 03:05 PM
Diggity Designs knapster Electric On-Road 20 02-14-2006 10:43 AM
Diggity Designs XL-R8 academygaz Electric On-Road 3 05-11-2005 07:46 AM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 03:33 AM
