Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-27-2011, 06:23 PM   #1081
haha, I meant the other Mark. Just come by the shop sometime and take a look at it.
P-Helps is offline   Reply With Quote
Old 02-27-2011, 06:27 PM   #1082
kartermdb's Avatar
Trader Rating: 15 (100%+)
Sure John just send me a pm here or an email to [email protected]. Is Eric going to cut "stiffer" chassis lol. I havent run the car since snowbirds but I am thinking of running it more in the near future.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-28-2011, 10:35 AM   #1083
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Paul Ohlsen View Post
I ran mine for the first time this last weekend. I like it a lot. It looks like I'm running the battery in a little different place than most.
And I should be surprised for what reason?
It looks like I will be down to race Thursday night on road, as I have some "Stuff" to deliver and need to re-set up my on road cars. So bring the WGT car to race.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 02-28-2011, 11:03 AM   #1084
Grenade10's Avatar
Just back from the Super Stock Nationals in Albuquerque, and was able to put the 1/10 & 1/12 Blur's into the A-mains. Nick was there with Johns 1/10 Blur and got it the A-main as well, but his car was a handfull on the track.
Traction was interesting, but somewhat similar to what our track in Denver did back a few years ago. For the WGT race was off from 4th and by turn 2 was in 1st which I stretched to almost 1/2 lap lead when the track started to change and shorted a corner, came out still in the lead, but with 2nd and 3rd on my tail and the car was just not the same. Limped it home to 4th and found that one of the side links broke the low roll center CRC pivot ball.
This is a known issue with these, but I made a change in the height of links for rear traction, and did not do what I usually do in making sure I have the correct size screw so it is just below the top of the pivot. (have been putting a screw in place, marking and then cutting it off just below the mark) With this, I will find the ball has broken off in the side link (I'm using an adjustable link with a closed in top) but it still works as the base is screwed to the ball.
I'm going to talk with Eric this week and see if we can come up with a better pivot to keep this from happening. Saw what is on the Top 1/12 scale car and I like it.
As to the chassis, I'm still running the proto type. Nick was on the new chassis, and not sure if it was his chassis settings or what, but my car was very good, running fast laps with John (runs the track) and Joe Trandel. With a more flexi chassis his car should have worked better for this track. Actually would have loved to try my old I-Fource, as it probably would have been perfect for this track.
1/12 scale car was running good. Not in the class with Kevin Heber, Mike Haynes, EJ Evans, Max Kuening ........ god there were a lot of great racers at this even. Put my car behind Sean Cochran and just tried to keep out of the way, as I was not going to push the car with the traction we had (broke a bottom motor plate in practice). Pulled the car with a min or two left and watched the leaders duke it out.
All in all a very good weekend of racing. ....... Had dinner with Team Associated, ........ spent time with EJ from Top, I like their new 1/12 scale car, .........Kenny Lambert with Tekin, my 13.5's were very fast for this track as I was not motored by anyone in either class. ......... Stealth van was loaded each day going to the track. Also, thanks to Adam Brown for riding with me as it made the trip much more fun than driving by my self and he is the reason EJ was pitting with us.
Off to run oval at the BRL race in Omaha in two weeks and then back to CORRC for our Carpet Classic April 15 - 17. So, Mr Burt ...... how about traveling to Colorado for Thurs - Sunday and doing a factory test .... tune .... Race. I'll cover the room, as I will be staying in Denver for the race.
Old 02-28-2011, 12:18 PM   #1085
Paul Ohlsen's Avatar
Send a message via Yahoo to Paul Ohlsen
I have Thursday off. Ill be down after a parts run to FTC. I need some ride height adjusters for the rear. Im changing the power plant to a Black Diamond and different motor for Montana.
I ran it up in South Dakota between races and broke it.
Paul Ohlsen is offline   Reply With Quote
Old 02-28-2011, 12:59 PM   #1086
Grenade10's Avatar
If all you need is the adjusters, I have 4+ new sets and CDee would have some as well ....... unless there is something else that you need.
Old 02-28-2011, 01:30 PM   #1087
I think thats all i need. I haven't seen chris in a few weeks. I have broken 2 in the last week.
Old 02-28-2011, 02:40 PM   #1088
Grenade10's Avatar
So, see me at the track and if I get down early I'll leave a set at your pit space.
Old 03-01-2011, 02:05 PM   #1089
tim fry's Avatar
Been running my WGT now for a few weeks and its really starting to get good. I'm currently running the cell across the middle which is probably not the norm but I'm planning on running it down the centre for our next meeting. I changed the centre spring to AE gold and this really calmed the car down enough to qualify 3rd and win the A so its definitely on the pace. Just waiting for a few new bits to arrive from E for testing. I will post some pics up.
tim fry is offline   Reply With Quote
Old 03-01-2011, 05:45 PM   #1090
Grenade10's Avatar
Tim, nice job
The battery across the car does seem to work well as it does transfer some weight through a corner. You might also look as moving the esc behind the battery and the battery up against the stand off for the shock mount (same as cener battery) . This works on the carpet.
If you need any other help post here or send me a pm. Always glad to help.
And as Eric puts it, if Mark can get fast this car must be great!!!!
Old 03-03-2011, 12:03 PM   #1091
You should have them any day.
-Eric
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 03-03-2011, 01:42 PM   #1092
tim fry's Avatar
-Eric
Thanks Eric looking forward to some testing.
Heres my car
Old 03-13-2011, 10:59 AM   #1093
tim fry's Avatar
Ran the car today and it performed excellently. I didnt get time to change the battery to down the centre that I planned to do but I did get time to fit the 10 deg front blocks and this really gave the car the turn in I was looking for.
Will be trying some different front end parts next time.
Really loving the car and must invest in the 12th
Old 03-14-2011, 12:24 PM   #1094
Good to hear! Let me know when you're ready for the 1.12 chassis
-E
Team BSR
Team Power Push
Old 03-17-2011, 05:08 PM   #1095
I heard there was a new Darkside 1/12th chassis...have looked back through this thread and on the Darkside website and was unable to find any pics...is there somewhere I can check out what it looks like?
Mafia Motorsports "Carbon Fiber" Pitboard and Motor stand Steve Bahnatka R/C Items: For Sale/Trade 10 10-15-2007 06:03 PM
The "DarkSide" enters nitro tourers! TomB Australian Racing 26 12-24-2006 06:06 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 05:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 09:04 PM
5 BRAND NEW - 3700 MAH EXPRESS MOTORSPORTS "TEAM" PACKS SweetRacing R/C Items: For Sale/Trade 17 05-08-2006 03:12 PM
