Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-11-2007, 09:36 PM   #871
Hey guys I need some ideas...I'm out in Seattle on business and I've been fortunate enough to get some time running at SIR. My car is setup for our outdoor asphault track which is fairly high bite but I'm about a second off the pace here at SIR, an indoor carpet track. SIR has a bit more bite and a lot less tire wear then I am used to but it is also a lot more bumpy in key areas. Traction is good enough to where I can run full compound on both front and back tires and have it handling pretty well. Right now I am running:
Full caster
1.5 deg camber
0 toe
.22 front springs
stock center spring
blue side springs on outside hole
35wt center shock oil
5000wt damper tubes oil
4mm ride height all around
Purple front tires
Magenta rear tires
Now I'm traveling for work so there's only so much I could bring with me, I'm pretty much limited to spring changes so I am thinking on going to the .20 front springs to make it more forgiving on the bumps and maybe the white side springs. I'm not looking to have track record busting laps but would like to get a little closer to the average at least. Anyway do you guys think I'm at least heading in the right direction with these ideas?
Old 11-12-2007, 09:23 AM   #872
I forgot to mention I did pick up a 4200mah pack and it is a good thing I brought my fiberglass battery bracket that I made. My 4200mah pack is the same size as my 3800mah packs so without the bracket the cells would have been sliding a lot. I'm thinking if I rebuilt the packs using the thick plastic insulators on the positive end would bring the pack to the right length to fit without sliding.
Old 11-13-2007, 07:55 AM   #873
Hi, I am having a problem installing my servo in my MX2. The servo is a JR 3550, the problem is that the servo mounts cant go wide enough to except the servo. I can also not shoe glue the the servo to the chassis as the servo saver is to tall. I have seen a nother local racers MX2 with servo installed, they shoe glued it in place put a hole had to be cut in the chassis to accomplish this, I would prefer not to do this. If it matters the JR 3550 servo will be replaced in a couple weeks with JR 3650. Any help would be appreciated.
SMOKESHOW86 is offline   Reply With Quote
Old 11-13-2007, 11:29 AM   #874
If you can find a piece of kydex you should be able to cut it to the same dimensions as your servo. Shoe Goo the kydex to the servo then to the chassis. That should space it up high enough for a standard small kimbro servo saver to clear the chassis.
Old 11-13-2007, 12:00 PM   #875
What is Kydex?
Old 11-13-2007, 01:12 PM   #876
It's a black plastic that used to be used extensively as a bumper
Old 11-13-2007, 02:13 PM   #877
carpet racer's Avatar
Anyone know how I can get in touch with someone from Darkside Motorsports?
Coming soon..the best site for 12th scale carpet racing!!! www.carpetracer.com
carpet racer is offline   Reply With Quote
Old 11-13-2007, 03:20 PM   #878
They often reply here in the thread or you could try the e-mail address from their website.
Old 11-13-2007, 08:53 PM   #879
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
Eric usually checks this pretty often, but I can pass a message along as I will be seeing him within the next few days.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Old 11-13-2007, 09:02 PM   #880
RC_Dan's Avatar
Full caster
1.5 deg camber
0 toe
.22 front springs
stock center spring
Purple front tires
Magenta rear tires
Not sure how big the track is, but here is my basic set up for 19t:
5 deg caster blocks
1.5 deg camber
1 deg toe out
.20 front springs
Silver center spring
White side springs on outside hole, just touching rear pod at rest
30wt center shock oil
4000wt damper tubes oil
3.5mm ride height all around
Black front tires, Jack the Gripper on inside 1/2
White rear tires, Jack the Gripper on all
I have also had luck with same setup, but:
Purple front tires, Jack on 3/4
Grey rear tires, Jack on all
Hope that helps some
460whp CRX on E85
Old 11-13-2007, 09:40 PM   #881
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
hi fellow MX2ers,
how does mounting the side springs affect the car's handling, say moving from outside hole to the inside hole? this is for outdoor asphalt track use. thanks.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-14-2007, 09:45 AM   #882
mtveten's Avatar
Trader Rating: 27 (100%+)
Default SIR setup
InspGadgt,
It sounds like like tires are your main problem, if you have to run full front compound you are running the wrong foam.
At Sir I usually run 2x pink front & rear with anywhere from 25-50% front sauce depending on tire size and grip level. I am running a crc car so I can't help with chassis setup but I would think going to .020 front springs would also help.
If your still in town Sunday I will be at the track with a pit box full of foams & tuning parts we can try to get it up to pace.
Mark
mtveten is offline   Reply With Quote
Old 11-14-2007, 09:46 AM   #883
mtveten's Avatar
Originally Posted by alana07 View Post
hi fellow MX2ers,
Moving the tweak springs further out from the center pivot lessens the leverage and will yield a firmer setting for a given spring.
Mark
Old 11-14-2007, 12:02 PM   #884
Feel free to contact me at [email protected] with any questions you may have
-Eric
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 11-14-2007, 12:05 PM   #885
Mark
Yep that's correct, thanks for the input!
-E
Team BSR
Team Power Push
Mafia Motorsports "Carbon Fiber" Pitboard and Motor stand Steve Bahnatka R/C Items: For Sale/Trade 10 10-15-2007 06:03 PM
The "DarkSide" enters nitro tourers! TomB Australian Racing 26 12-24-2006 06:06 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 05:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 09:04 PM
5 BRAND NEW - 3700 MAH EXPRESS MOTORSPORTS "TEAM" PACKS SweetRacing R/C Items: For Sale/Trade 17 05-08-2006 03:12 PM
