Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-05-2007, 11:27 AM   #436
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Good Luck Mike!!........... After seeing you shaking down your car on Sunday, I don't think your going to have a problem making the podium!
Alex Valdes
TQRacing / 360 V2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 02-05-2007, 11:38 AM   #437
Mike Haynes's Avatar
Thanks for the vote of confidence guys, but i wouldn't count on that right now...im too much of a hammer trigger guy for mod 12th still...lol
Now next month at the nat's il be running 19 turn again so just maybe
BTW Al...could't beat an 11.71 with the 12 even tho it felt good, i wanted that 6 so bad lol
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-05-2007, 11:39 AM   #438
Mike 415's Avatar
Eric Good Luck At the the SnowBirds .Got your message on techtalk,,Thanks,,,
Lead, Follow or get Mangled
Mike 415 is offline   Reply With Quote
Old 02-05-2007, 08:19 PM   #439
As I said I would here are pics of how I have the steering geometry setup on my Mx2:
First pic you see the hole I dremeled out for the servo saver to clear:
Top view of tie rod angle:
Front view you can see how the servo saver sits in the hole and can see the slight downward angle of the tie rods:
Last pic from the back of the car the tie rod angle is more more easy to see:
Old 02-06-2007, 03:44 PM   #440
Well looking at the car last night I noticed the change in ackerman. The angle difference between inside and outside tires is quite a bit less then the typical 1/12th setup. I'm not sure yet which is better...I never was totally comfortable with the ackerman on my 12L3 and 3.2R...I always thought it was a bit too much. However this might be too little. That can easily be cured though by moving the ball studs on the servo saver to the top holes or going with the larger servo saver if more is needed.
Old 02-06-2007, 03:59 PM   #441
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Good luck, Mike...You'll do well no matter how much of a "hammer trigger guy" you think you are
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-12-2007, 10:15 AM   #442
Dave G's Avatar
Mike: Good job at the birds, b main in mod 12th scale is a pretty good! Dontcha think? It was good to see you running with MARTIN in 19turn rubber as well. Congrats!
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline   Reply With Quote
Old 02-12-2007, 10:19 AM   #443
RaceAce701's Avatar
Trader Rating: 83 (99%+)
need a little help tuning my car
i race in stock on a very very tight track 4ft wide lanes and all 180 corners
the car puspes off power but is fine on power
any idea wat to do to get more offpower steering
it has 35 wt and a gold spring on the shocks
red side spring in the innermost holes
an 20,000 lube in the tubes
with purple fronts and grey rears
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 02-12-2007, 11:45 AM   #444
I think 20k tube lube is too heavy, probably making the car stay to flat and act a bit funky, try lightening it up to 10k or 7k, my cra seemed to like a lighter lube in that area.
Also, i recommend trying to run magenta front tires to gain more steering
Old 02-12-2007, 01:17 PM   #445
Our local race this weekend turned into more of a practice session due to lack of racers...but that worked out great for me. My Spektrum glitches are solved and I got a chance to really see what this baby can do. Since it was only a practice session we sprayed significantly less sugar water down and the car worked very well even in the lower traction. I've been using the thick CRC oil on the damper tubes and think I'm going to go down to the medium and I think it's about time to switch to a digital servo soon. The 94145 has been great but there's play in the gears allready that gives me a little trim issues. I let a buddy drive it and he had so much fun with it he ran it through an entire 3800 pack (stock motor).
Old 02-13-2007, 06:36 AM   #446
Trader Rating: 15 (100%+)
Got back from the birds last night. I got my outlaw 07 in the B. first time driving the car. So the car def works. finish 3rd in the E with the solid enemy. had a great time learned alot from eric. Mike, next time I am wheeling that thing. eric doesnt have confidence in me, LOL.
omnis85 is offline   Reply With Quote
Old 02-19-2007, 05:01 PM   #447
Raced stock 12th scale on Saturday at our indoor asphalt track. TQ and a win for the Darkside Mx2.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-19-2007, 07:32 PM   #448
Good to hear, keep up the good work
-E
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 02-20-2007, 04:40 PM   #449
Grenade10's Avatar
Trader Rating: 37 (100%+)
E - Picked up the parts at HT this morning....Thanks!!
I'm hoping to do as well on Wednesday night will be running the Black car (no not yours) as I got mine almost done last night.
I'll let you know if the repair works for the silver car. If it does, I'll fix Mike's as well.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 02-20-2007, 05:19 PM   #450
Scottrik's Avatar
Trader Rating: 240 (100%+)
Hey Mark,
The Billings Posse have our reservations (La Quinta/Westminster Mall) for the 2-day race!! Right now there are 4 of us coming down (I think ya'll have our entries...any way to get confirmation of that?) and Stormer keeps makin' "harumphing" noises like he may come too.
Looking forward to getting my a$$ handed to me by an entirely new group of racers!
Oh...to get it on-topic...got sidetracked on Operation Darkside Dial-in by Stormer wanting me to try running a Tamiya silver can in stock. Turns out it was a tenth and a half slower than the winner of stock, but MAN what a great idea for new drivers! REALLY have to smooth your lines. Ran the Darkside in 19-T, was doing OK right until I changed the shock spring before the main and didn't re-set the height. Can you say "black belly"? Needless to say the handling was a little off.
Maybe Eric should get on the ball and develop an "Idiot-Proof" chassis for, say, guys like me.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Mafia Motorsports "Carbon Fiber" Pitboard and Motor stand Steve Bahnatka R/C Items: For Sale/Trade 10 10-15-2007 07:03 PM
The "DarkSide" enters nitro tourers! TomB Australian Racing 26 12-24-2006 07:06 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
5 BRAND NEW - 3700 MAH EXPRESS MOTORSPORTS "TEAM" PACKS SweetRacing R/C Items: For Sale/Trade 17 05-08-2006 04:12 PM
SEO by vBSEO 3.5.0
