Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree9Likes
Old 09-20-2017, 05:38 PM   #991
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by jmcelroy42 View Post
With ROAR allowing 4 pole motors in 1/10 scale now, i am looking at trying out a Pro2 in my wheeler. I run a 5.5 now, what KV would you recommend?
I've done it lol. The 5100 is a beast but is close to a 5.5. The 4100 works great but lacks the snap a 5.5 would have.
Be careful, I melted mutliple spur gears testing this.
jmcelroy42 likes this.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-22-2017, 09:59 AM   #992
VegasHB's Avatar
Originally Posted by Randy_Pike View Post
That numeric figure is not a percentage of YOUR throttle input to the ESC. It's a figure that is based on the maximum allowable throttle singal we accept. As long as you are seeing "Flats" in the log you're getting wide open throttle to the ESC.
Another quick check is to power up your ESC and hit WOT and verify all LED's ramp up and then flash all at the WOT mark.
Need to add the ability to scale or percentage offset the throttle and brake value in the PC side of the tool. I've set all my radios to 100% value on brakes, throttle and re-calibrated the ESC and every Tekin ESC datalog is +/- 10-25% off and different for each esc.
It's very minor as you note as long as you see it flatline you know you're WOT but it seems like a simple fix for a software guy to institute in an update.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 09-22-2017, 11:34 AM   #993
Trader Rating: 76 (100%+)
Randy, any word on the 1S esc?
MUDVAYNE is offline   Reply With Quote
Old 09-23-2017, 01:23 PM   #994
Trader Rating: 46 (100%+)
A-main shows it available to pre-order for late November delivery.
Randy_Pike likes this.
biz77 is offline   Reply With Quote
Old 09-26-2017, 09:33 PM   #995
Do I need a booster/receiver battery pack for the RSPRO Black Edition to use 1s batteries.
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 09-27-2017, 09:46 AM   #996
Team Tekin
Randy_Pike's Avatar
If you're running the currently available 2s version, yes.
Old 10-08-2017, 03:40 PM   #997
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default Tekin sc4x 5.5 550 Brushless
How far past the notch on the can is recommend for this motor for timing? I'm using the notch in the can and the black timing notch as a base point.
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 10-15-2017, 02:24 PM   #998
MaxRain's Avatar
Default home made dyno
While testing I learned a valuable lesson. make sure to turn drag brake off or else the ESC may blow...
I wish I kept the plotted data from the current sensor when it peaked. I was in awe that it worked. Will be more careful in the future.
DBM likes this.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 10-18-2017, 03:44 PM   #999
Team Tekin
Randy_Pike's Avatar
Heat is the main concern. What ESC?
Old 10-20-2017, 01:40 PM   #1000
Trader Rating: 15 (100%+)
Is the 1st gen RS Pro still sufficient enough for 17.5 blinky TC? I would assume yes, but everything else has changed... I don't really want to buy more escs, as I have 2 of these already.
trilerian is online now   Reply With Quote
Old 10-20-2017, 03:28 PM   #1001
The original Rspro was sold with a 2.5t motor. It will have no issues running a 17.5t motor blinky or boosted.....
bertrandsv87 is offline   Reply With Quote
Old 10-23-2017, 07:48 PM   #1002
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Was getting ready to check out a new 5.5 for my 4w buggy. Noticed there is a 6.5 spec r motor too? Question is why would want this over a 5.5 or a 6.5 normal motor? Seems a mod motor with that low of turn has plenty of send it power without low resistance design. LOL
Cameron Kellogg is offline   Reply With Quote
Old 10-24-2017, 05:20 PM   #1003
Team Tekin
Randy_Pike's Avatar
Yes that's easily covered.
Old 10-24-2017, 05:21 PM   #1004
Team Tekin
Randy_Pike's Avatar
The Spec R 6.5 was specifically designed for the popular 1/12 6.5T "Mod" class. It may work in a TC but none of us liked the powerband in off-road.
Old 10-24-2017, 07:15 PM   #1005
Oh wow. Almost pulled the trigger on the spec r today. Glad I waited. I knew if it was not in Lutz's 4w buggy there had to be a reason. I have been wanting a 5.5 anyway. Guess I better order some front arms too. #sendit
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
