Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-29-2014, 07:17 PM   #826
Questions??
Hi Tekin gurus
I'm wanting to know how safe is it to run a 13.5t motor on the gen 2 rs spec esc in a road setup ?
I know that the esc is rated down to 13.5t but I have been reading a bit about guys cooking this esc using a 13.5. Is it safe or is it more so these guys are doing something wrong ?
Cheers
Boothy
Boothy82 is offline   Reply With Quote
Old 06-05-2014, 06:23 AM   #827
howardcano's Avatar
Trader Rating: 35 (100%+)
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-25-2015, 07:57 PM   #828
Is the older Hotwire compatible with the Gen 2 RS speed controls?
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 01-25-2015, 08:12 PM   #829
Team Tekin
Tekin Prez's Avatar
Yes all Tekin Hotwire units work with all Tekin esc's
Tekin Prez
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 02-15-2015, 09:25 AM   #830
Is there going to be a Tekin 1s esc? At the 2013 IIC I asked Randy about it, he said early 2014. Haven't heard anything about since.
Old 02-15-2015, 05:41 PM   #831
All Tekin ESC work on 1s now! Really no need to build anything else. requires a booster or a rx pack!!! Get over it, move on!!!
jakespeed is offline   Reply With Quote
Old 02-22-2015, 06:30 PM   #832
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
agree simple life pack is best. They usually have a switch and you just stick the wire in the open Rex port and everything works perfect..
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 05-07-2015, 08:08 AM   #833
Default Question on data logging
Never mind, I figured out what I was doing wrong with my RS Gen 2, no parameters were checked so it wasn't recording anything. All OK now. BTW I love my RS, RSX, and RX8 gen 2 ESCs. I really like the data logging features. It give me good feedback on motor/ESC temps, RPM, throttle position and helps big time with gearing. Only thing I'd suggest for the next software update or the Gen 3 would be to add AMP draw as a feature that can be tracked. I've seen some of the data logging on other ESCs and it only gives max values; having a time series throughout the entire race with the TEKIN ESCs is a real advantage.
John Wallace2 is offline   Reply With Quote
Old 05-07-2015, 11:21 AM   #834
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Boothy82 View Post
Hi Tekin gurus
Cheers
Boothy
Negative. The Spec is just fine on 13.5 all day long.
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-07-2015, 07:36 PM   #835
OZDC's Avatar
Trader Rating: 16 (100%+)
I was wondering if anyone else has experienced an issue with the RS Pro (version 1) and D4 motors.
I stupidly blew my Pro 2 so reverted back to my old faithful RS Pro.
I started getting hesitations at speed and off the start line at intermittent times when running my blinky, 13.5 D4, which ran fine with the Pro 2.
I swapped the sensor lead and then to another RS 1 and still had the issue. Swapped out the D4 for another D4 and still had the problem.
I finally swapped the D4 for a killshot and have not had the issue since.
So it would appear that there is an incompatibility between the RS 1 and the D4?
Anyone have any suggestions or experienced the same?
New ESC or have a D4 sale ?
Dave
OZDC is offline   Reply With Quote
Old 05-07-2015, 08:10 PM   #836
RacinJ's Avatar
I had the same issue with my old RS Pro. I would get intermittent loss of power under heavy acceleration. Only a few times per run. In different parts of the track.
I sent the esc in for repair but the problem didn't go away until I replaced the esc.
This was a few years ago with a speed passion motor. Sounds familiar.
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 05-08-2015, 06:49 AM   #837
Dave
I assume you are using a big capacitor on the Gen 1 ESC. The BEC on the Gen 2 ESCs fixed the hesitation problems I was having with the gen 1 ESCs particularly when I was using a high amp draw servo like the Savox..
Old 05-08-2015, 05:02 PM   #838
Team Tekin
Randy_Pike's Avatar
Dave
There should be no issue. However some sensor boards are "cleaner" than others. Try swapping the Killlshot pcb into the D4. As others have mentioned it can be "noise" from the servo on the BEC line also. Some servos are worse than others, a glitch eliminator cap can often fix the issue.
Old 05-09-2015, 12:46 AM   #839
OZDC's Avatar
Thanks all,
I have just the std capacitor, where and what would I use instead?
Servos are Futaba.
Just seems weird as 2 D4s have issue but the KS didn't.
Are the D4 boards different or more sensitive?
DC
Old 05-09-2015, 04:28 AM   #840
DC I think there is an issue with the D4 sensor boards.
I have seen the same issue with 2 other D4's purchased recently when used with LRP and Speed Passion ESC.
DamianW is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
