Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-24-2013, 02:40 PM   #766
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that is wrong motor type,but if it did it during a run it will more then likely have to go back.first try a factory reset and or a re flash with the hotwire,if it still does it contact them through the live chat to get a RA number
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-24-2013, 02:43 PM   #767
Trader Rating: 21 (100%+)
Originally Posted by rcadic View Post
Quick question
I have a rs pro and last weekend my Car stops, when I check my speedo the first 2 and last two led light is blinking, have steering but no throttle, what is wrong with this..
Wrong motor selected
http://www.teamtekin.com/manuals/RSManual.pdf
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 02-24-2013, 02:59 PM   #768
I did not know that is possible that while I'm driving it will switch to a different motor selection
But thanks for the info
thanks for my sponsors" bank of america, capitalone, federal credit union and commom wealth one"
rcadic is offline   Reply With Quote
Old 02-24-2013, 03:02 PM   #769
mrk80 is offline   Reply With Quote
Old 02-24-2013, 03:05 PM   #770
Quick question
I've had the same problem with my RX8 and pro4 combo it's happened about 5 times now????
After checking my wire connections found they were fine,
so i pulled apart the pro4 motor and found i had melted the solder on the wire solder post inside the can on the black wire post after re-soldering the connection the motor worked again but as i said it's happened about 5 times now so i have given up and bought a new RX8 and pro4 no problems yet... fingers crossed
Old 02-26-2013, 05:01 AM   #771
tc3team's Avatar
I was wondering if anyone had any experience of using a g11 pro with lipos and a 27t rebuildable motor?
I was considering using a 2s 40c 5200 turnigy or a 45c 4500c and could do without the cost of an ESC too atm
I did a search and found this info: tekin G11
I do realise of course that the ESC does not have a lipo cut off but as it won't be used with a fast motor and I will only use the lipo for one or two races max (with the power cap of course) before recharging it so that shouldn't be an issue but wondering if this setup will be OK to use?
Bascially, I'm contemplating using it for my son who is keen to start up racing with his first car but dont see the need for him to go brushless just yet.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-11-2013, 07:21 AM   #772
tc3team's Avatar
Anyone?
Old 03-11-2013, 08:31 AM   #773
Team Tekin
Tekin Prez's Avatar
The G11 is still a very good brushed esc and rated for mod motors. It should have no trouble with a 27T stock motor. There is actually a pro version with solder posts, and a regular version that comes with wires soldered to board.
Howevery I do have some concerns about the bec and some of todays servos that draw extreme unecessary current. If you avoid gold servos you should be fine.
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 03-12-2013, 04:42 AM   #774
tc3team's Avatar
First of all, it's nice to get an answer from you Jim, so thank you!
I don't plan on using a crazy motor or servo, as it will be my sons first r/c car. As and when (if) he wants to go faster, obviously then I will go down the path of brushless.
So hopefully my g11 pro will work ok with what you've said It has the solder posts and I will make the wires as short as possible.
Thank you for the answer!
Old 03-12-2013, 09:33 AM   #775
Team Tekin
Tekin Prez's Avatar
G11 can handle full mod brushed motors so no concern there at all.
It is not the crazy fast servos that are necessarily a problem. It is some of the lower cost servos that are known for needing a cap on the RX
www.teamtekin.com
Old 03-13-2013, 01:36 AM   #776
tc3team's Avatar
thanks again for the info
Old 05-01-2013, 10:07 PM   #777
Okay I am a rookie and just got a tekin rs esc used. How do I know or get it into blinky mode without a Hotwire
Bkautz is offline   Reply With Quote
Old 05-02-2013, 09:25 AM   #778
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If the unit has 223 software in it, simply use the mode/inc buttons to select TP 1
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-16-2013, 11:53 PM   #779
Hi Randy,
I usually race in blinky class. But if I am going to race in boosted or mod, how do I choose the correct start/end rpm for the different turn motor?
faifaisalfal is offline   Reply With Quote
Old 06-14-2013, 10:11 AM   #780
Team Tekin
Randy_Pike's Avatar
Essentially the lower turn the motor the higher the end rpm will be.
So a 10.5 may be fine on the 20k end rpm but a 4.5 will be better served with a 40k end rpm or more.
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
