Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree5Likes
Old 10-01-2012, 05:20 AM   #736
tjompa's Avatar
Update, Randy! it worked fine! Did tuned it a little bit for our track and now the driving skills is lacking..haha
tjompa is offline   Reply With Quote
Old 10-01-2012, 09:18 AM   #737
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Awesome, we haven't but a "drivers talent" setting into the esc's just yet. We're working on it lol...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-01-2012, 08:10 PM   #738
rosko's Avatar
I have a tekin pro i just updated to latest software from out the box,using blinky mode i did reset my radio and speedo again. holding car in the air going from forward to brakes, when braking it make a clicking noise as if the speedo wants to still go in reverse unless i turn my brake epa down to like 70%. what should i do to fix that
rosko is offline   Reply With Quote
Old 11-01-2012, 08:27 PM   #739
I was wondering if Randy could tell me what wattage the mini rage can handle. I've been looking around at 20mm brushless motors and I'm not really sure if I still need to hold fast at 20mm can diameter or if I can go up to a 24mm diameter, like this guy.
Sabin is offline   Reply With Quote
Old 11-07-2012, 11:31 AM   #740
Team Tekin
Randy_Pike's Avatar
It should run that motor fine.
Old 11-10-2012, 09:58 PM   #741
For TC Stock, I'm thinking of a Gen2 17.5 paired with an RS speed control. Is this a suitable pairing?
Thanks.
jjjheimer is offline   Reply With Quote
Old 11-11-2012, 05:42 AM   #742
Bullz's Avatar
Hi Guys,
A few question to ask as being new to Tekin RS Pro. Does anyone use Ko Propo and calibrate with Tekin RS Pro running the newest firmware? Throttle & Brake EPA of Ko Propo can be set to 150, but following the Rekin RS Pro manual, it stated to set both EPA to "100 percent". Should i dial down from 150 to 100 before calibration procedure? Thanks in advance,
regard,
bullz
Bullz is offline   Reply With Quote
Old 11-14-2012, 11:59 AM   #743
Team Tekin
Randy_Pike's Avatar
I use the latest Ko radio. You can go 150/150 and get a bit more resolution but it's minor. I prefer 100/100 so when I tell someone I have my brakes turned down 20% they can match it on their radio at the same rate.
Old 11-14-2012, 07:37 PM   #744
Halve's Avatar
Sorry if this has been asked and answered already. Is the Gen2 stock 17.5 motor roar legal???
Life moves pretty fast... If you don't stop and look around once and a while...
You could miss it.
ProLine : LRH Hobbies
Halve is offline   Reply With Quote
Old 11-14-2012, 08:41 PM   #745
Also, Gen2 17.5 2404 and 2405 are the same price.. is it worth going for the RPM ver or just stick with the normal Gen2?
Old 11-17-2012, 02:34 AM   #746
Bullz's Avatar
Thanks for the info, Randy.
is there a guide somewhere for being new to Tekin RS pro? my ESC been heating up in my last race which i failed to complete 5 minutes race running 5.5T LRP X20. Esc cut off but when check the motor temp it only reach 65c. What setting was set too extreme that cause ESC cutoff?
Old 11-19-2012, 10:27 AM   #747
Team Tekin
TY@TEAMTEKIN's Avatar
It has been sent in to ROAR and will be legal as soon as they give the approval.
The RPM version gives a slight advantage over the regular version, but you lose a little torque in the process. It's really up to you which one, the RPM one just gives slightly higher RPM output.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 12-08-2012, 08:39 PM   #748
Trader Rating: 57 (100%+)
This is a question regarding the Tekin FXR
When I go full throttle it pulses. Never really goes "full throttle" but by sound about 1/2 throttle, then dies out, then goes back to 1/2 again in about 1 second increments. In reverse it will go to full throttle.
I've changed motor (silver can), battery, and went through my radio gear everything with that is fine. Also plugged it into hotwire and reset settings.
PROMODVETTE is offline   Reply With Quote
Old 12-10-2012, 04:05 PM   #749
Team Tekin
Randy_Pike's Avatar
Do the led's hold steady while on full throttle?
Old 12-10-2012, 05:02 PM   #750
They are all on and flashing at a constant rate.
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
