Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-23-2012, 10:23 AM   #721
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by rcadic View Post
Question guys
I have tekin rs and I want to run 10.5 mod. Is any of you guys have a good tekin set up, I'm using 2012 Xray, on mid traction outdoor asphalt,
It would help to know the size of the track.
Hara's 11.5 setup esc wise is a good place to start, aggressive though so watch motor temps while you find the right gearing for your track and layout:
http://teamtekin.com/hotwire/ESCsetu..._11.5_v212.pdf
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-23-2012, 05:15 PM   #722
liteweight's Avatar
Originally Posted by Randy_Pike View Post
Which 5.0T is it? You don't mention and with what esc?
5.0 reedy sonic , rs pro, low traction outdoor asphalt
Thsnks
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 08-24-2012, 02:43 PM   #723
Bigz84's Avatar
Trader Rating: 15 (100%+)
Default set up
Randy or any other Team Tekin Driver,
What would be a good starting point for the RX8 esc? I was using an LRP SXX TC, stock set up, 11-12 pinion, in a Losi SCTE, on a 100x60 mid to high bite clay, indoor, currently using a Novak 4.5 motor. Using the LRP, i was lacking a little speed on the straight.
Let me know and thanks for any info...
Bigz
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 08-24-2012, 04:07 PM   #724
goatman's Avatar
Default speed control and motor issues Help PLease
Hey Tekin
I run a rx8 speedo and a sct4x motor in my losi sct ten
I have run it for 5 or so big races and no issues when at my recent race it started to make a cogging noise and starting and stoping. I took it off and ran it in the next qually and seemed fine and then did it again. Third time it was just flashing first 2 and last 2 lites on the speedo, according to the sheet it means wrong motor? what could be the problem hopefully you guys can help.
"no go in Calgary"
Larry "Goatman" Blois
Checkout the new ldrcgraphics.net site
"We still do decals but added some new stuff"
TEAM RCDEPOT
goatman is offline   Reply With Quote
Old 08-25-2012, 12:20 PM   #725
Team Tekin
Randy_Pike's Avatar
Thsnks
Start out in sensored only mode, 20 boost, 0 motor timing, 10k start, 35k end rpm...find your gearing while checking lap times and motor temp.
Old 08-25-2012, 12:21 PM   #726
Team Tekin
Randy_Pike's Avatar
Bigz
Use this SC4x setup on your novak:
http://teamtekin.com/hotwire/ESCsetu...pbell_v223.pdf
Old 08-25-2012, 12:23 PM   #727
Team Tekin
Randy_Pike's Avatar
Originally Posted by goatman View Post
Hey Tekin
"no go in Calgary"
Try another known good motor. If the code is still displayed and you know you're on a brushless motor type, you may need esc repair.
Old 09-12-2012, 04:53 AM   #728
not sure if this is the right place for this. I have a Tekin FXR in a crawler, and it is not working. As soon as I move forward or backward within 2 seconds or so, it stops working. The servo keeps working but I can't move forward or back. I believe all the lights come on, but they are very dim. Is this thing jacked up or am I just being dumb?? And if this is in the wrong place please let me know or move it. Thank you.
mgillooly is offline   Reply With Quote
Old 09-12-2012, 09:45 AM   #729
Team Tekin
Tekin Prez's Avatar
Dim leds can indicate a BEC load pulling down the voltage. Try to drive it without the servo plugged in. Might also try a different receiver to cover all the bases before it has to be sent in. You can also plug the throttle into the steering channel on the receiver and drive it with wheel to see if it is a bad channel.
All this assumes you are using the BEC and not a seperate BEC unit.
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 09-12-2012, 03:35 PM   #730
Originally I had a cc bec connected to it, but it was not working so I removed it. I swapped out the receiver as that was my first thought. And even while connected to the steering channel with nothing connected, when I turn the wheel on the transmitter the lights light up with how I am moving but stop after 2 to 5 seconds and nothing else will happen. I wanted to make sure the motor wasn't the problem either so I disconnected it from the esc and same results. And just incase for good measure I connect a hh br xl and it all works fine. This FXR is brand new just installed it, I have one in a different vehicle and it works great so I was surprised when this one did not.
Old 09-12-2012, 03:52 PM   #731
Team Tekin
Tekin Prez's Avatar
Always worth trying to update the software. We are releasing a new software for the FxR shortly. We have been giving out beta software for testing and all looks good.
It may just be broke It happens... and we take care of it best we can
www.teamtekin.com
Old 09-12-2012, 04:02 PM   #732
I believe it still connects with the tekin hot wire and takes a program, just doesn't make the vehicle move.
Old 09-28-2012, 03:32 AM   #733
tjompa's Avatar
Hi everyone!
Where can i find Tekin rs pro setups for 1/12 scale 1s lipo 13.5 stock class? Thanks in advance.
tjompa is offline   Reply With Quote
Old 09-28-2012, 11:42 AM   #734
Team Tekin
Randy_Pike's Avatar
Originally Posted by tjompa View Post
Hi everyone!
http://teamtekin.com/hotwire/ESCsetu..._13.5_v212.pdf
Old 09-29-2012, 01:13 AM   #735
tjompa's Avatar
Thanks Randy! This will be tested tomorrow.
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
