Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-29-2011, 09:10 PM   #646
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Ok, I have strange problem. rs pro problem, I am running 212. Now after I put my esc into my SCR I have blinking 1,2 +6,7 which by the trouble shooting table is motor settings incorrect. But the problem is my motor setting is set for 1 (brushless, brake, no reverse) (verified in hotwire) I have tried a couple different sensor cables and 2 different motors and same outcome. Is this a send back to tekin or is there a way to make it happy again? Tried resetting factory settings didn't work. Unless someone has some input this is going back to tekin
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 09-29-2011, 09:17 PM   #647
smilekt's Avatar
Originally Posted by Still Bill View Post
For onroad carpet...You will know after the IIC...
thank still bill ... when iic 2011 ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 09-29-2011, 09:34 PM   #648
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by RedBullFiXX View Post
Thanks.
Regarding C1 and C2:
"Now, C1 and C2 are great for racers running multiple classes with the same chassis or ESC. With these custom profiles you are allowed to save them BOTH in the ESC for later use, as well as the 5 preset profiles. So say you have 17.5 spec, running TP1 "blinky" mode one heat and the next you run 13.5 Pro Stock with the C1 profile. This essentially allows your RS/RSPro to be 2 ESCs in one by simply switching between profiles while swapping motors!"
How do I switch from C1 to C2 and back without using the Hotwire?
YR4Dude is offline   Reply With Quote
Old 09-29-2011, 09:55 PM   #649
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by YR4Dude View Post
Thanks.
Use quick tune mode as shown in the original manual.
Mode and Incr Buttons
To select Throttle Profiles
1: TP1: Spec Stock "blink mode" 0*timing boost
2: TP2: 15* Timing Boost / RPM Range 5443-20,016
3: TP3: 25* Timing Boost / RPM Range 5443-20,016
4: TP4: 35* Timing Boost / RPM Range 5443-20,016
5: TP5: 45* Timing Boost / RPM Range 5443-20,016
6: C1
7: C2
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-29-2011, 10:08 PM   #650
YR4Dude's Avatar
6: C1
7: C2
So on LED 5:
I would select LED1 - LED6 for C1
I would select LED1 - LED7 for C2
Yes? Does that mean Throttle Profile and Timing Profile are both the same?
Old 09-30-2011, 07:02 AM   #651
So on LED 5:
TP is Timing Profile when using Quick Tune.
Previous to v208 it was Throttle Profile.
Old 09-30-2011, 08:16 AM   #652
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
make sure you dont have any solder crossing the post also pull the end bell off and check
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-30-2011, 09:42 AM   #653
rx7ttlm's Avatar
checked, shipping it back to tekin.
Old 09-30-2011, 11:41 AM   #654
YR4Dude's Avatar
Okay, sorry to be so redundant.
Now that the speed control is running v212, LED 5 which used to be Throttle Profile according to the original manual is now Timing Profile. Yes?
So does that mean the Throttle Profile in the Hotwire is disabled?
Or is it...
The Throttle Profile is only adjustable in the Hotwire and that LED 5 is now only for Timing Profile.
Old 09-30-2011, 02:17 PM   #655
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Now that the speed control is running v212, LED 5 which used to be Throttle Profile according to the original manual is now Timing Profile. Yes?Yes
So does that mean the Throttle Profile in the Hotwire is disabled?No
Or is it...
Correct
Answers in Red.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-01-2011, 11:49 AM   #656
YR4Dude's Avatar
Originally Posted by Randy_Pike View Post
Correct
Answers in Red.
Thanks.
I had programmed a Non-boost profile for C1 and a Boosted profile for C2. When I set it on C1, as expected, I got no boost but also didn't get a "blinky" LED. It seems that "blinky" only happens when Timing Profile is set on LED1. Thats fine. So long as I can "Pit Tune" the speedo to "blinky", that leaves me two custom profiles to pre-set for different levels of boost and turbo.
Old 10-01-2011, 01:27 PM   #657
Thanks.
That's the beauty of the Tekin RS, with Free updates
Old 10-30-2011, 11:15 AM   #658
Default help with redline 10.5
Bought a used rs/redline 10.5. Ran it on the track in my b4, works great. Took a bad landing and adjusted the motor mesh. Turns out the mounting holes are stripped. I tried rotating the end cap and 3 of the six holes are stripped. Does Tekin offer the end plate or am I out of luck? Was using the mounting screws from a sc10 rs rtr. (3x6mm) Could I try a longer mounting screw?
Thanks for any info.
TLR 22 10.5/17.5; 22SCT 17.5; SCTE King Headz
King Hobbies and Raceway Valparaiso In.
Leisure Hours Joliet Il.
Rawwolf is offline   Reply With Quote
Old 10-30-2011, 11:19 AM   #659
20 SMOKE's Avatar
TT2281
http://teamtekin.com/blmotors.html
Jamie W
Old 10-30-2011, 11:55 AM   #660
Thank you very much. I looked at the website before i posted, saw the picture but didnt think it was anything to click on LOL
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
