Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree2Likes
Old 11-18-2010, 06:22 PM   #571
Trader Rating: 24 (100%+)
Looking for a starting point in 1/12th stock (17.5) with not limitations on speedo, tight track. Roll out and speedo settings as a starting point for my son. He is using a RS Pro in a AE 12R5.1
Jeff Ford is offline   Reply With Quote
Old 11-18-2010, 07:14 PM   #572
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Jeff we can Josh close in no time... I have a normal base we put in new cars that gets a good start for stock 1/12th... From there we will have to work driving style roll out to lock in the motor.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 11-18-2010, 07:28 PM   #573
O'k, he may stop by on saturday if you end up having practice after oval racing as long we/he knows about it in time.
Old 11-18-2010, 07:47 PM   #574
ammdrew's Avatar
No oval Saturday.. Only once a month but we may have myself or jess in Saturday night for a bit and open up... Should know by tomorrow night... Jess can get home really close also... Friday night we can get a base setup in also....
Old 11-20-2010, 07:59 PM   #575
fullout's Avatar
Send a message via MSN to fullout
Default M11x with 451r in high response mode
Can you tell me if i should be using the normal or HRS mode with my tekin RS, which by the way i have been super pleased with?
fullout is offline   Reply With Quote
Old 11-23-2010, 06:51 AM   #576
RacinJ's Avatar
Default 17.5 Redline Rotor Question
I'm looking to replace the rotor in my 18 month old 17.5 Redline. I'll be running 1/12th scale spec, "blinky", no boost, would you recommend the 12.3 or 12.5 mm rotor?
What is the performance and/or feel difference between the 12.3 and 12.5 mm rotor ROAR legal?
Thank you.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 11-23-2010, 06:57 AM   #577
Trader Rating: 21 (100%+)
Thank you.
12.3 more speed
12.5 more torque
http://www.teamtekin.com/blmotors.html#redlines
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 11-23-2010, 09:47 AM   #578
Regional Moderator
CarbonJoe's Avatar
Originally Posted by lidebt2 View Post
12.3 more speed
12.5 more torque
I'd phrase what you said about the 12.3 rotor as "more RPM" instead of "more speed". You more than likely would need to change your gearing when changing rotors.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-23-2010, 04:28 PM   #579
RacinJ's Avatar
When running 1S 1/12th scale, is there an advantage in running one rotor over the other?
I see other motor manufacturers offering 1S rotors and they seem to have a smaller diameter.
I guess I should be asking what is a 1S motor? Is the Tekin motor a good 1S motor?
Old 11-23-2010, 04:33 PM   #580
chris moore's Avatar
Trader Rating: 87 (99%+)
Run the 12.5, it'll slow you down.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-23-2010, 04:35 PM   #581
question on the tekin RS. is there a limit on the amount of times you can solder on the posts?
i replaced my battery wires once, and in the next couple of days im going to replace my capacitor on my tekin rs as well add a 1s booster, to which ill have to remove my battery wires again off the posts... i know if i have the iron on too long, it can damage it, but i make sure i let it cool and work quickly....
honhon is offline   Reply With Quote
Old 11-23-2010, 07:44 PM   #582
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
just don't leave it on the post to long as the heat transfers fast on metal source
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-24-2010, 05:57 AM   #583
RacinJ's Avatar
Gonna need all the help I can get.
Old 11-24-2010, 07:14 AM   #584
so the frequency of soldering doesnt hurt?
Old 11-24-2010, 08:04 AM   #585
TrevCoult's Avatar
No there is no limit, as long as you don't leave the heat on for too long. Just follow the instructions on soldering in the RS manual, they are good.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
