Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree9Likes
Old 12-11-2009, 03:02 AM   #496
Big_Boy's Avatar
Is there any and or how do I go about the Military discount that I hear Tekin has? ?
Panther Tire's / Banzai Motors /
Big_Boy is offline   Reply With Quote
Old 12-11-2009, 07:42 AM   #497
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
first post says how
Tekin shows support for military!!!
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-04-2010, 01:28 AM   #498
YAH
YAH's Avatar
Trader Rating: 77 (100%+)
Hi Randy,
I am from the land downunder.
I just bought a RSPro and 17.5 Redline combo as well as Hotwire. I am new to Tekin. Have been able to follow through getting latest Vega 2.0 downloaded and installed.
The question I have is
What is the advantage if any running Dual Mode versus running Sensored Mode. I looked at a couple of team driver set up sheets for 17.5 and they all ran Sensored Mode with 0 timing advance at the motor. Is that the preferred set up for 17.5?
The only Surviving Active Life membership of the Smash 'EM! Racing Team, WA's Home of Fun in RC Motorsport, has retired!!
2013 WCMRC club champion - VTA and Mini.
YAH is offline   Reply With Quote
Old 03-04-2010, 07:41 AM   #499
spencehotbodies's Avatar
Default SET UP FOR RS
Hello
Hope you can help?
Do you have a set up for the rs, using a 13.5 speed passion or novak motor?
Thanks Inadvance
Spence
spencehotbodies is offline   Reply With Quote
Old 03-04-2010, 10:47 AM   #500
20 SMOKE's Avatar
Originally Posted by YAH View Post
Hi Randy,
dual mode is using timing advance only (30deg) and no motor timing, used more in the low turn mod class ,in sensored mode for high turn stock classes you get the motor timing,timing boost and turbo boost and tuning with the start and end rpm range,all these features are why tekin is on top of the esc game
Jamie W
Old 03-04-2010, 04:30 PM   #501
YAH
YAH's Avatar
Thumbs up Cheers
Thanks mate
Old 03-05-2010, 07:27 AM   #502
Default RS LOST THROTTLE SETTINGS
Hello
Need help
Have got 2 rs esc both set up no problem, but one of them has starting losing the throttle profiles....................have to keep reseting.
Any help would be great?
Cheers
Spencer
Old 03-05-2010, 07:31 AM   #503
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
for that one setting in hotwire that deals with Concave, etc. I believe for throttle response. Which setting gives it a linear feel?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-05-2010, 07:35 AM   #504
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by spencehotbodies View Post
Hello
Need help
Cheers
Spencer
Most of the time, these problems can be solved by reloading the software into the speed control. Hook up the hotwire and select 203. Click "update esc" and then go through the setup procedure again. That should take care of your problem.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-19-2010, 02:37 PM   #505
bigtp2's Avatar
Trader Rating: 24 (100%+)
What voltage does a Tekin RS Pro output to the receiver and servo?
Also, can it be changed?
Thanks.
bigtp2 is offline   Reply With Quote
Old 03-19-2010, 04:14 PM   #506
Thanks.
I thought the voltage of the battery you use.
So as you use a 2 cell lipo 7,4V and as you use a 1 cell lipo 3.7V
No it can not be changed with the speedo.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-20-2010, 11:08 AM   #507
theisgroup's Avatar
Thanks.
the bec of the speedo limits voltage to 5.7 to the rx/servo. but it does nto boost voltage. so if you have less then 5.7 to the speedo, then whatever you feed the speedo is what it feeds to the rx/servo
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-20-2010, 10:54 PM   #508
64buick's Avatar
Default newbie help
Im new to the tc racing and I am looking for some good esc,gearing set-ups for my tf-5, heres what im running now.
Motor:Ballistic 17.5 with 15 degrees timing
CAR:Kyosho tf-5 stallion
100 tooth spur
26 tooth pinion
internal is 1.8
final drive is 6.93
rollout is1.113
ESC:Tekin rs
version 203
sensored mode
Drag:20
Reverseff
Brake:100
Neutral:10
Motor:1
Throttle:3
Voltageff
Pushff
Timing boost:50
Turbo boost:10
Delay:.2
Turbo ramp:3.0
Start rpm:2903
Ending rpm:13000
64buick is offline   Reply With Quote
Old 04-03-2010, 08:15 AM   #509
colt1402's Avatar
Trader Rating: 90 (100%+)
Hi team Tekin mates,
I am currently using Tekin FX-R for my local stock 28 turn motor. May i ask if Tekin web site have any LATEST software for my current FX-R? If so does it help me to have increase punch & power? If not what is the latest software all about. Please enlighten...
Looking forward hearing from you soon. Thank you!
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-14-2010, 02:36 PM   #510
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes the latest software is on the site. It improves the bottom end thottle resposne.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
