Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-23-2009, 02:43 PM   #421
I have actualy found, running the RS Pro in sensored mode, pretty good, as it is easy to add a little more top end speed.
keep the neutral width to 1bout 15 on the hotwire
TP linear (3)
Limiter to about 85
Boost about 10-15
gear about 10.5:1 on a long track
DA_cookie_monst is offline   Reply With Quote
Old 04-23-2009, 03:17 PM   #422
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I run the 6.5 often and use 84/19 and run the following setup:
If you need more top end just bring up the "Timing Advnace" in incriments of 10. Pay attention to motor temp after every adjustment.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-24-2009, 01:47 PM   #423
Thank you for the quick replys.
I will start with the attached settings (or in that range).
I will get some 16-20 tooth pinions anyway, but it was mostly the Hotwire settings I'm a little confused about.
Is there perhaps some downloadable manual I can read ahead of time untill I recieve the ESC/motor combo.?
sasquatch is offline   Reply With Quote
Old 04-24-2009, 02:15 PM   #424
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Hey guys, I just purchased an rc10 and I have a r1 pro with 448 sensorless and am geared 22/87. This thing is wicked fast and was good in my slash but is soo fast in the sc10 its uncontrollable. I have a dx3s so I have my end point turned way down but there must be another motor that would better suit this setup. I only drive on the track but alternate from a large to small 10 scale track. I also am waiting for my hot wire to come in so what should my base starting setup be when I get it? Thanks for the help on this great product you guys have produced.
-WHEELMAN- is offline   Reply With Quote
Old 04-25-2009, 12:14 AM   #425
RCBLUE's Avatar
You might want to consider a Redline 632 motor. Still very fast but also much more drivable in a sc10. Once you get your Hotwire email Randy Pike to get the newest software for it because the newer version help the R1 out quite a bit. I used to run the Redline 448 motor in my 4 wheel mod car and that was way stupid fast. It is insane power for a sc10.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 04-26-2009, 10:19 PM   #426
-WHEELMAN-'s Avatar
Thanks a bunch, I'll look into getting that motor. In the mean time what would a base set up be with hot wire? I ran at OCRC and it was hooking up pretty good and my 448 was pretty killer with some traction.
Old 04-27-2009, 04:12 PM   #427
Team Tekin
Randy_Pike's Avatar
I would try to tame it a bit since the 448 is A LOT of motor for an SC10.
Try running low timing advance like 20 or so. Next use the Punch Control and set it like 75.
Then remember to "squeeze" the trigger!
Old 04-27-2009, 06:32 PM   #428
RCBLUE's Avatar
SLOWLY!!
Serpent America
Lunsford Racing
Old 04-27-2009, 07:02 PM   #429
-WHEELMAN-'s Avatar
Awesome, Thanks Randy and blue. I am in the process of building my 8TE 2.0 conversion and think I'm going to swap the MMM I have for an RX8. It sounds like everyone is really liking the RX8.
Old 04-27-2009, 07:12 PM   #430
RCBLUE's Avatar
Yeah, I don't have one just yet, because my other 1/8th scale is in about 1500 different pieces, but I have seen them first hand and they rock. Even a mild system in the right hands can destroy most nitro cars with a similar level driver.
Serpent America
Lunsford Racing
Old 05-04-2009, 07:19 AM   #431
stiltskin's Avatar
Trader Rating: 102 (100%+)
Will an RS pro work in 1/8 scale applications with a fan? Probably looking to run 4s.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-04-2009, 11:50 AM   #432
Team Tekin
Tekin Prez's Avatar
It worked very well in our testing. It can get overheated because of no heatsink, but ran fine with typical buggy setups. A fan at the solder posts is helpful.
You do need at least 25V caps for 4S and 35V caps for 5S or 6S.
You also need a seperate BEC unit and pull our red wire from the reciever plug.
If you do use the RSpro in 1/8 scale we want it in Dual mode with fairly low timing. NO sensored only mode, especially with 40mm motors like our T8 1/8 motors.
Tekin Prez
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 05-04-2009, 12:57 PM   #433
I just bought an RS Pro and Redline 13.5 combo and just wanted to say thanks for making such a great product
Bull_Dog is offline   Reply With Quote
Old 05-04-2009, 03:23 PM   #434
stiltskin's Avatar
Any recommendation on motors when using the RS pro in 1/8 scale?
Tony Rumple
Old 05-04-2009, 04:11 PM   #435
Team Tekin
Tekin Prez's Avatar
To get the full advantages you need a Tekin T8 motor. It will work with any 1/8 scale motor.
www.teamtekin.com
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
